Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Shoes
Fit Shoes
Discuss Wheels & Tires for the Fit and Jazz
Forum Sponsor: Tire Rack
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #21 (permalink)
Old 01-21-2009, 02:40 AM
fitinfit's Avatar
fitinfit relies on Rep Points to livefitinfit relies on Rep Points to livefitinfit relies on Rep Points to livefitinfit relies on Rep Points to livefitinfit relies on Rep Points to livefitinfit relies on Rep Points to livefitinfit relies on Rep Points to livefitinfit relies on Rep Points to livefitinfit relies on Rep Points to livefitinfit relies on Rep Points to livefitinfit relies on Rep Points to live
Quote:
Originally Posted by raton View Post
Just picked up the RPF1 15" (41 offset) on Dunlop Star Spec (195/55/15). On Skunk2 ProCs. No rubbing.
offtopic, how much more can you lower with the Pro-C in these pictures on the 15's?
__________________
07 Sport 5MT(back to stock)
  #22 (permalink)
Old 01-21-2009, 03:37 AM
raton's Avatar
raton relies on Rep Points to liveraton relies on Rep Points to liveraton relies on Rep Points to liveraton relies on Rep Points to liveraton relies on Rep Points to liveraton relies on Rep Points to liveraton relies on Rep Points to liveraton relies on Rep Points to liveraton relies on Rep Points to liveraton relies on Rep Points to liveraton relies on Rep Points to live
Quote:
I'm sure I could drop another 1/2 inch or a little more front & rear. Not sure if it'll rub though. I've got -2.5 camber on the front w/ camber bolts so it helps avoid some rubbing. The current height is so I don't scrape my driveway everytime I go home.
I never tried the max drop but u could probably go even lower.
__________________
'08 SSM Sport 5-Speed MT
  #23 (permalink)
Old 01-21-2009, 05:01 AM
feared relies on Rep Points to livefeared relies on Rep Points to livefeared relies on Rep Points to livefeared relies on Rep Points to livefeared relies on Rep Points to livefeared relies on Rep Points to livefeared relies on Rep Points to livefeared relies on Rep Points to livefeared relies on Rep Points to livefeared relies on Rep Points to livefeared relies on Rep Points to live
car looks sick, good job
__________________
2008 Honda Fit Sport SSM
  #24 (permalink)
Old 01-21-2009, 10:11 AM
mahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to live
Getting some wheels, Enkei Rpf1 15x7, anyone know which offset is better? I see most people got the +41, I'm just curious if the +35 would work as well(clear stock calipers?)? probably look better? Thanks in advance!!
The v41 offset works without modding the fenders and has as much performance as the 35. Most have to use narrower tires with the 35 so looks aren't diiferent enough to tell at 10 yards. Performance may be better with 41's and wider tread on lightweight tires.
  #25 (permalink)
Old 01-21-2009, 10:36 AM
rvall004's Avatar
rvall004 relies on Rep Points to livervall004 relies on Rep Points to livervall004 relies on Rep Points to livervall004 relies on Rep Points to livervall004 relies on Rep Points to livervall004 relies on Rep Points to livervall004 relies on Rep Points to livervall004 relies on Rep Points to livervall004 relies on Rep Points to livervall004 relies on Rep Points to livervall004 relies on Rep Points to live
u have to go with the 35 offset they will look 10 times better thatn the 41
__________________
If you SCARE of the Boost go to CHURCH
  #26 (permalink)
Old 01-21-2009, 11:48 AM
dewthedew's Avatar
Fit Moderator
dewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to live
Send a message via AIM to dewthedew
any pics of the +35?
  #27 (permalink)
Old 01-21-2009, 01:29 PM
rvall004's Avatar
^^^chek jerome's car he has 35 offset..his username is boris..something i forgot
__________________
  #28 (permalink)
Old 01-22-2009, 10:36 PM
BoriJDMGD3's Avatar
Ihh IS Jaaaarome!
BoriJDMGD3 relies on Rep Points to liveBoriJDMGD3 relies on Rep Points to liveBoriJDMGD3 relies on Rep Points to liveBoriJDMGD3 relies on Rep Points to liveBoriJDMGD3 relies on Rep Points to liveBoriJDMGD3 relies on Rep Points to liveBoriJDMGD3 relies on Rep Points to liveBoriJDMGD3 relies on Rep Points to liveBoriJDMGD3 relies on Rep Points to liveBoriJDMGD3 relies on Rep Points to liveBoriJDMGD3 relies on Rep Points to live
Quote:
my sig ...
__________________
KillerFit #6
I CLICK THROUGH GEARS !!!!
  #29 (permalink)
Old 01-24-2009, 11:57 PM
wdb's Avatar
wdb wdb is offline
wdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to live
I ordered the '02-'08 Honda CR-V center caps (#44732-S9A-A00, CenterCaps.net - Cap Listing - Honda Details - CR-V). Hopefully, they'll work ok. If not...meh...
Subscribed to find out the answer -- please let us know.
  #30 (permalink)
Old 01-25-2009, 12:06 AM
dewthedew's Avatar
Fit Moderator
Quote:
Originally Posted by BoriJDMGD3 View Post
my sig ...
looks good any bigger pics?
  #31 (permalink)
Old 01-25-2009, 03:45 AM
BoriJDMGD3's Avatar
Ihh IS Jaaaarome!
thanks, Ray have them on his camera...
__________________
KillerFit #6
  #32 (permalink)
Old 01-25-2009, 10:09 AM
Tork's Avatar
Location: Winthrop Harbor Illinois/ Presque Isle Wisconsin
Tork relies on Rep Points to liveTork relies on Rep Points to liveTork relies on Rep Points to liveTork relies on Rep Points to liveTork relies on Rep Points to liveTork relies on Rep Points to liveTork relies on Rep Points to liveTork relies on Rep Points to liveTork relies on Rep Points to liveTork relies on Rep Points to liveTork relies on Rep Points to live
Quote:
Originally Posted by kenchan View Post
i would do +41 on the front and +35 on the rear for a nice flush look.
+35 sticks out too much for my personal tastes, plus more potential for rubbing.
Agree with Kenchan except an option would be go +41 all around and use 5MM spacers on the rear (5MM are usually cheap) Keep in mind your stock wheels are +55 so 41's push your tires out about 5/8ths of an inch.
__________________
SSR Type-C, RS*R Ti 2000, Odyssey Battery, Unorthodox Racing lightweight pulley set. Tork's $11 Grill mod, 1st JDM T-Light swap, Skunk 2 short shifter, rear wiper delete, front little wiper delete, PRM intake (the original longer tube design) I am forever humbled and grateful for my wife and I having the privilege of adopting our 2 daughters from China.
  #33 (permalink)
Old 01-25-2009, 12:14 PM
BoriJDMGD3's Avatar
Ihh IS Jaaaarome!
35mm wont stick out!!! and it wont rub, if you put a 41mm and 5mm spacers you will have less thread in your lug studd... and it will almose the same thing ...
__________________
KillerFit #6
  #34 (permalink)
Old 01-25-2009, 12:30 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Raaaaaaaaaay. is an unknown quantity at this point
Ive ran +26mm... The tires are just inside the fenders and rear 1/4's. Yes it rubs a lot.
+35mm wont stick out at all.
It may rub a little, nothing the fender lining mod wont fix.
Heres Jeromes car.
Do a search on my name. My car is as low as itll go on Pro-C's.
I hit frame on some parts of the road.
__________________
- KillerFit #2 -
- iFrame -
  #35 (permalink)
Old 01-26-2009, 12:00 AM
that's actually not a bad idea, looks almost the same but you can still rotate your tires... i may look into this haha
__________________
  #36 (permalink)
Old 01-26-2009, 12:21 AM
YeeFit's Avatar
YeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to live
Quote:
I beg to differ.. You might not rub going in a straight line but once you start cornering you'll rub guaranteed. I'm running +41mm and I rubbed a lot. 195 series tires too. Those that say you won't rub either must not be lowered at all or never have to turn.
I rubbed a lot in the front and never in the back when I was lowered on TEIN S-Techs (1.8" drop)... but then I swapped those springs out for the J's Racing/Showa suspension (1.0" drop) and i rub a little in the back with passengers.
  #37 (permalink)
Old 01-26-2009, 07:18 PM
BoriJDMGD3's Avatar
Ihh IS Jaaaarome!
i do cornering too, and i have 195/50/15 and still no rub ... and im sure my car is lower than 1.8 drop, on lowering springs.
__________________
KillerFit #6
  #38 (permalink)
Old 01-26-2009, 07:23 PM
YeeFit's Avatar
well that's a bit of a discrepancy then isn't it?!? lol.. perhaps the 50 series over the 55 series makes a difference as that is the only thing that I can see that would prevent rubbing.
So you are saying that +35mm w/50 series won't rub. But if you go 55 series with +41 you will since that is what I have.
  #39 (permalink)
Old 01-26-2009, 07:36 PM
BoriJDMGD3's Avatar
Ihh IS Jaaaarome!
it rubs but is not a big deal, is like Ray says. only rub the fender liners... and i dont have my fenders roll. and if it rubs is when you take bump or somthing, but i been taking pretty big bumps and still no rub lol...
__________________
KillerFit #6
  #40 (permalink)
Old 01-26-2009, 07:44 PM
FitFlowjoe relies on Rep Points to liveFitFlowjoe relies on Rep Points to liveFitFlowjoe relies on Rep Points to liveFitFlowjoe relies on Rep Points to liveFitFlowjoe relies on Rep Points to liveFitFlowjoe relies on Rep Points to liveFitFlowjoe relies on Rep Points to liveFitFlowjoe relies on Rep Points to liveFitFlowjoe relies on Rep Points to liveFitFlowjoe relies on Rep Points to liveFitFlowjoe relies on Rep Points to live
I'm running 15" Black Rpf1's w/ 41 offset with 195/55 Direzza Z1 Star Specs.. and I rub alittle in the front, but once the fender clips fell off, no more rubbing.. And I do Auto-X.
I'm using Tanabe's GF-210 but soon to go Skunk2 Coilovers and camber bolts. And I want to use 205/50 in the front.. well see what happens there
Reply
Tags
15, 32, 35, 35mm, 41, crv, enkei, fit, fitfreak, gold, honda, mm, offset, offsets, rpf1, wheels
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
The OFFICIAL Fit Shoes Thead! (Lug Nuts Included!) Illusive Fit Shoes 83 Yesterday 01:31 PM
Enkei RPF1 wheel cap question Chitownfit Fit Shoes 1 06-26-2008 10:28 PM
FS!! Enkei RPF1 - 17x7 4x100, 43offset!!!!!!!!!!!!!!!!! Prefer Socal Pickup hotkamote For Sale / Want To Buy / Classified Ads for USED Fit Items 21 05-20-2008 04:05 AM
Enkei RPF1 - Who sells them? cessna Fit Shoes 5 05-05-2008 11:36 AM
Enkei RPF1 for street use? YeeFit Fit Shoes 7 06-02-2007 09:17 AM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
