Quote:
Originally Posted by VBP08GD3
so it wouldnt work?
No, they won't work. Forget adapters, bad stuff.
Get wheels, max 7"rim width, 42 to 55 mm offset with hub bores that fit the Fit hub. (something like 64 mm) and wheel discs that clear the calipers. (wheel disc is the area between the hub with the bolt-on holes and the rim)
The 4 bolt holes need to be on a 100 mm circle (bolt circle or BC) and the bolt hole seats match your Honda lubuts or get a set with your new wheels that fit them.
PS 100 mm is NOT 4' and if you try to make them work you have a high risk of breaking the studs and losing a wheel.
