Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Shoes
Fit Shoes
Discuss Wheels & Tires for the Fit and Jazz
Forum Sponsor: Tire Rack
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #241 (permalink)
Old 10-24-2009, 11:00 PM
bandanab is an unknown quantity at this point
Can i use a 175/65-15 snow tire on 07 sport wheels? The stock tire is 195/55/15
thx B
  #242 (permalink)
Old 10-25-2009, 09:04 AM
mahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to live
Quote:
thx B
Certainly if you're not dropped. 17565x15's are about a half-inch taller than the stock 195/55x15's but still cllear the fender wells unless you're dropped or carry a couple of heavyweights in the back seat.
They have a couple of advantahges
1. narrower tire cuts thru now much easier and has more pressure on the contact surface to grab better because of smaller contact area on the road.
2. larger diameter rolls over snow in front easier and therefore make better headway.
3. taller tire also increases road clearance a little (1/4") but every little bit helps passing over snow.
Ok I counted 4 too.
good luck.
  #243 (permalink)
Old 10-25-2009, 03:54 PM
Mahout
I will have about 150 pound machine in the trunk. But one bit of info that I left out is that i am going to put the 07 sport wheels on my 09 fit sport with stock suspension.
thx for your help
B
  #244 (permalink)
Old 10-25-2009, 07:44 PM
Mahout
thx for your help
B
Aha, Since the stock wheels on an 09 are 24.1" diameter you should be OK if you got away with carrying that 150 lb machine then without difficulty on the stock tires.
  #245 (permalink)
Old 10-26-2009, 09:18 AM
Platinum Honda FIT Vendor
jim@tirerack is on a distinguished road
The 175/65R15 is actually even better for the winter and they fit fine.
If I can help with the tires let me know.
__________________
Jim@tirerack.com
800-428-8355 ext 364
Performance Specialist
  #246 (permalink)
Old 10-27-2009, 08:46 PM
COTU's Avatar
COTU is an unknown quantity at this point
My 14s fit my 09
2000 Honda Civic wheels. 14 inch of course. They fit, but it is close. They are also hubcentric correct. I will be using these for snow tires. This is an initial fitment and in no way means 14s will fit any other 09 Fit. But, if you're wanting to try, the Honda Civic rims are a good choice.
__________________
09 Fit AT sport
90 Mustang LX 5.0 convertible
92 FJ1200
2000 Mustang GT
  #247 (permalink)
Old 10-28-2009, 07:00 AM
Jodele's Avatar
Jodele relies on Rep Points to liveJodele relies on Rep Points to liveJodele relies on Rep Points to liveJodele relies on Rep Points to liveJodele relies on Rep Points to liveJodele relies on Rep Points to liveJodele relies on Rep Points to liveJodele relies on Rep Points to liveJodele relies on Rep Points to liveJodele relies on Rep Points to liveJodele relies on Rep Points to live
Send a message via Skype™ to Jodele
Now your speedometer will read 40 when you are actually doing 30...at least you'll think you're going fast...
__________________
A man's mind, once stretched by a new idea, never regains its original dimensions. [Oliver Wendell Holmes]
  #248 (permalink)
Old 10-28-2009, 10:44 AM
COTU's Avatar
Quote:
No, a 185/70R14 has the same outer diameter as a 185/55R16. Speedo will read the same.
__________________
09 Fit AT sport
92 FJ1200
2000 Mustang GT
  #249 (permalink)
Old 10-28-2009, 03:42 PM
Jodele's Avatar
OK, I’ve exaggerated the mileage…but it will be off BECAUSE a 70% tire is taller and will compress more than a 55% tire to the point that your effective rolling diameter will be smaller. Sooo...YES!
__________________
  #250 (permalink)
Old 10-28-2009, 06:48 PM
COTU's Avatar
Effective rolling diameter, of a radial tire? Do you also think that setting a tire to 32psi prior to installing the wheel on the vehicle will result in a higher pressure when you sit the vehicle down on the tire? You're not helping yourself when it comes to being knowledgeable about tires
__________________
09 Fit AT sport
92 FJ1200
2000 Mustang GT
  #251 (permalink)
Old 10-28-2009, 07:47 PM
Jodele's Avatar
Just about all tires make these days are radial…even truck tires radial plied…some old truck tires are still bias plied and earth-moving equipment still use bias plied tires…so, moot point.
Now your second statement also does not make any sense either…you’re implying that you remove your snow tires to check the pressure????
And thirdly, I’m not trying to help myself…this is for the sake of everybody else here on this forum. If you want a little tire theory, all you have to do is ask…
__________________
  #252 (permalink)
Old 10-29-2009, 10:44 AM
COTU's Avatar
SOME Drag tires, trailer tires, "new" off road tires, ATV tires, motorcycle tires, and etc are bias tires. My point is not moot, the characteristic you were giving, "Effective rolling diameter", is more along the lines of a Bias tire and that is why I made the point. Bias tires can grow or shrink with a change in pressure or load. Radial tires by construction, from my research, resist changes in circumference due to pressure or load changes. It is the circumference, not compressed diameter, that determines the distance traveled per one revolution of a tire (and thus, speedo readings). Circumference is not directly related to the compressed diameter of a loaded tire. Tire construction and properties are just not that simple. Radial tires maintain a pretty consistent circumference regardless of normal pressures and loads. Your previous statement about 55 and 70 series sidewalls is incorrect. Then again, I COULD be wrong, but I'm not the one offering tire theory for the sake of helping people. If you are trying to help people, at least make sure your info is correct. I would say we're getting off topic, but most people do by a snow tire that is narrower or a smaller diameter wheel, and is therefore a different series tire. So, it is relative to the topic.
__________________
09 Fit AT sport
92 FJ1200
2000 Mustang GT
  #253 (permalink)
Old 10-29-2009, 11:05 AM
The 185/70R14 tire is within 2/10" of the OE Fit tires. It is not going to throw off the speedometer more than maybe 1 mile per hour at 55 mph. I will say that we do not show the 14" clearig and working on the 09 Fit. We only list up to 15" but if you get them to clear they do have enough load capacity so you are fine.
I am not really sure where all of the bias versus radial tire thing is going.
__________________
Jim@tirerack.com
Reply
Tags
15x5, 2006, boston, driving, fit, fits, handling, honda, michelin, performance, snow, tire, tires, wheel, winter
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fit and winter driving? scanner General Fit Talk 12 09-22-2008 11:28 PM
Winter Driving frogpond1 Other Car Related Discussions 10 09-22-2008 07:05 PM
Winter driving Muggaphone Tire, Wheel, Brake & Suspension Forum sponsored by The Tire Rack 5 12-14-2007 02:26 PM
Winter driving Muggaphone European Fit Forums & Clubs 1 08-21-2006 01:42 AM
winter driving with the fit? Wu-Zi General Fit Talk 2 05-01-2006 11:13 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
