Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Suspension & Brake Modifications
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #681 (permalink)
Old 10-17-2008, 10:19 AM
Zangoose GD3 Blue's Avatar
Zangoose GD3 Blue relies on Rep Points to liveZangoose GD3 Blue relies on Rep Points to liveZangoose GD3 Blue relies on Rep Points to liveZangoose GD3 Blue relies on Rep Points to liveZangoose GD3 Blue relies on Rep Points to liveZangoose GD3 Blue relies on Rep Points to liveZangoose GD3 Blue relies on Rep Points to liveZangoose GD3 Blue relies on Rep Points to liveZangoose GD3 Blue relies on Rep Points to liveZangoose GD3 Blue relies on Rep Points to liveZangoose GD3 Blue relies on Rep Points to live
Send a message via AIM to Zangoose GD3 Blue
Quote:
Originally Posted by NIGHTHAWKSI View Post
the day i installed them i coated both the rubber bushings in silicon spray, as well as the perch so that i would have alittle play to slide the spring off of the bolt heads before i placed the entire cars wieght on the spring. that had no results.
i have since fixed my problem and went ot home depot and got some 18-8 grade bolts that looked like the ones in the panducky kit and installed them. problem solved.
but i am still going to try and get in touch with progressive to inform them they should sell their kits with updated hardware.
well to further prove my point, yes, this is another person who feels the design isnt the best. might not have said it in those words, but you need to get into a readin comprehension class if you cant figure that out.
alright, we all get it. you enjoy buying parts that are flawed and like to live with them. i expect quality when i buy from a quality company. **** off if you dont have any constructive input.
Ian did it work properly... if it did i might get another set from home depot then
__________________
07 Honda Fit sport 5Speed M/T aka WARTURTLE
SLW FTW
Mods Installed--> Suspension completed ( track ready)/ Engine 70% done/ Comestic ( well who cares lol )
Now: Building Custom Turbo 60% completed....
  #682 (permalink)
Old 10-17-2008, 10:34 AM
NIGHTHAWKSI relies on Rep Points to liveNIGHTHAWKSI relies on Rep Points to liveNIGHTHAWKSI relies on Rep Points to liveNIGHTHAWKSI relies on Rep Points to liveNIGHTHAWKSI relies on Rep Points to liveNIGHTHAWKSI relies on Rep Points to liveNIGHTHAWKSI relies on Rep Points to liveNIGHTHAWKSI relies on Rep Points to liveNIGHTHAWKSI relies on Rep Points to liveNIGHTHAWKSI relies on Rep Points to liveNIGHTHAWKSI relies on Rep Points to live
Quote:
yea. ive got alot of extra washers for you if you want them.
bolts were $2.50/pair and loctite nuts were $.98/pair
they didnt stock much metric, so i got standard sizes. i think the thread size was 5/16"x10 and the bolt head looks just liek teh panducky hardware, except polished rather than black. the head of the bolt and nut were slightly narrower than the hardware supplied with the sway bar, but a washer at both the head and nut (rather than just the nut) solved the problem. no squeaking anymore.
__________________
RIMS FS:
http://www.fitfreak.net/forums/sale-...tml#post772926
HID FX45 retrofit/JDM LED tail lights/JDM sunvisor/JDM red H's/AVIC-D3 navigation/Alpine type s/ MTX amp/MUGEN visors/Progress lowering springs/WORK CrKai 15x7 +44/Kics r40 neochrome lugs/RAYS valve stems/Aspec intake/Password JDM CF engine cover/Skunk2 short shifter/ARC shift knob/JDM yellow fog lights/Progress rear sway bar/fujitsubo cat-back
  #683 (permalink)
Old 10-17-2008, 10:44 AM
Thumbs up
i might have to take a ride with you to home depot then....
__________________
SLW FTW
  #684 (permalink)
Old 10-17-2008, 10:53 AM
manxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to live
I offered plenty of constructive advice, but you were too interested in complaining to follow them. BTW, there is no "18-8 grade"- to meet DOT safety standards, automotive fasteners have to be Grade 8 which denotes hardness, temper, and structural strength. Your 18-8 merely means that the bolts are stainless steel, which are not Grade 8, and can be soft enough to bend or brittle enough to break.
Get Grade 8. There y'go. more constructive advice for you to ignore, and waste more time complaining about.
  #685 (permalink)
Old 10-17-2008, 11:14 AM
please go back and quote your advice that you gave me. somthing more than "other people found a solution", or "use bolts as a spacer to lift the spring off the perch"...because that is garbage advice.
im suprised that some one who would offer a dangerous solution such as that, would know or give a shit about DOT standards...but im happy you know somthing. IMO, im not as concerned that each bolt is grade 8 becuase i dont think there is enough stress on the sway bar to warrent that much bolt strength.
thank you for finally having some accurate information.
__________________
RIMS FS:
  #686 (permalink)
Old 10-17-2008, 11:18 AM
"..............and waste more time complaining about". How does a six year old like you own a Fit?
Please explain how using bolt heads as spacers to level the bottom of the springs, with the entire weight of the rear of the car on the spacers, is in any way dangerous. Apparently you don't know that the springs can't come out of the perches, regardless of what's under them, unless you lift the car and unfasten the shocks. Exactly how is that going to happen on the road?
Children think that complaining about a problem is the solution, because mommy and daddy make it all better. More advice- grow up.
  #687 (permalink)
Old 10-17-2008, 11:50 AM
i guess cause im more of a sucessful 6 your old then you ever were? i dont know...just guessing here.
i have never seen a car that the spring didnt sit on a full level surface, and im sure its like that for a reason. so, yes i know that the spring cannot just pop out, but at the same time, i feel it shoud be fully supported form underneath.
im dont bickering with you as i have since found the problem, solved the problem, and contacted progress about the issue. when progress gets in touch with me and hopefully the issue on their end rather than forcing the consumer to fix the design flaw, i will post up the emails. im sure some consumer will apprecaite that some one here took the initaitive to solve the issue at the source rather than have to fix the manufacturers problem themselves.
i dont know what your trying to prove by throwing insults out. i ask for advice, you cannot provide reasonable solution, so you rather insult?....and you have the audacity call me a 6yr old? please grow up. i dont hold conversations with people that need to stoop to a childish level to make themselves feel they are correct.
thank you and have a nice day.
__________________
RIMS FS:
  #688 (permalink)
Old 11-09-2008, 11:43 PM
sl0wp0k3 relies on Rep Points to livesl0wp0k3 relies on Rep Points to livesl0wp0k3 relies on Rep Points to livesl0wp0k3 relies on Rep Points to livesl0wp0k3 relies on Rep Points to livesl0wp0k3 relies on Rep Points to livesl0wp0k3 relies on Rep Points to livesl0wp0k3 relies on Rep Points to livesl0wp0k3 relies on Rep Points to livesl0wp0k3 relies on Rep Points to livesl0wp0k3 relies on Rep Points to live
anyone have long term problems with the sway bar?
only reason i ask is because the spring is sitting lopsided after install.
__________________
guess what?!? my Fit is USDM!! and STOCK!
  #689 (permalink)
Old 11-10-2008, 02:06 PM
NewEdgePerf is on a distinguished road
Check your spring orientation
On some brand of springs, you can set the spring in the pocket so it does not sit on the rear sway bar bolt heads. You may be able to do the same...just rotate the springs in the pocket ( jack it up to take the load of the spring and you may have to take the shock loose to do so).
I hope this helps.
Tony D
__________________
www.newedgeperformance.com.
  #690 (permalink)
Old 04-20-2009, 12:53 AM
DrKelso's Avatar
DrKelso relies on Rep Points to liveDrKelso relies on Rep Points to liveDrKelso relies on Rep Points to liveDrKelso relies on Rep Points to liveDrKelso relies on Rep Points to liveDrKelso relies on Rep Points to liveDrKelso relies on Rep Points to liveDrKelso relies on Rep Points to liveDrKelso relies on Rep Points to liveDrKelso relies on Rep Points to liveDrKelso relies on Rep Points to live
Ok. After reading through about 3 pages of this thread, I'm tired and don't feel like going onward lol.
Can anyone tell me what size the holes on the lower spring perch are? The holes on my bar measured at 1/2" but the holes on the perch are smaller. I thought about drilling out the holes on the perch to 1/2" but I'd like to avoid that.
Also, is there any kind of sleeve/adapter that I can slide over the bolt once it is through the spring perch to make it increase in diameter up to 1/2"? I'd like everything to be as snug as possible.
Thanks
__________________
WTB: NHBP Sideskirts/Rear lip.
  #691 (permalink)
Old 05-05-2009, 10:07 AM
docjim2's Avatar
docjim2 is on a distinguished road
Quote:
Originally Posted by jits14 View Post
It would be more effective if mounted to a Fit with the c-pillar to tower crossbar or a rollcage. I could see Ben's fit oversteering with the sway bar because there is too much structural flex happening above the chassis to kind of counteract the extra ridgid subframe with the rear axle and swaybar causing too much oversteer.
The forward momentum of the upper half of the hatch continues to move when the lower frame has improved tracking. Without any reinforcement to the upper half connecting to the lower frame of the car, the top back of the car is more or less disconnected to the lower rear causing the abrupt oversteer.
I am not sure what ben has for bracing in the rear, but this is just speculation and I would think it would only benifit with rollcage type reinforcement. Swaybars Rock!
I have my Fit braced front-back-up and down! Then do I actually need a rear antisway bar? The car rides kinda harsh now; I guess the 17's contribute to that. You know I actually use this car for car pooling! And my passengers do get lulled off when going home so I guess the ride isn't that harsh?!
But no lowering since the tyres now look great and fill in the visual thing in the wheel wells.
__________________
2000 Accord Coupe v6
Eibach Sport springs; Eibach camber kits; custom cat back; Honda 17in wheels w 225 45 X 17 Toyo P4's; AEM short ram ; Pass 8500 X50 radar
2007 Fit Base Vivid Blue Pearl AT
17 ASA painted black w machine lip; 205-40X17 Fusion tires; iWay GPS 350c; Zeta sills; Mugen viser ; Cobra radar; blue accent shift knob ; tonneau cover, Zeta"dead pedal"; Megan racing cat back; Tanabe tower bar braces; pillar brace. K&N OEM filter
Please turn your head when you cough...
  #692 (permalink)
Old 05-07-2009, 01:18 AM
Koi Koi is offline
Koi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to live
I could so go for some cadaver screaming jewelry. That shit is bitchin
  #693 (permalink)
Old 05-08-2009, 12:48 AM
DrKelso's Avatar
Does anyone know what size bolts are needed to install the rear sway bar?
The holes on the bar are 1/2" but the holes on the rear lower spring perch are smaller.
Anyone? Bueller?
__________________
  #694 (permalink)
Old 05-08-2009, 11:19 PM
fit-aficionado's Avatar
fit-aficionado relies on Rep Points to livefit-aficionado relies on Rep Points to livefit-aficionado relies on Rep Points to livefit-aficionado relies on Rep Points to livefit-aficionado relies on Rep Points to livefit-aficionado relies on Rep Points to livefit-aficionado relies on Rep Points to livefit-aficionado relies on Rep Points to livefit-aficionado relies on Rep Points to livefit-aficionado relies on Rep Points to livefit-aficionado relies on Rep Points to live
After reading on this thread, I have to agree with NIGHTHAWKSI..the bolts from Progress should not interfere whatsoever with the functioning of other parts in the car, specially the springs. The springs should seat without any problems, this is a bad design from Progress and/or they obviously missed it. I have owned Progress RSBs before on both two previous generation Civics and never had a problem; the bars worked great. I do like Progress, but this bar and its hardware DO have a design flaw that needs to be fixed.
  #695 (permalink)
Old 05-09-2009, 12:02 AM
So what do you expect, that ppl only buy Progress springs? If you release an aftermarket product, it should work with the parts around it that serve a common purporse, not interfere with their function.
  #696 (permalink)
Old 05-09-2009, 03:04 AM
macbuddy's Avatar
macbuddy relies on Rep Points to livemacbuddy relies on Rep Points to livemacbuddy relies on Rep Points to livemacbuddy relies on Rep Points to livemacbuddy relies on Rep Points to livemacbuddy relies on Rep Points to livemacbuddy relies on Rep Points to livemacbuddy relies on Rep Points to livemacbuddy relies on Rep Points to livemacbuddy relies on Rep Points to livemacbuddy relies on Rep Points to live
The RSB works for me...
For the record, the Progress RSB works perfectly with the Megan Coilovers. No unwanted side effects have surfaced since install.
-macbuddy-
  #697 (permalink)
Old 05-09-2009, 05:13 PM
redrumm's Avatar
redrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to live
Quote:
-macbuddy-
im running mine with panducky bolts. If you need panducky style bolts i can get them.
__________________
ORDER 3 OR MORE BARS GET FREE SHIPPING!!!!
FOR YOUR GD3/GE8......http://ultraracingusa.com/
EMAIL: ultragd3@yahoo.com
mbarton@ultraracingusa.com
  #698 (permalink)
Old 05-09-2009, 05:17 PM
solbrothers's Avatar
solbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to live
Send a message via AIM to solbrothers
i switched out the hardware for some low profile allenhead bolts.
__________________
-matt
Quote:
Originally Posted by keepitpg View Post
cant disagree with solbrothers
  #699 (permalink)
Old 05-09-2009, 05:19 PM
Quote:
unless you weld the bar to the rear suspension beam, there really isnt a way to mount it without interference from SOME aftermarket springs.
also, i dont have any issues with my skunk2 coilovers and rubbing noises
__________________
-matt
  #700 (permalink)
Old 05-09-2009, 06:39 PM
Quote:
I'd rather do this than weld the bar to the car..let me know how I can get some of these bolts from you. I did some research and appearently Panducky closed.
Reply
Tags
06, anti, antisway, bar, bars, diy, fit, honda, instal, install, pics, progress, rear, scion, sway, xb
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Progress Rear Sway Bar Or Wr Cage Set jman245 Fit Suspension & Brake Modifications 14 02-05-2008 11:29 PM
24mm front sway bar w/ Progress rear ldweng Fit Suspension & Brake Modifications 7 10-08-2007 04:41 AM
BLOX Rear Anti Sway Bar 24mm JamesBizzle Fit Suspension & Brake Modifications 10 08-09-2007 03:05 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
