Fit Suspension & Brake ModificationsThreads discussing suspension and brake related modifications for the Honda Fit
Welcome to Fit Freak!
Welcome to Fit Freak,
arent the OEM camber bolts just made skinnier in diameter so theres more play in the strut so you can move it around til you get the camber just right?
They are exactly the same size as the stock one on the car. Usually a camber bolt will have a small hump right above the threads so when you rotate the bolt it will move the hub for +/- camber.
__________________
2006 Suzuki GSX-R 600 White/Silver - Street Bike -
2006 Suzuki GSX-R 600 Black - Track Tool -
2008 Nissan Titan - Toy Hauler -
I'd like to know as well... but seeing as how i just got an alignment, i dont see any point in dumping another 20-30 bucks into bolts then another 50 on the alignment for another -.5 - -1 degree more camber
David
__________________
I'm sure if you could find someone to sorce the JDM front strut mount bolts & nuts ...since they are smaller in DIA. vice the USDM ones you could use them for setting more camber in the front...??? give me a day or two and I'll see if I can post the part # for you guys
__________________ 2009 FG2 Civic Si 2009 GE8 Fit Sport
Below is straight out of Honda's Interactive Network, the part# is probably correct but wrong part in the wrong package, happens all the time. I will check my service manual tomorrow and see what it says. If those bolts are not on your car, I would return them and just tell the parts deparment what happened, I'm positive they can verify that Honda made a mistake.
Then this happened twice because i bought 2 of them!
-David
__________________
i wanna get a the DFs but i got a JDM GD1, is there any difference between JDM and USDM tanabe springs? will there be fitment issues or will it be the same fitting for both JDM and USDM??
__________________
EVIL Prevails when GOOD MEN DO NOTHING
hi
is there any difference between JDM and USDM fitting for the Tanabe Lowering springs?? cos i wanna change from NF210 to DF210, i have a JDM 2004 Honda Jazz and im currently on my Tanabe NF from Japan,
will i have fitting issues if i get Tanabe USDM and put em on my JDM Jazz
__________________
i wander if i should get mine aligned since mine are dropped on skunk2
i would have to look at any alignment place or fine someone that does it for lowered vehicles
Some are just skinnier which would allow you to more the strut in/out to get more camber adj.
Some are "eccentrics" which would have the small-hump; so when you rotate it, it'll change cam/caster...
hey all, first post here. im getting my fit next week(BOM) and i cant wait. but im new to these forums and i dont really know where to get parts(i drove a scion tC before which got totaled). can someone please tell me where i can get the tanabe springs? both the GF and the DF?? thanks in advance.
planning on getting these for my ride when it comes in next week. but the only pics ive seen here are not on sport models. wanted to see how the front lip stood off the ground. pictures would be appreciated as well as feedback. thanks in advance.
