Yes Nissin is the manufacturer for honda's brake components.
To be honest, turbomanGT is correct, it's a LOT cheaper just to buy a pre-fabbed bolt-on kit from T1R or Fastbrakes.com then to try to build your own. Plus in the long run, you won't have any problems if you try to build your own kit. Remember, the brakes are what slow u down and u DO NOT want to try and fab-up something that's going 2 stop your car from 80mph. These companies that have conversion kits out have tested it numerous times before putting it out on the market, so they know that it's flawless.
Oh and BTW the T1R and fastbrakes.com both use OEM Nissin calibers with their kits so finding replacemnt pads or even rotors are easy 2 find.
__________________
AIM: koolkev1107
