Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Suspension & Brake Modifications
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 07-11-2009, 06:18 AM
Jazz GD3's Avatar
Jazz GD3 relies on Rep Points to liveJazz GD3 relies on Rep Points to liveJazz GD3 relies on Rep Points to liveJazz GD3 relies on Rep Points to liveJazz GD3 relies on Rep Points to liveJazz GD3 relies on Rep Points to liveJazz GD3 relies on Rep Points to liveJazz GD3 relies on Rep Points to liveJazz GD3 relies on Rep Points to liveJazz GD3 relies on Rep Points to liveJazz GD3 relies on Rep Points to live
Thumbs up Ingalls Camber Kit Review
I just got the Ingalls front camber kit installed yesterday. I also got the car aligned (the toe was way messed up), while at it, and set the camber to -1.3 to -1.4 negative up front, and the rear was measured to be -1.25 negative. I told the place to just set it the front so it was close or more then the rear by a little bit. I told them this because my rear was having very little to no camber wear.
The things I have done to the car already in suspension,
Tanabe DF210's, and a Progress Rear Sway Bar, on 17" wheels with Toyo Proxes 205/45.
(But this is short to just review getting a camber kit installed, having the camber setting right for you, and emphasizing that you really should get a alignment after lowering.)
Performance - I think from the need of camber itself, but prob from the kit I guess.
OK, the car literally does not understeer at all anymore. It oversteered today though. When having fun, I usually accel through the turns. Every corner makes you confident you can step on the gas. I havent heard a screech from my Toyo Proxes after the install, even when it oversteered,
...like on a big circle offramp.
The touge and slalom... like on Azusa Canyon Roads were very stable compared to previous encounters.
Going on freeway or without holding the wheel, it kept straight for a long long time, even if the road was slanted, it took a while to go over. The steering response is heavier!
Its one of the most basic ideas or things you should be able to if you want good handling, youd dial in a the right toe, the camber you want, and have a good set of tires, in addition to shocks/springs/or coilovers. (At least it was easy to set up the suspension the way you want it in the old cars, now everything is unadjustable unless you buy some kit...)
Quality of Product
The camber bolts were great quality. Heavy Black Steel, compared to the stock ones they replace. The alignment said that it has up to 2+- degrees in setting although we did not have to use that tab washer. They said it was for another application?
I love the way it handles and it handles more similar to my other car thanks to this camber kit. Hopefully it can corner as well as my other car soon.
If anyone is was like me, who had a lowered car, with a great set of grippy wheels for their suspension (and prob a RSB), I would seriously recommend you to get this kit and set up some good camber!
__________________
Lovers In Japan
Sponsored Links
  #2 (permalink)
Old 07-11-2009, 02:08 PM
BlueCell's Avatar
BlueCell relies on Rep Points to liveBlueCell relies on Rep Points to liveBlueCell relies on Rep Points to liveBlueCell relies on Rep Points to liveBlueCell relies on Rep Points to liveBlueCell relies on Rep Points to liveBlueCell relies on Rep Points to liveBlueCell relies on Rep Points to liveBlueCell relies on Rep Points to liveBlueCell relies on Rep Points to liveBlueCell relies on Rep Points to live
Awesome! I'm about to get me some of these.
__________________
My Photo Thread
My Flickr
www.Team16NiSs.org
Quote:
Originally Posted by C-Fit View Post
About time you got rid of those HFP's!!
  #3 (permalink)
Old 07-11-2009, 04:07 PM
FITGD3 is just really niceFITGD3 is just really niceFITGD3 is just really niceFITGD3 is just really niceFITGD3 is just really nice
no more understeer by installing the camber bolts?thats impossible.
camber bolts make your ride more stable during the corner(more grip).
However I dont feel any difference by fitting camber bolts for FIT.
Reply
Tags
alignment, bolt, bolts, camber, fit, forum, forums, good, honda, ingalls, install, installation, installing, kit, review
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Tanabe Gf210s photos, questions, answers photofit77 Fit Suspension & Brake Modifications 223 08-29-2009 07:00 PM
Suspension Theory cojaro Fit Suspension & Brake Modifications 29 02-05-2009 08:02 PM
Ingalls Stiffy vs Spoon engine torque damper suketoborudo00 Fit Engine Modifications, Motor Swaps, ECU Tuning 11 12-26-2008 01:26 PM
Fit review on CNET - they get fooled by trip computer! DZeckhausen 2nd Generation (GE 08-present) 1 10-26-2008 12:22 PM
FIT Yahoo Autos Reviews alclssus2020 General Fit Talk 43 07-12-2007 04:07 AM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
