Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Suspension & Brake Modifications
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 07-20-2009, 11:52 AM
diedwater has a spectacular aura aboutdiedwater has a spectacular aura about
camber, rain...
well...I just put on the spc camber bolts this weekend, set it to the max. put on a set of new wheels (15 x 7 - 40)
this morning, it was raining outside, got on the high way, man....I couldn't even keep the car straight at 45....the bump steer is horrible, and the car just seem to have lost soo much traction....
so I just want to know if this is normal...as I don't have much experience in this department...
the traction isn't bad on dry surface, but bump steer certainly has gotten worse.
Car is lowred on skunk2 springs.
EDIT:
sorry forgot to specify that I push the SPC bolts to max Negative camber to fix the front rubbing.
Sponsored Links
  #2 (permalink)
Old 07-20-2009, 12:07 PM
dewthedew's Avatar
Fit Moderator
dewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to live
Send a message via AIM to dewthedew
did you even get an alignment???
  #3 (permalink)
Old 07-20-2009, 12:43 PM
i had an alignment after lowering, but with the camber bolts, I just pushed both to max so I didnt think it needed alignment...
  #4 (permalink)
Old 07-20-2009, 01:02 PM
kenchan relies on Rep Points to livekenchan relies on Rep Points to livekenchan relies on Rep Points to livekenchan relies on Rep Points to livekenchan relies on Rep Points to livekenchan relies on Rep Points to livekenchan relies on Rep Points to livekenchan relies on Rep Points to livekenchan relies on Rep Points to livekenchan relies on Rep Points to livekenchan relies on Rep Points to live
wat do you mean by pushed to max? max which way? neg?
__________________
08 FitSport (5MT) Storm Silver - My modded dd
09 FitSport (AT) Taffeta White - My stock GE8 as her dd
04 G35Coupe (6MT) Silver - My modded weekend touring car.
09 370Z (6MT) Silver - My weekend sports car.
Post your questions in my Fit Blog
  #5 (permalink)
Old 07-20-2009, 01:07 PM
FitFlowjoe relies on Rep Points to liveFitFlowjoe relies on Rep Points to liveFitFlowjoe relies on Rep Points to liveFitFlowjoe relies on Rep Points to liveFitFlowjoe relies on Rep Points to liveFitFlowjoe relies on Rep Points to liveFitFlowjoe relies on Rep Points to liveFitFlowjoe relies on Rep Points to liveFitFlowjoe relies on Rep Points to liveFitFlowjoe relies on Rep Points to liveFitFlowjoe relies on Rep Points to live
U need to make sure you have the alignment checked... Seems to me your front toe might be off.
  #6 (permalink)
Yup, Neg....sorry, I forgot to specify.
  #7 (permalink)
Old 07-20-2009, 03:32 PM
yah, not sure how much neg your bolt provides but if it's more than -2 you will have issues with straightline grip in the wet.
i would get that car aligned run no more than -1.8 for street use. you can do like -2.2 at the track by that's too much for street imho.
__________________
  #8 (permalink)
Old 07-20-2009, 03:49 PM
tanukifit's Avatar
tanukifit relies on Rep Points to livetanukifit relies on Rep Points to livetanukifit relies on Rep Points to livetanukifit relies on Rep Points to livetanukifit relies on Rep Points to livetanukifit relies on Rep Points to livetanukifit relies on Rep Points to livetanukifit relies on Rep Points to livetanukifit relies on Rep Points to livetanukifit relies on Rep Points to livetanukifit relies on Rep Points to live
Yeah, get it aligned after I put in my bolts and added neg camber the toe was really bad causing the tires to slip and slide in the rain. With 0 to .05 toe out and -2.0 - -2.5 camber it rides straight and bump steer virtually eliminated.
  #9 (permalink)
Old 07-20-2009, 06:46 PM
thanks a lot for the help guys, I'll go get it aligned, see if that helps
  #10 (permalink)
Old 07-20-2009, 06:53 PM
yah, you only need the 2 wheel alignment since the rear is fixed... dont waste your money at the dealer getting a 4wheel alignment. lol
__________________
  #11 (permalink)
Old 07-20-2009, 07:00 PM
tanukifit's Avatar
Quote:
Yeah, the crappy thing is most will consider this a custom align so they'll charge extra. If they do say it's more for custom alignment ask em if they can align it with you in the car as it changes when you jump in the car.
  #12 (permalink)
Old 07-20-2009, 10:30 PM
So I took my car in to get it aligned, I tried my luck by asking to pay half cuz I only need 2 wheel alignment, but they wouldn't do it, so I was like ok...and then they were like, wait you lowered you car? we need to charge more, and i was like WTF? all I need is toe correction, leave everything else. so after a fit, they went ahead and did it. But guess what, after telling them over and over and over and over and over...not to change the camber, then went ahead and correct the camber as well....needless to say, they have to do everything all over again.
but after everything is done, the problem is gone! car handled 200% better!!!
my front toe was way off...
again, thanks for all the help guys! I really appreciated it.
Reply
Tags
camber, fit, honda, rain
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
09 aftermarket wheels CAUTION mahout 2nd Generation GE8 Specific Wheel & Tire Sub-Forum 382 11-23-2009 04:07 AM
Tanabe Gf210s photos, questions, answers photofit77 Fit Suspension & Brake Modifications 223 08-29-2009 07:00 PM
SPC camber bolt / shim help !! FELIXY69 Fit Suspension & Brake Modifications 10 07-21-2009 11:38 AM
Ingalls Camber Kit Review Jazz GD3 Fit Suspension & Brake Modifications 2 07-11-2009 04:07 PM
Suspension Theory cojaro Fit Suspension & Brake Modifications 29 02-05-2009 08:02 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
