Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Suspension & Brake Modifications
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 08-25-2009, 09:33 AM
die_lawn's Avatar
die_lawn relies on Rep Points to livedie_lawn relies on Rep Points to livedie_lawn relies on Rep Points to livedie_lawn relies on Rep Points to livedie_lawn relies on Rep Points to livedie_lawn relies on Rep Points to livedie_lawn relies on Rep Points to livedie_lawn relies on Rep Points to livedie_lawn relies on Rep Points to livedie_lawn relies on Rep Points to livedie_lawn relies on Rep Points to live
rear camber kit?
i've been looking online and all i can find is shims for the rear. is this what everyone else is using? also if you have one, what site did you get it off of, can you please post a link, thanks!
__________________
RIP BCH-FIT 5/1/09-9/11/09
Sponsored Links
  #2 (permalink)
Old 08-25-2009, 01:50 PM
MiniMiniVan is an unknown quantity at this point
I sure hope they make something for GE's. I'm looking to drop mine on D2 coilovers along with a 16" rim with somewhat of a wicked offset. Definately wanna be HellaFlush.
  #3 (permalink)
Old 08-25-2009, 10:47 PM
die_lawn's Avatar
oh yeah by the way, this is for a GD
__________________
  #4 (permalink)
Old 08-25-2009, 11:06 PM
Daemione relies on Rep Points to liveDaemione relies on Rep Points to liveDaemione relies on Rep Points to liveDaemione relies on Rep Points to liveDaemione relies on Rep Points to liveDaemione relies on Rep Points to liveDaemione relies on Rep Points to liveDaemione relies on Rep Points to liveDaemione relies on Rep Points to liveDaemione relies on Rep Points to liveDaemione relies on Rep Points to live
Unless you actually machine the spindle or torsion beam mating surface, shims are the only way to adjust the rear alignment.
If you get some, order new spindle nuts & hub caps while you're at it - you'll need to replace them when you do the job.
  #5 (permalink)
Old 08-25-2009, 11:32 PM
solbrothers's Avatar
solbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to live
Send a message via AIM to solbrothers
ok. anyone have an online how-to on this? i plan on adding some negative camber to my yazz this weekend
__________________
-matt
Quote:
Originally Posted by keepitpg View Post
cant disagree with solbrothers
  #6 (permalink)
Old 08-26-2009, 03:59 AM
die_lawn's Avatar
damn that sounds like more wotk then it needs to be haha
__________________
  #7 (permalink)
Old 08-26-2009, 01:08 PM
Mr08FiT's Avatar
Mr08FiT relies on Rep Points to liveMr08FiT relies on Rep Points to liveMr08FiT relies on Rep Points to liveMr08FiT relies on Rep Points to liveMr08FiT relies on Rep Points to liveMr08FiT relies on Rep Points to liveMr08FiT relies on Rep Points to liveMr08FiT relies on Rep Points to liveMr08FiT relies on Rep Points to liveMr08FiT relies on Rep Points to liveMr08FiT relies on Rep Points to live
Send a message via AIM to Mr08FiT
I would definately bring it to your alignment place for this to be done... Setting camber, with-out the right tools, is not necessarily a "In-Driveway" mod. IMO
__________________
  #8 (permalink)
Old 08-26-2009, 09:36 PM
Once you've had your alignment done and know what direction you want to go with the rear end, you can definitely do it on your own - the SPC shims come with a chart that let you dial in exactly the amount of toe & camber change as you need/want, up to 1.5 degrees in either direction. For example, I got mine aligned after I lowered it, and on my left side I'm looking to go -.8 degrees of toe and -.3 degrees of camber. The right side needs .4 degrees more positive toe, and I want another -.7 degrees camber. The goal being toe zeroed out as much as possible, and 2 degrees of negative camber on both sides.
I'm doing one corner of mine soon (tomorrow?), I'll take a few pictures as I go. But as long as you've got enough leverage (or a beefy impact wrench) to get the spindle nut off, it's a pretty straightforward job. I plan on an hour per side, tops - that's in my driveway with hand tools and jack stands.
  #9 (permalink)
Old 08-27-2009, 04:31 AM
die_lawn's Avatar
please make a DIY while you're doing this if you don't mind! haha it would help us alot
__________________
  #10 (permalink)
Old 08-30-2009, 11:38 PM
I started the job on Friday, wasn't able to finish though - there's a bolt that holds the spindle onto the axle that I wasn't able to remove with my current tools. Bought a better impact driver and 3 pound sledge, hopefully that'll do the trick - I can drill it out as a last resort.
Anyway, I probably won't get back to it until the end of the week, but I want to get the shims in before this weekend. I'm gonna put 1200 miles or so on the car over Labor Day weekend, and need to fix the rear toe before that happens.
  #11 (permalink)
Old 08-31-2009, 03:03 AM
Evotech8 relies on Rep Points to liveEvotech8 relies on Rep Points to liveEvotech8 relies on Rep Points to liveEvotech8 relies on Rep Points to liveEvotech8 relies on Rep Points to liveEvotech8 relies on Rep Points to liveEvotech8 relies on Rep Points to liveEvotech8 relies on Rep Points to liveEvotech8 relies on Rep Points to liveEvotech8 relies on Rep Points to liveEvotech8 relies on Rep Points to live
Do you know what size bolt that is? Its a Allen bolt/screw right?
Thx!
__________________
07' SSM Fit Sport 109 hp
Progress RSB, Skunk2 Pro-C's, DC Sports strut bar, T1R rear brake discs, 15" Konig Helium, H-Fit SS intake, Megan header (w/stock heat shield!)+axleback, Zenith HIDs.
04' Black EVO VIII 350 whp
  #12 (permalink)
Old 08-31-2009, 09:00 AM
Yup, a 6mm allen head. Mine stripped almost immediately, I used a dremel to put a big slot in it for a flathead screwdriver.
  #13 (permalink)
Old 08-31-2009, 10:08 AM
Mr08FiT's Avatar
Can you post any pictures of your progress or maybe a link to the shim kit you bought?
__________________
  #14 (permalink)
Old 08-31-2009, 01:36 PM
redrumm's Avatar
redrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to live
you can buy them on ebay. you can usually buy the SPC camber bolts/shims together
if you want to do the washer trick i can post that later.
__________________
ORDER 3 OR MORE BARS GET FREE SHIPPING!!!!
FOR YOUR GD3/GE8......http://ultraracingusa.com/
EMAIL: ultragd3@yahoo.com
mbarton@ultraracingusa.com
  #15 (permalink)
Old 08-31-2009, 03:46 PM
die_lawn's Avatar
haha yeah post the washer trick, i know lots of guys with older civics do that
__________________
  #16 (permalink)
Old 08-31-2009, 05:23 PM
Slipping in some washers is an okay way to just dump in negative camber for clearance purposes . . . but to do it right (and fix toe at the same time), washers aren't an easy solution.
It's the same amount of parts removal & replacement as putting in the SPC shims, but unless you've got a ready supply of washers in exact thicknesses, it's gonna take some precise grinding, measuring, and some trial and error to put your toe exactly where it should be.
Reply
Tags
2009, adjust, alignment, camber, degrees, fit, honda, how, in, kit, rear, skunk2, spindles, to, trick, washer
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
camber kit questions, alignment front and rear questions and specs bus stop Fit Suspension & Brake Modifications 245 10-08-2009 01:47 PM
DIY rear disc slowcarguy Fit Suspension & Brake Modifications 111 10-05-2009 04:56 PM
Modified 2010 Hyundai Genesis Coupes Sid 6.7 Other Car Related Discussions 82 04-30-2009 04:04 PM
Suspension Theory cojaro Fit Suspension & Brake Modifications 29 02-05-2009 08:02 PM
EUDM GE-08 vs EUDM GD-1 2007 F0NIX 2nd Generation (GE 08-present) 3 01-26-2009 12:46 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
