Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Suspension & Brake Modifications
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 09-02-2009, 10:48 PM
Kurse's Avatar
Kurse relies on Rep Points to liveKurse relies on Rep Points to liveKurse relies on Rep Points to liveKurse relies on Rep Points to liveKurse relies on Rep Points to liveKurse relies on Rep Points to liveKurse relies on Rep Points to liveKurse relies on Rep Points to liveKurse relies on Rep Points to liveKurse relies on Rep Points to liveKurse relies on Rep Points to live
Send a message via AIM to Kurse Send a message via MSN to Kurse
Spring rate question.. low coil vs coil over
I want to know why all lowering spring have a bigger spring rate in rear and on the coil over, mostly brand have a bigger spring rate in front?
It weird to me.. Please explain!
Thanks!
__________________
Base SSM Honda Fit 08 ; Daily Drive and Track Whore
Think outside the [___] box
Sponsored Links
  #2 (permalink)
Old 09-03-2009, 04:17 PM
kenchan relies on Rep Points to livekenchan relies on Rep Points to livekenchan relies on Rep Points to livekenchan relies on Rep Points to livekenchan relies on Rep Points to livekenchan relies on Rep Points to livekenchan relies on Rep Points to livekenchan relies on Rep Points to livekenchan relies on Rep Points to livekenchan relies on Rep Points to livekenchan relies on Rep Points to live
most of these manufacturers for lowering springs have several reasons why they use higher spring rate for the rear.
1) people think higher spring rate in the back = better cornerability. (answer is wrong... depends on the application)
2) lowering springs are usually progressive coil... this emables the user to enjoy some comfort while going straightline using their stock dampers. so they use higher spring rate in the back to try to compensate the initial soft unsettling feel as kind of a swaybar substitute. well, we all know this doesn't work nearly as well as running lowering springs + rear swaybar.
3) people run more weight in the back with passengers and cargo...so to minimize customers complaining about full bump (full stroke) they use higher spring rate in the back.
basically you will never achieve the level of stock or coilovers by running just lowering springs. if you're just going straightline on even roads, sure, you might be able to get it to where you want it. as soon as you start doing some fast left/right manuvers the car will quickly tell you, you degraded your performance just because you wanted to have the lowered ride appearance.
do it right from the getgo. just leave it stock, or get coilovers (or minimum correct lowering springs + dampers)
__________________
08 FitSport (5MT) Storm Silver - My modded dd
09 FitSport (AT) Taffeta White - My stock GE8 as her dd
04 G35Coupe (6MT) Silver - My modded weekend touring car.
09 370Z (6MT) Silver - My weekend sports car.
Post your questions in my Fit Blog
  #3 (permalink)
Old 09-04-2009, 01:18 AM
im the fit's Avatar
im the fit relies on Rep Points to liveim the fit relies on Rep Points to liveim the fit relies on Rep Points to liveim the fit relies on Rep Points to liveim the fit relies on Rep Points to liveim the fit relies on Rep Points to liveim the fit relies on Rep Points to liveim the fit relies on Rep Points to liveim the fit relies on Rep Points to liveim the fit relies on Rep Points to liveim the fit relies on Rep Points to live
What he said!!!
__________________
"I rather drive a slow car fast than a fast car slow"
Reply
Tags
09, coil, coilover, connection, fit, honda, low, lowering, original, questions, rate, rear, spring, standard, suspension, works, wrong
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Sticky?: Suspension Theory (extended) cojaro Fit Suspension & Brake Modifications 10 10-18-2008 01:38 AM
stupid question: Coil over vs just Spring alexfree05 Fit Suspension & Brake Modifications 26 06-03-2008 11:06 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
