Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Suspension & Brake Modifications
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 10-14-2009, 01:51 PM
willitfit's Avatar
willitfit relies on Rep Points to livewillitfit relies on Rep Points to livewillitfit relies on Rep Points to livewillitfit relies on Rep Points to livewillitfit relies on Rep Points to livewillitfit relies on Rep Points to livewillitfit relies on Rep Points to livewillitfit relies on Rep Points to livewillitfit relies on Rep Points to livewillitfit relies on Rep Points to livewillitfit relies on Rep Points to live
Weired noise...
lately i've been hearing a scrapping noise coming from the front left wheel when i turn left. sounds like *scrap scrap scrap scrap* sound gets louder when i turn more or when gather more speed.
anyone know or have this problem?
__________________
F*CK SocalEvo.net
Sponsored Links
  #2 (permalink)
Old 10-14-2009, 02:11 PM
gitaFit's Avatar
gitaFit relies on Rep Points to livegitaFit relies on Rep Points to livegitaFit relies on Rep Points to livegitaFit relies on Rep Points to livegitaFit relies on Rep Points to livegitaFit relies on Rep Points to livegitaFit relies on Rep Points to livegitaFit relies on Rep Points to livegitaFit relies on Rep Points to livegitaFit relies on Rep Points to livegitaFit relies on Rep Points to live
are you missing any cats?
seriously though have you even looked under the fender?
__________________
Dance you pussy... dance.
?+rep
  #3 (permalink)
Old 10-14-2009, 03:33 PM
willitfit's Avatar
its been raining for the past 3 days and today its suppose to stop and im take a lot at it when it stops.
__________________
F*CK SocalEvo.net
  #4 (permalink)
Old 10-14-2009, 05:25 PM
dela's Avatar
dela relies on Rep Points to livedela relies on Rep Points to livedela relies on Rep Points to livedela relies on Rep Points to livedela relies on Rep Points to livedela relies on Rep Points to livedela relies on Rep Points to livedela relies on Rep Points to livedela relies on Rep Points to livedela relies on Rep Points to livedela relies on Rep Points to live
Send a message via AIM to dela
loose fender lining? is the sound metallic?
__________________
  #5 (permalink)
Old 10-15-2009, 01:37 PM
willitfit's Avatar
yee the sounds metallic.
__________________
F*CK SocalEvo.net
  #6 (permalink)
Old 10-15-2009, 01:57 PM
dela's Avatar
first check under the fender n see if anything looks off... if nothing, spin the tire while on jacked up, listen if you can hear it... or wheel bearing? hands at 12 and 6, any play when you push or pull each hand?
__________________
  #7 (permalink)
Old 10-16-2009, 12:57 AM
willitfit's Avatar
Quote:
i just checked it, and nothing seems to be out of place but...i think the hub is loose, i was playing around with the rotors and i notice alittle bit of play with them. ima fix it tomorrow cause i got work in 10min.
__________________
F*CK SocalEvo.net
Reply
Tags
2008, brake, fit, honda, problems
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Skunk2 spring noise help! red08fit Fit Suspension & Brake Modifications 19 10-26-2009 07:39 PM
Help! Weird noise after hitting a pothole and blew a tire fai07 1st Generation (GD 01-08) 5 12-02-2008 07:22 PM
Axxis Ultimate pads and high level of brake noise?? Sleep_DEPRIVED Fit Suspension & Brake Modifications 0 04-14-2008 03:30 AM
Loud thumping noise when braking. NO HELP from stealership on resolving problem bittermelon Fit Trix General Discussions 10 03-27-2008 04:46 AM
2007 FIT dashboard noise holmes General Fit Talk 13 03-11-2007 01:16 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
