Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Suspension & Brake Modifications
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #121 (permalink)
Old 11-23-2008, 08:04 AM
Fit_Dr's Avatar
Fit_Dr relies on Rep Points to liveFit_Dr relies on Rep Points to liveFit_Dr relies on Rep Points to liveFit_Dr relies on Rep Points to liveFit_Dr relies on Rep Points to liveFit_Dr relies on Rep Points to liveFit_Dr relies on Rep Points to liveFit_Dr relies on Rep Points to liveFit_Dr relies on Rep Points to liveFit_Dr relies on Rep Points to liveFit_Dr relies on Rep Points to live
Haven't received everything yet. Should get it this week.
  #122 (permalink)
Old 11-25-2008, 09:47 AM
Frequent FitFreak Poster
jezzy's jazz is on a distinguished road
just want to let u all no, i installed a set of Dixcel type M front pads onto the GD1 jazz over the week end there..
got rid of the constant squeek i was getting from the original pads even after honda de-glazing them twice!!
not sure on how they r performing yet as i have not give them a proper stamping, tryin to brake them in a bit for now...
  #123 (permalink)
Old 06-12-2009, 03:30 PM
DOHCtor relies on Rep Points to liveDOHCtor relies on Rep Points to liveDOHCtor relies on Rep Points to liveDOHCtor relies on Rep Points to liveDOHCtor relies on Rep Points to liveDOHCtor relies on Rep Points to liveDOHCtor relies on Rep Points to liveDOHCtor relies on Rep Points to liveDOHCtor relies on Rep Points to liveDOHCtor relies on Rep Points to liveDOHCtor relies on Rep Points to live
Quote:
Originally Posted by lsvtecdc4 View Post
FMSI # 7497-D621
Hawk's IMO are overpriced and don't perform as well as PBR/Axxis Metal Master pads. You can get the PBR/Axxis Metal Master pads for under $50 shipped.
For people worrying about brake dust, try the PBR Organic pads.
A buddy did put some PBR Metal Master in front and PRB Organic at the back of his 99 Maxima along with Brembo Disc at all corners...
It brakes like crazy!!!
Marko!!
  #124 (permalink)
Old 06-12-2009, 06:03 PM
mahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to live
Quote:
Originally Posted by richard612 View Post
Agreed. In your opinion, what pads fit this criteria?
We've standardized on Hawk HPS pads since on occasion we are preety hard on brakes for extended periods.
Thats on pretty much everything.
  #125 (permalink)
Old 06-12-2009, 06:07 PM
I keep seeing "stock pads suck" appear over and over again in this thread. Guys, there's a reason why the stock pads aren't meeting some of your needs. You can't please everyone all of the time -- You can only hope to meet the needs of the largest audience.
Stocks pads must:
  • Not make noise
  • Not eat the customer's rotors
  • Not make noise
  • Not throw off crazy amounts of dust
  • Not make noise
  • Not have corrosive dust
  • Not make noise
  • Work fine at all normal temperatures
  • Not make noise
  • Provide a good service life
  • Not make noise
  • Provide a reasonable friction coefficient (acceptably low pedal effort)
Did I mention that North American drivers will not tolerate ANY noise from their car's braking systems? If your brake temps exceed the capability of the stock pads, call a spade a spade and admit that you're on a racetrack (or are likely a crazy nutjob driver) and need a higher temp pad. Just expect some compromises in the above items.
You left out the most imoportant criteria: they must 'stop damn well, every damn time' no matter how fast or how often. All the rest are merely window dressing.
  #126 (permalink)
Old 06-21-2009, 06:48 PM
richard612 is an unknown quantity at this point
That's good criteria for you and I, but it's not reasonable for Honda to put pads on the car that can hold up at 1100F. No mass-market consumer grade pad could reasonably be expected to survive under those conditions yet meet the criteria above. It's one or the other.
  #127 (permalink)
Old 06-21-2009, 08:42 PM
rocksnap is an unknown quantity at this point
pads
Quote:
Originally Posted by phil_qc View Post
Does anyone know if there is some aftermarket, non oem,
performance brake pads out there now ??? Looking at Hawk
or PBR (Axxis) but nada
Maybe some JDM pads
Thanks,
Philippe
The stock pads work pretty damn well. If you want to gain some performance/pedal feel try replacing your fluid with ATE Super Blue or Gold. That will firm up your pedal.
Besides, if you put enough miles on your Fit to wear them out then you are way past due for a fluid change... I have 30k on mine in 16 months and they slill look like new.
  #128 (permalink)
Old 06-21-2009, 08:51 PM
Kurse's Avatar
Kurse relies on Rep Points to liveKurse relies on Rep Points to liveKurse relies on Rep Points to liveKurse relies on Rep Points to liveKurse relies on Rep Points to liveKurse relies on Rep Points to liveKurse relies on Rep Points to liveKurse relies on Rep Points to liveKurse relies on Rep Points to liveKurse relies on Rep Points to liveKurse relies on Rep Points to live
Send a message via AIM to Kurse Send a message via MSN to Kurse
hawk make pads, hps and hp+
I run the hp+ on my car with the T1R stainless brakesline with the ATE blue dot 4 (dont put dot 5 in your car) + brembo plain front disk.
The pedal is very firm and it BRAKE.
__________________
Base SSM Honda Fit 08 ; Daily Drive and Track Whore
Think outside the [___] box
  #129 (permalink)
Old 06-21-2009, 09:12 PM
Did the T1R's help?
  #130 (permalink)
Old 06-21-2009, 11:15 PM
Kurse's Avatar
Sure! The pedal feeling is great.
But my car dont brake like I want, i'll put 11" in front next time
__________________
  #131 (permalink)
Old 06-22-2009, 01:17 AM
redrumm's Avatar
redrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to live
project MU pads
__________________
ORDER 3 OR MORE BARS GET FREE SHIPPING!!!!
FOR YOUR GD3/GE8......http://ultraracingusa.com/
EMAIL: ultragd3@yahoo.com
mbarton@ultraracingusa.com
  #132 (permalink)
Old 06-22-2009, 09:01 AM
Since there are 5 major components to braking: brake fluid, proportioning valve, pads, rotors, and tires, have you addressed all 5, especially the tires?
And do you measure 'like I want" by measuring stopping distances, or what you feel?
It is rocket science.
PS: 11" rotors won't necessarily be better.
  #133 (permalink)
Old 06-22-2009, 09:13 PM
Kurse's Avatar
I've good tire too, i'm running the potenza re-11.
In time attack, 11" brake is a must..
__________________
  #134 (permalink)
Old 09-04-2009, 06:06 PM
Jodele's Avatar
Jodele relies on Rep Points to liveJodele relies on Rep Points to liveJodele relies on Rep Points to liveJodele relies on Rep Points to liveJodele relies on Rep Points to liveJodele relies on Rep Points to liveJodele relies on Rep Points to liveJodele relies on Rep Points to liveJodele relies on Rep Points to liveJodele relies on Rep Points to liveJodele relies on Rep Points to live
Send a message via Skype™ to Jodele
11" front discs made a hell of a big difference for me on my GD3! See my post here for a cheap way to do it http://www.fitfreak.net/forums/fit-s...tallation.html
__________________
A man's mind, once stretched by a new idea, never regains its original dimensions. [Oliver Wendell Holmes]
  #135 (permalink)
Old 09-04-2009, 07:26 PM
Selden's Avatar
Selden relies on Rep Points to liveSelden relies on Rep Points to liveSelden relies on Rep Points to liveSelden relies on Rep Points to liveSelden relies on Rep Points to liveSelden relies on Rep Points to liveSelden relies on Rep Points to liveSelden relies on Rep Points to liveSelden relies on Rep Points to liveSelden relies on Rep Points to liveSelden relies on Rep Points to live
Better tires have a big impact on actual stopping distance; changing the brake fluid can have a huge impact on brake feel. When people switch to SS lines, half the improvement they notice is probably just from fresh brake fluid. Change it annually; it it's the color of honey, it needs to be changed.
__________________
Microsoft has a majority market share in the new desktop PC marketplace.
This is a bug, which Ubuntu is designed to fix.
-- Mark Shuttleworth
Reply
Tags
brake, civic, fit, fitfreak, hawk, honda, konig, megarace, pads
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
