DIY: Koni Yellows for GD3 rear
Old 09-05-2012, 08:30 PM
eurobeaner's Avatar
i need to try this. it should be super easy to make a tube, with 3 brackets.... 2 being for the knuckle, and 1 for the sway bar. then a round mount to put any coilover sleeve (ground control or whatever). it should be gravy.
im getting ready to do all this on my n600. its got a weird setup, and i want to switch to a knuckle with 4x100
  #42
Old 09-05-2012, 08:34 PM
solbrothers's Avatar
yeah. it should be very easy. I'm working out a price for the front integra koni/gc suspension, but i should have that worked out by the end of the week
  #43
Old 09-05-2012, 09:00 PM
eurobeaner's Avatar
you might not want integra front koni... you really want a koni designed for macpherson style strut. the rod will be much thicker since it takes all the weight, PLUS cornering load. the integra has double wishbone setup, so the only force the shock sees is up and down, not side to side.
we ran into this when i had my 1980 civic. nothing available, no inserts available that small, so people modded integra and civic struts to it and eventually bent the rods. they are not designed to take all the cornering force that a macpherson is designed for
  #44
Old 09-06-2012, 12:32 AM
macbuddy's Avatar
Originally Posted by TPColgett
... I have been using the Tokico HTS adjustable struts for a little over 3the years
Tyler, if you have a chance, check the OD of your Tokicos. I wonder if those might be a candidate for the Koni insert mod.
  #45
Old 09-06-2012, 12:34 AM
ouch! very interesting
  #46
Old 09-06-2012, 09:20 AM
Do you really think that yellows for all cars are the same? I mean based on your spring rate comments and not knowing that....
  #47
Old 09-06-2012, 09:31 AM
apexanimal's Avatar
^one of my concerns...
good idea on the tokicos and any other aftermarket strut for the fit...
  #48
Old 09-06-2012, 09:38 AM
ragingti's Avatar
That company is looking to make a lot of money for doing something a koni shock and ground control sleeve could do
Again, no Koni insert will fit in our front housings, and using some random insert probably will not end well(example above). IF you could find one that fits, and then have it revalved, it might handle ok, but as already said, it needs to be meant for our suspension design. I have no connection with that company, but for a FULL COILOVER suspension, custom front housings/strut , adjustable ride height and adjustable shocks, with shocks valved properly for our cars already, seems like a fair price to me, and you can pick whatever spring rates you want with their setup.
What he said.
  #49
Old 09-10-2012, 11:59 PM
TPColgett's Avatar
I some how unsubscribed from this thread...
I can still measure the OD of my Tokico's tomorrow in the daylight but. I don't remember them being any visibly larger...
  #50
Old 09-11-2012, 01:02 AM
cjecpa's Avatar
If you want struts and shocks only found this for GE8 not sure if he has for GD3 $780 for Koni fronts and rear 06-11 Civic Suspension
  #51
Old 09-11-2012, 01:32 AM
how low can you get on the redshift coilovers?
  #52
Old 09-11-2012, 08:00 AM
cjecpa's Avatar
I do not know that you can e-mail Chris there to see. I notice that he has the Koni shocks and custom front strut without the springs for sale.
  #53
Old 09-11-2012, 08:30 AM
Link please?
  #54
Old 09-11-2012, 09:51 AM
cjecpa's Avatar
Here is the link I was checking out his site 06-11 Civic Suspension I know this comes up 06-11 Civic but the page says 09+ Fit.
If you hit the highlighted under Koni shocks you can e-mail him.
  #55
Old 09-11-2012, 10:03 AM
Hmm. IIRC the GE fronts work just fine on the GD. I'll have to email and see if he can send just the front, sans springs.
  #56
Old 09-11-2012, 11:12 AM
cjecpa's Avatar
I e-mail to see about getting a set for my GE8 I already have Eibach springs.
  #57
Old 09-11-2012, 12:19 PM
TPColgett's Avatar
If the Red Line "struts" are available for the fronts for the GE and are able to be simply rettro fitted on a GD, then the SAAB Koni's are available for the rear... did we just find a front and rear solution?
Haha, at this point at $540 shipped for another set of Tokico's I might just get them and put them on a shelf till I need them!!!
  #58
Old 09-11-2012, 12:21 PM
TPColgett's Avatar
On the page it says "Lowering Spec: 0-3" Drop" but these are listed for a 09+ Fit
  #59
Old 09-11-2012, 02:05 PM
pearl's Avatar
Wow, this really took off. It looks like the guy at RedShift has figured it out! The photos just show an insert, but it looks like this is a straight bolt in offering?
Now just need to take the plunge!
  #60
Old 09-11-2012, 02:11 PM
TPColgett's Avatar
Red Shift already appears to have a thread on here:
https://www.fitfreak.net/forums/2nd-...-interest.html
Quick Reply: DIY: Koni Yellows for GD3 rear
