DIY: Koni Yellows for GD3 rear
  #81
Old 05-02-2016, 06:25 PM
TPColgett's Avatar
Originally Posted by Kurse
So? Anyone found something for the front?
I'm confused now..
Other than the custom strut housings from Redshift for use with Koni Sport inserts, there is no direct fit application for GD.
Koni makes a STR.T (Orange) shock kit for the GE, but I have not attempted to fit it to a GD as the shock lengths, as well as extension and compression will be off (a little long likely,) and damping is set for different rates.
  #82
Old 05-02-2016, 06:37 PM
Kurse's Avatar
Does Redshift sell the kit?
  #83
Old 05-02-2016, 06:40 PM
TPColgett's Avatar
These were limited run made to order.
NOT AVAILABLE NOW - SEE DESCRIPTION FOR DETAILS - RedShift Koni "SPORT" (Single Adjustable) Full Coilover (06-08 Fit, 09+ Fit)
He has not done a run in quite a while, but I believe he still sells rears.
  #84
Old 05-02-2016, 06:49 PM
Kurse's Avatar
Thanks a lot!
  #85
Old 05-04-2016, 09:31 PM
GD001's Avatar
Would this modification be appropriate coupled with Ground Control - Honda Fit coilover kit
<<<<<<<these?
Blackberry Goose
05-05-2020 02:50 PM
1Gr8GE8
05-04-2014 12:18 PM
GD3_Wagoon
16
04-08-2010 03:08 AM
Fit of RAGE
04-23-2008 05:28 PM
Skimmer
02-08-2008 05:50 PM
Quick Reply: DIY: Koni Yellows for GD3 rear
