Actually the Newer DC Strut Bars are pretty strong with no flex and solid mounting and not adjustable. They are kinda tough to get on but they are very nice. The old ones were mostly for looks and able to flex easy. They fit perfect but as I said you can't adjust them.
Has anyone experience a rattling j's rear strut bar? help! Ive tried to tightened it and it still makes a rattling sound as if it wasnt installed properly. Any suggestions?
I have the Tanabe rear sway bar installed and my seats will not recline back into the second posistion. It will recline just a little bit but the seat hits the bolts on the sway bar. I could just cut off the bolts to allow them to recline all the way back but I'm lazy.
I tried that when I installed my rear Tanabe but they still won't latch in the reclined postion. If you cut out some of the plastic on the seat latch mechanisim it might lock. I just leave the seats foward.
__________________
2007 SSM Honda Fit Sport
15% Tint
Pioneer Avic D-3
Injen cai
Tanabe Concept G axle back
Weapon S Header
Megan Downpipe
Megan B-Pipe
Skunk2 Springs
Tanabe F/R Strut Tower Bars
Progress Rear Sway Bar
JDM Smoked LED Tails
Buddy Club P1's 17x7's Gunmetal 42 Offset
Kuhmo 205/40/17
Can anyone recommend a rear strut bar that will still let my chair recline all the way back.... Thxs!
__________________
07 Honda fit Sport VBP-
-Tanabe Concept G Exhaust,Tanabe Springs GF210, Injen Cai/Sri-Gram Lights 16x7 57c Rims w/ Toyo Proxes 4 205/40/16-Spoon Resevoir Tank Cover,Spoon Short Antenna,Seibon CF OEM hood -Blue Rays Engineering Lug Nuts-JDM center console, Honda Access JDM Coin Holder ,JDM Window Visors,JDM Sun Visor-OEM Trunk Cargo Cover,Locking Gas Fuel Cap-Cusco Front Strut Bar, Progress Rear Sway bar, J's Racing C pillar bar
I ordered a set of Cusco Front and Rear strut tower bars. I'm also planning on ordering the lower front brace wich I've seen available for the Fit. I e-mailed JapanParts.com and they said they aren't sure if that bar (designed for the JDM Fit) will work on the USDM Fit.
What do you guys think? Will it be just a matter of boring out the bolt holes to a larger size as is with the JDM coilover setups or will it be an open and shut case of simply bolting it on?
Thanks for any info.
tHE LOWER BAR FOR THE jdm fiT WILL NOT FIT!!! Check out the T1R ( I belive it is T1R) from AJR. It looks good and is not so expensive.. there is a thread where Ben explain the difference between the JDM and USDM bars with even a side by side comparo picture.
ohh ok. out of the three you mentioned, I saw the rear strut bar made the biggest difference. I would also consider getting the innerfender braces and lower tie bar.
ohh and BTW, the Floor bar won't fit usdm Fits.
you should do as claymore says and visit the susspension forum. you'll find ALOT of answers there. happy hunting.
Does anyone know what the c-pillar bar really does?
Eric
__________________
Cars that I currently own/drive
2007 BOM Fit Sport 5A
2002 Sebring Limited convertable
1989 Chev 4WD Suburban
1975 Porsche 914 Renegaded 327 V8
1915 Ford Model T Touring (stock)
Oh well so much for having all my bars from the same manufacturer. Screw it, I'm buying the T1R bar and my braided lines next.
I already installed the Skunk2 Springs Carlos! Rims and wheels get in this week, already have my set of Rays Dura Nuts. The Cusco bars should arrive in about week or so.
