Fit FREAK.net
Go Back   Honda FIT Forums > Fit Trix > Fit Suspension and Brakes
Fit Suspension and Brakes Discuss suspension upgrades and brake modifications
Reply
  #41 (permalink)
Old 04-09-2008, 09:15 AM
starier9801's Avatar
starier9801 will become famous soon enough
Quote:
Originally Posted by ToyotaLover View Post
take the push pins out from the top 3 of each arch...then push the lining above the mounting tabs. Basically you will still retain the lining and it is behing held in by the tabs because it's above it...but the lower push pins are holding it in.
it goes above the fender where the screw is...and comes back out where there is a notch in the fender closer to the passenger compartment. I'll take pics when i get home if I remember.
If you can, please post pics. I'll be doing this to my Fit this weekend to fit my 17's.
  #42 (permalink)
Old 04-09-2008, 02:37 PM
Fit4Trav's Avatar
Frequent FitFreak Poster
Fit4Trav has much to be proud ofFit4Trav has much to be proud ofFit4Trav has much to be proud ofFit4Trav has much to be proud ofFit4Trav has much to be proud ofFit4Trav has much to be proud ofFit4Trav has much to be proud ofFit4Trav has much to be proud ofFit4Trav has much to be proud ofFit4Trav has much to be proud of
Quote:
Originally Posted by Injundon View Post
at around 2 .5" suspension drop in the front the control arms will petty much be flat. AJ-R sells a roll center adjuster which would greatly help if you want that much of a drop.
That's the answer I was looking for
Thanks
  #43 (permalink)
Old 04-23-2008, 02:56 PM
HONDAJUNKIE's Avatar
HONDAJUNKIE has a brilliant futureHONDAJUNKIE has a brilliant futureHONDAJUNKIE has a brilliant futureHONDAJUNKIE has a brilliant futureHONDAJUNKIE has a brilliant futureHONDAJUNKIE has a brilliant futureHONDAJUNKIE has a brilliant futureHONDAJUNKIE has a brilliant futureHONDAJUNKIE has a brilliant futureHONDAJUNKIE has a brilliant futureHONDAJUNKIE has a brilliant future
Though I was the only one who told people no more than 2, but most of my friends know the deal they all mostly have slammed cars to so they understand its only a problem when I want to chill with some new pussy cause they bring other females with them which is a good thing but so far I have'nt had trouble in my fit yet cause its bone stock still. My springs are still in the box sitting next to my intake in a box still.
__________________
Quote:
Originally Posted by fitinfit View Post
uhh...don't want people copy your style?...try...design your own wheels, or don't post up pictures on the internet?
  #44 (permalink)
Old 10-08-2008, 11:57 PM
teggsr925's Avatar
teggsr925 has a spectacular aura aboutteggsr925 has a spectacular aura about
lets get this thread back alive!!!
__________________
i haz no fit but i still haz VTAKKK
2008 4dr SI
  #45 (permalink)
Old 10-09-2008, 08:25 PM
I Am Ray.'s Avatar
The One With HoBo Stab Insurance.
I Am Ray. relies on Rep Points to liveI Am Ray. relies on Rep Points to liveI Am Ray. relies on Rep Points to liveI Am Ray. relies on Rep Points to liveI Am Ray. relies on Rep Points to liveI Am Ray. relies on Rep Points to liveI Am Ray. relies on Rep Points to liveI Am Ray. relies on Rep Points to liveI Am Ray. relies on Rep Points to liveI Am Ray. relies on Rep Points to liveI Am Ray. relies on Rep Points to live
Since this was bumped I guess I can post. My cars kinda low.
Skunk2 coilovers. Fronts untouched, rears modded.
Fronts can still go lower. Awaiting my 14's to be on first.
15x7 +26mm Enkei RC-S's
195/50/15's.
Tires all around are about .25 to .50in tucked.
__________________
- KillerFit #2 -
- The Originator -
  #46 (permalink)
Old 10-09-2008, 08:41 PM
rvall004's Avatar
rvall004 has a brilliant futurervall004 has a brilliant futurervall004 has a brilliant futurervall004 has a brilliant futurervall004 has a brilliant futurervall004 has a brilliant futurervall004 has a brilliant futurervall004 has a brilliant futurervall004 has a brilliant futurervall004 has a brilliant futurervall004 has a brilliant future
men seeing all this fits slammed to the floor makes me want to get coils
__________________
DON'T DRINK AND DRIVE, SMOKE AND FLY
  #47 (permalink)
Old 10-09-2008, 08:47 PM
trancedsailor's Avatar
trancedsailor should get some awardstrancedsailor should get some awardstrancedsailor should get some awardstrancedsailor should get some awardstrancedsailor should get some awardstrancedsailor should get some awardstrancedsailor should get some awardstrancedsailor should get some awardstrancedsailor should get some awardstrancedsailor should get some awardstrancedsailor should get some awards
how do you 'tuck' your tires?
__________________
Myspace: www.myspace.com/silentscreamer
  #48 (permalink)
Old 10-10-2008, 10:44 PM
I Am Ray.'s Avatar
Roll/pull your fenders, negative camber, and never make U-turns unless desperately needed.
__________________
- KillerFit #2 -
- The Originator -
  #49 (permalink)
Old 10-10-2008, 10:53 PM
junior40er's Avatar
junior40er has a brilliant futurejunior40er has a brilliant futurejunior40er has a brilliant futurejunior40er has a brilliant futurejunior40er has a brilliant futurejunior40er has a brilliant futurejunior40er has a brilliant futurejunior40er has a brilliant futurejunior40er has a brilliant futurejunior40er has a brilliant futurejunior40er has a brilliant future
heres mine on Ksport coilovers. Its actually lower right now and plan on going even lower but I need to roll my fenders first cause im rubbing like a bisshh.
  #50 (permalink)
Old 10-10-2008, 11:35 PM
jazn's Avatar
jazn relies on Rep Points to livejazn relies on Rep Points to livejazn relies on Rep Points to livejazn relies on Rep Points to livejazn relies on Rep Points to livejazn relies on Rep Points to livejazn relies on Rep Points to livejazn relies on Rep Points to livejazn relies on Rep Points to livejazn relies on Rep Points to livejazn relies on Rep Points to live
195/50/15's.
I have samee tire size as you, but i have 15x6.5 with +32 offset so im thinking if i dump as much as you it should look similar. I love that shit homie. DUNKENNNN ALL DAY.
__________________
08 NHBP Manual | Skunk2 springs | Mishimoto carbon fiber intake | Genuine Honda OEM red badges | Limo tint | HID's | Side markers | Yellow Fogs w/ Yellow Lamin-x film | Mugen Visors | Zeta dead pedal | 100% complete JDM no fake BULLSHIT
Bumping 2 10" DVC Pioneers w/ JVC KW-NX7000 DVD/NAV
7k miles
Shoes: Pride and Joy: SSR Sprint Hart CP-F 15x6.5 +32 | Gram Lights 57Maximum 16x7 +38 | Stock Enkeis |
Proud SEMA/SAN member
  #51 (permalink)
Old 10-11-2008, 07:57 AM
FELIXY69's Avatar
FELIXY69 has a spectacular aura aboutFELIXY69 has a spectacular aura about
to me....all ur cars are LOW...but inorder to be slamed..u HAVE to be on BAGS !!
__________________
Stylish Looking fit cAmE !!
My Project Horny GTR RB30/26
current status
-slammed + fat wheels + turbo
-OCT 2008 JDM Noblesse conversion done !
B00sted NobleSSe fit
I hate ppl who made their AT look like MT....my fit is AT and is b00sted--> WhAt !!
  #52 (permalink)
Old 10-11-2008, 12:41 PM
Fit4Trav's Avatar
Quote:
Air is for cheaters
__________________
REAL FRIENDS > CAR CLUBS
"And I dont mod my Fit to please anyone else. Its mine, its modded for me." (I Am Ray.)
  #53 (permalink)
Old 10-11-2008, 01:07 PM
dank24's Avatar
dank24 is a jewel in the roughdank24 is a jewel in the roughdank24 is a jewel in the roughdank24 is a jewel in the rough
I like where this thread is at. All those people with skunk springs think they are "slammed"
__________________
I sell HIDs, Plug and Play. Great prices shipped. PM me for more info.
  #54 (permalink)
Old 10-11-2008, 01:37 PM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
Kyle is raaddd relies on Rep Points to liveKyle is raaddd relies on Rep Points to liveKyle is raaddd relies on Rep Points to liveKyle is raaddd relies on Rep Points to liveKyle is raaddd relies on Rep Points to liveKyle is raaddd relies on Rep Points to liveKyle is raaddd relies on Rep Points to liveKyle is raaddd relies on Rep Points to liveKyle is raaddd relies on Rep Points to liveKyle is raaddd relies on Rep Points to liveKyle is raaddd relies on Rep Points to live
yeah i think bags are "cheating" also
__________________
  #55 (permalink)
Old 10-11-2008, 01:56 PM
dank24's Avatar
Quote:
nah get some bags as struts and coilover = best setup omg ::droool:::
thats ballin
__________________
  #56 (permalink)
Old 10-11-2008, 04:58 PM
jazn's Avatar
Quote:
i agree, i have skunk2 coilovers and im bummin everyday =( i wanna ****eeeen DIP!
__________________
7k miles
  #57 (permalink)
Old 10-11-2008, 04:59 PM
jazn's Avatar
... dodge dive, duck, dip.
__________________
7k miles
  #58 (permalink)
Old 10-12-2008, 08:37 PM
teggsr925's Avatar
this thread is weak. why do people on springs think they are slammed?
__________________
2008 4dr SI
  #59 (permalink)
Old 10-12-2008, 09:09 PM
dank24's Avatar
thats what i said lol
Skunk 2 springs are like 10 sets for $10.99 on ebay
__________________
  #60 (permalink)
Old 10-12-2008, 09:28 PM
I Am Ray.'s Avatar
So far all the bagged US Fits are just as low as my car. Only difference is mine is drivable.
Im going by the tire vs fenders.
__________________
- KillerFit #2 -
- The Originator -
Reply
Display Modes
Linear Mode Linear Mode
Threaded Mode
