hi
i got a set of T1R coilovers from a fourm member
i didn't get any instructions on how to Adj. it
my question is .where are these adjustment at?
-camber --do i need the optional pillowball top mount to use this function ?
-36 way compression --this must be the knob ontop ?
-rebound -- where is this ? usally on the bottom, but i don't see it ?
also my fronts are kinda weird, the rubber bushing on top can move when i turn the steering wheel. but the bolt is tight, and you can see it's tight cuz you can see the bushing is kinda mushed down.
this is also causing it to creak..and makes weird noise
I was wondering if you ever fixed the problem with your front coilover. I had mine installed a long time ago and they've been running fine until recently. Now whenever I go over anything that's not flat on the road and I hear a weird clunking noise. It makes the noise too when I press up and down on the front of the car. Never had this problem before and I tried everything. Had all the bolts re torqued, did an alignment, nothing I can think of to fix the clunking noise. It's just my front left that's making the noise, everything else is fine.
thanks for responding, I actually just got back from putting the fit baby back together. Turns out that the clunking noise was actually one of my last few theories.
My whole coilover was solid, nothing was loose and I know the install was correct. The last time I had taken the suspension out I saw that the factory rubber bump stop was damaged on the inside rim that sits around the nut of the coilover. I didn't think to much of it until I realized that the inside of the rubber bump stop is metal, thus the clunking noise. I ended up putting some rubber rings between the nut and the rubber bump stop and i finally have silence , hope this helps anyone that comes along with this problem. Took me a couple days and a lot of pondering to figure out where the sound was coming from.
Btw I believe the rubber bump stop was damaged when I drove over a really bad pothole I didn't see coming. It bent my rim and effed up my tire a bit too.
wat? the T1R's use factory bumpstops? or are you
referring to the rubber top mount, lower half?
__________________ 08 FitSport Storm Silver Metallic (5MT)
Suspension: EnduraTechs
Dressup: Black fog lamp surrounds, Megan axle-back.
Wheels: DragDR21 15x7 +40mm, Ziex912 195/50/15
Int & Ext: Factory a/s floor mats, Zeta deadpedal,
factory trim kit, JDM visor, JDM door handles, MOMO Champion,
Daikei hub 20mm spacer + AS01 adjust, RecaroYoung Sport
child seat VivoLite, TypeR style satin shift knob, Zeta cargo cover,
Mugen window visors, ONYX metalized 30% tint.
ICE: JVC Arsenal HU
