Echoing what Manxman said, the Progress sway is THE single most cost effective no downside mod out there for the Fit. After putting it on, there is a very subtle difference in the ride. The handling difference is hugely noticeable the first time you corner resonably hard. Turn in is much sharper. My friend/coworker wanted to look into a rear sway for his Focus after a ride in my Fit.
Definetly the Progress bar, all ive heard is AWESOME reviews for that thing, and its not exspensive..Its a great mod to your cars handling.
__________________
- KillerFit #12 - Have a question or concern? Feel free to PM me or any colored User Name Honda Fit Forums Administrator
No more Crotas. . .
the front sway is imho stiff enough even with the rear progress bar.
i still get plenty of understeer when the crappy ziex912's break.
A little OT, but lose the front sway bar and it will clear up your understeer. The front end can use the extra flex to shift weight on the outside tire more and fight the understeer.
i've heard about this. always wanted to see someone put it to the test.
Yeah, in theory but I think you would have to really dial in the back in order to get more neutral handling. If the back was too tight, then you would get some snap oversteer. The fit is tricky because the weight distribution is odd. You have a tall hatch in the back, a fuel tank in the middle, and a stubby nose with a light engine in the front.
I have gotten my car close to where I want the handling, but it needs some roll center adjusters and a limited slip to finish it.
no the car would roll too much and loose straightline stability along
with the ability to reposture upright itself after coming out of a turn.
the spring rates are not tuned to work without the front bar.
i would keep the front bar the same, add the progress bar, and
add better tires up front, same tires in the rear but narrower width
if this was for race application.
__________________ 08 FitSport Storm Silver Metallic (5MT)
Suspension: EnduraTechs
Dressup: Black fog lamp surrounds, Megan axle-back.
Wheels: DragDR21 15x7 +40mm, Ziex912 195/50/15
Int & Ext: Factory a/s floor mats, Zeta deadpedal,
factory trim kit, JDM visor, JDM door handles, MOMO Champion,
Daikei hub 20mm spacer + AS01 adjust, RecaroYoung Sport
child seat VivoLite, TypeR style satin shift knob, Zeta cargo cover,
Mugen window visors, ONYX metalized 30% tint.
ICE: JVC Arsenal HU
