just some notes -
Stance isn't the same big name like ohlins, moton, or KW. on the other hand, last year's NASA TTR champions ran a Stance suspension. To save you time, here is a link to the rules that designate what the TTR class is - http://www.nasaproracing.com/rules/Time-Trial-Rules.pdf.
The long story short: "The TTR class is designated as a truly unlimited racecar class. It is intended for purpose built,
tube frame, never street legal, and monocoque racecars, as well as very high-end modified streetcars with low weight/hp ratios. Modifications are completely unlimited (within NASA safety technical guidelines), although open-wheel formula cars are not legal."
I'm sorry, but I haven't been too impressed with the suspension options available for the Fit thus far, other than the "OEM" stuff from spoon and mugen. I don't know anyone at Stance, I don't have a Stance suspension, and literally only know about them because I'm a big Evo fan and took notice when a Stance equipped car beat much pricier competition (to include Penske triple adjustable on remote reserviors, on the high end).
I think that the people that have held off on coilovers (like me) now have a legit suspension to consider. I honestly wish I had never found this.
i have them on my 240sx (gr+pro) and i loved them and compared them to teins flexs. they are stiffer and feel better. the only problem i had with them is that i felt every bump on the road and has a rough ride.
i would probably put these on eventually.
what is the spring rate? it's not posted on the site
I was at my local parts distributor yesterday and I started the convirsation with coil-overs in mind. I mentioned Tein, and he mentioned Stance. I'm definately picking up a set this winter for the following spring. He sells them for $1100, and their local so if there's any problems then it's a 20min drive for me to work things out with them.
~I think the front is 5K and rear is 4K spring rates. I think.
__________________
'08 Millano Red 5-spd Sport
~Tein S-Techs
~A-Spec Header
~A-Spec Cat-Back
~A-Spec C.A.I.
~A-Spec F&R Strut Bars
~T1R Front Sway Bar
~Mugen Window Visors
~Spoon Resovior Covers
All ApplicationsProduct Description Select A Make to Narrow the Selection ACURAHONDALEXUSMAZDAMINIMITSUBISHINISSANSUBARUTOYOTA
HONDAPartNumberYearModelSubModelCylindersLiterAspi rationEng Desg.FuelNotesST-GD3-GR 2007 - 2008FITBASE; SPORTL41.5NL15A1GASFront Spring Rate5kRear Spring Rate4kNotesStance GR+ Coilovers
__________________
~Tein S-Techs
~A-Spec Header
~A-Spec Cat-Back
~A-Spec C.A.I.
~T1R Front Sway Bar
you should call the stance guys, i did a few months back on another application. that way you can get a spring rate that you like on them. i'll be going with a 3/5 or a 4/6 setup.
__________________
07' SSM Fit Sport 109 hp
Progress rear sway bar, Skunk2 Pro-C, DC Sports strut bar, Konig Helium 205/50/15, H-Fit intake, Megan header (w/stock heat shield!)+axleback, Zenith HIDs.
the stance coilovers for the gd3 do not have upper pillowball mount with camber adjustments
i have a custom set from stance, race-valved and custom spring rates so mine are alot stiffer than the off-the-shelf rates which are 5.5kg and 4kg i believe
i've had some slight issues with mine, as it's the first set from stance to be custom made for a gd3, so i understood it
my front spring is too long, and while preloaded and the damper lowered all the way, it is still too high for my preference, a 2 inch shorter spring would solve that issue
the rear suspension of mine is a spiral wound spring like the oem style, and not a linear like most aftermarket ones, i originally requested a linear rear spring, but they still sent me this one, and for some reason, i don't believe my rear springs are 10kg since it's way too soft and the rear compresses more than my old tanabe df-210's. i'm still working with stance to fix this issue, but so far, the feel of the suspension is awsome compared to before and i would highly recommend it to anybody
goes against that mumbojumbo in your head per the complaints
you had over in the ET coilover thread. you wanted front rates
to be lower than the rear.
here's your post:
your powers of pointing out the obvious never cease to astound. as i have posted in the endura tech thread, as well as this one, i would specifically order the spring rate that i want.
and if you did the research rather than just buying the off-the-shelf spring rates and insisting that everyone hit the "i believe" button like you did, you'd know that the coilovers of any value will let you specify a spring rate appropriate for your application.
see, that's the power of the internet! you get to specify what's right for you, then buy it. rather than the backwards way of buying something, putting it on, and seeing if it works out. then swearing up and down it's the best. it's even worse when you're talking about suspension and have no motorsports experience.
darn kenchan, that's what you get for not reading the whole thread. and trying to get involved where you clearly are not thoroughly expereinced, despite how loud you yell about it.
when you get the chance, you should call up spoon and tell them that they're doing their spring rates wrong. and swift too while you're at it. let us know how that goes
here let me help you, there's a neat little spreadsheet in this thread: Spring Comparision
just saying. you've got a long list of suspension suppliers that you better get on the horn and save.
by the way, "mumbojumbo"? very descriptive; i suppose slang is a substitute for a valid argument now, but it is consistent from your posts in your endura tech nut swinging thread, where i busted you out there too:
Quote:
Originally Posted by kennef
i can't lie, i refuse to take such logic seriously. "because many others do it" or "because these are more expensive than those" are poorly constructed arguments that aren't convincing.
hahaha, looks like i pushed the right button.
__________________ 08 FitSport Storm Silver Metallic (5MT)
Suspension: EnduraTechs
Dressup: Black fog lamp surrounds, Megan axle-back.
Wheels: DragDR21 15x7 +40mm, Ziex912 195/50/15
Int & Ext: Factory a/s floor mats, Zeta deadpedal,
factory trim kit, JDM visor, JDM door handles, MOMO Champion,
Daikei hub 20mm spacer + AS01 adjust, RecaroYoung Sport
child seat VivoLite, TypeR style satin shift knob, Zeta cargo cover,
Mugen window visors, ONYX metalized 30% tint.
ICE: JVC Arsenal HU
