spoon springs installed!!!~
Old Aug 18, 2006 | 02:48 AM
honda_dna's Avatar
Originally Posted by dmxsoulja3
think you can get away with 5mm front and rear? I got some left over from my scion.
it should be fine.
Old Aug 18, 2006 | 03:00 AM
marokero's Avatar
Sorry, what I meant to ask was if after lowering the Fit had less negative camber than stock. The numbers you gave for the rear camber were -1.7 and -1.8 for lowered, and -2 to 0 for stock (I guess that's where I'm confused about).
Old Aug 18, 2006 | 03:52 AM
honda_dna's Avatar
oh, those are the acceptable range. Not stock spec.
if i remember correctly,most honda (fit included) comes with 0 toe in the front, 0.1 toe at the rear. 0 camber in the front and -1 camber at the rear.
The honda spec i gave out is the acceptable ranges.
Hope it clears up.
Old Aug 18, 2006 | 06:56 AM
VividBlueFit's Avatar
how hard was it to install the rear springs?
the front looks like the typical civic and preludes i've done before but the rears are nothing like i've done before
Old Aug 18, 2006 | 08:00 AM
aveosam's Avatar
the rears are even easier than the front....all you do is detach the bolt holding the shocks to the trailing arm and drop the suspension enough that u can get the springs out and slide the new ones in the right position and then bolt the shocks back to the trailing arm and lower the car slowly to make sure the springs stay in place
Old Aug 18, 2006 | 09:01 AM
jdmfit07's Avatar
nice. verry nice.
Old Aug 19, 2006 | 08:59 AM
macks75's Avatar
Old Aug 19, 2006 | 09:15 AM
awesome, thanks, i'm supprised theres nothing in there holding them in
Old Aug 19, 2006 | 10:26 AM
Mr SEntra's Avatar
Question
What size wheels and tires are you running? I just wanted to get a feel for your wheel gap compared to your wheel and tire setup. Thanks and the car looks great!
Old Aug 19, 2006 | 05:14 PM
clk1022's Avatar
Any raffle in the interior after installed?
Old Aug 19, 2006 | 06:24 PM
mia-fit's Avatar
Any rattle in the interior after installed?
Old Aug 19, 2006 | 08:42 PM
  #32
STTICH's Avatar
from the pic..im pretty sure macks75 are running wth 16in wth 45 profile tyres.
Old Aug 20, 2006 | 12:08 AM
  #33
Mr SEntra's Avatar
Thanks for the info!
Old Aug 20, 2006 | 02:56 AM
  #34
marokero's Avatar
It looks just like mine, which are 16x7 Spoons with 45 profile tires The drop seems mild, but for some reason the gap in front doesn't seem the same as the gap in the rear. I'm thinking of going with T1R's, specially for the higher rate in the rear springs compared to Spoon.
Old Aug 20, 2006 | 03:41 AM
  #35
simons2k's Avatar
Nice drop! It looks like the perfect lowering height.
How would you compare the ride to oem springs? Stiffer, or the same?
Old Aug 20, 2006 | 07:17 AM
  #36
macks75's Avatar
tire size
205/45/16 dunlop lemans
the ride is even bette than the oem springs less road noise also
Old Aug 20, 2006 | 01:01 PM
  #37
Mr SEntra's Avatar
I'm highly interested. I can't get myself to spend money on full coilovers, but I can't stand the stock ride height. The T1R springs are nice, but I think a little too low, especially if you want to haul stuff around in the back. Thanks for the pics and the info again.
Old Aug 22, 2006 | 12:54 AM
  #38
Halcyon's Avatar
I have t1r, the ride quality is bad right now. I think the installer goofed up. Front s coils have too much play i think with the shock and it bounces like a pogo stick on the road on any bump!
Old Aug 24, 2006 | 03:25 PM
  #39
Paulo107's Avatar
cant wait to see mine dropped on the skunks
Old Sep 3, 2006 | 08:10 PM
  #40
marokero's Avatar
to honda_dna
It's been two weeks now, how are the springs? I mean, have they settled some or not much changes from how they looked in the original pics?
