Fit FREAK.net
Go Back   Honda FIT Forums > Fit Trix > Fit Trix General Discussions
Reply
  #1 (permalink)
Old 08-29-2007, 11:10 AM
Fit of RAGE's Avatar
Honda Fit Forums Moderator
Fit of RAGE is a name known to allFit of RAGE is a name known to allFit of RAGE is a name known to allFit of RAGE is a name known to allFit of RAGE is a name known to allFit of RAGE is a name known to all
Modding OEM Grill
Hey everyone, i took a look at the front OEM grill the other day and i noticed that air passes through it and then it gets blocked off at the rad by a plastic/rubber shield. has anyone removed that shield so that the intake has more/colder air entering the engine? If we remove it, will it cause turbulance in the engine compartment??
Sponsored Links
  #2 (permalink)
Old 08-29-2007, 12:25 PM
Supervillain
doctordoom has much to be proud ofdoctordoom has much to be proud ofdoctordoom has much to be proud ofdoctordoom has much to be proud ofdoctordoom has much to be proud ofdoctordoom has much to be proud ofdoctordoom has much to be proud ofdoctordoom has much to be proud ofdoctordoom has much to be proud ofdoctordoom has much to be proud of
i think it's there to make sure the cold air goes through your radiator. correct me if i'm wrong. and some aftermarket pieces even replace the shield with a metal piece. Carbing Aluminum Radiator Cooling Plate 00-07 Honda S2000 is that what you're talking about?
  #3 (permalink)
Old 08-30-2007, 09:58 AM
Quote:
I'm not sure if that's it. I"ll take a pic of it when i get a chance. But, if you look into the grill, you'll notice that all air is blocked off. air will enter the grill, hit the rad, and stop there.
Reply
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Overlay grill? kgustaf Fit Bodywork & JDM Styling 9 04-18-2007 10:07 PM
Which grill do you like? fitfit Fit Bodywork & JDM Styling 11 03-31-2007 02:19 PM
Home Depot Grill Part 2 leonine Fit Pictures and Videos 46 11-03-2006 12:55 AM
Mesh Grill... Is it possible? kkim General Fit Talk 8 06-01-2006 12:01 AM
Mesh grill? sLiVeRwOrM General Fit Talk 9 05-20-2006 01:18 PM
Go
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
