We now offer Tein and H&R! Coilovers, Springs, Spacers, and Camber kits!
Old 07-19-2011, 01:32 PM
ShopFormFresh's Avatar
Former Vendor
Exclamation We now offer Tein and H&R! Coilovers, Springs, Spacers, and Camber kits!
Check us out on Facebook and Twitter!
Email: aaron@shopformfresh.com
Phone: 1-877-527-2261
Website: (under construction) www.shopformfresh.com
PM for pricing and availability!
Tein Basic Damper
TEIN type BASIC damper offers a high quality coilover system at an entry level price. Drivers will feel in increase in stability, and grip, while maintaining good ride quality on the street and freeway. A shortened shell case is utilized to allow for better ride and improved performance at lowered ride heights. BASIC damper is a great option for consumers wanting a simple and quality made coilover. Each application is test fitted and road tested to ensure the best possible balance between comfort and performance on the street. Includes ride height adjustment to give your vehicle a minor to major drop.
  • Steel Construction
  • Twin Tube internal construction
  • Larger piston diameter for strut type front and rear (22mm)
  • Ride Height adjustable via spring seat
  • Powder coated damper body with Zinc coated threaded section
  • 1-year Manufacturers Defect Warranty
  • Available for Overhaul
Tein Super Street Damper
TEIN Super Street damper kit was designed for drivers seeking improved handling on the street and at the track. A shortened shell case is utilized to allow the most piston stroke possible, which allows for a better ride at lowered ride heights, and increased grip at the track. Great for daily driving and occasion track use, whether it be at the drag strip, local circuit, or Auto-X course. Includes both ride height and damping force adjustment to allow the driver to dial in the suspension for various surface conditions.
  • 16 way adjustable dampers, compression and rebound combined
Tein H-Tech Springs
TEIN High.Tech springs utilize the latest spring and material technology to optimize comfort, performance, and quality. Designed and tested in North America to be used in conjunction with OEM or similar shocks for excellent ride comfort and slightly increased handling. The line is produced with Vanadium (SAE9254V), which is durable, lightweight, and has properties to retain more spring stroke. High.Tech springs are designed for those seeking a slightly lowered stance while maintaining high ride quality at a reasonable price. Most vehicles will attain a 1.2 inch drop for a more attractive appearance, added performance, and excellent comfort. Includes a one year limited warranty.
Tein S-Tech Springs
TEIN S.Tech Springs are an excellent step towards suspension tuning. They offer approximately a 1.5 inch drop for a more aggressive appearance and increased road holding capability. Designed to be used with OEM or OEM replacement shocks. Each application is road tested in North America for the proper balance between performance and comfort. Comes with a 1 year limited warranty, spring length is guaranteed not to sag more than 5mm, and be clear of any manufacturer defects.
H&R Sport Springs
Sport Spring kits are H&R’s number one selling product. Enhance the look of your vehicle with a reduced fender well gap. H&R Sport Springs lower the vehicle center of gravity and reduce body roll for better handling. The progressive spring rate design provides superb ride quality and comfort. A lower wind resistance signature will make the vehicle more streamlined and improve gas mileage. If you are only looking to improve one part of your vehicle’s suspension, you cannot go wrong with installing Sport Springs. Fun to drive, H&R Sport Springs are the number one upgrade for your vehicle.
H&R Track+ Wheel Spacers
Wider is Better! H&R TRAK+® Wheel Spacers provide simple and effective vehicle track widening for improved handling, performance, safety, and a 'perfect stance'. Featuring a 'perfect fit' hubcentric design, TRAK+® Wheel Spacers are extremely durable and lightweight thanks to a proprietary aluminum/magnesium alloy.
H&R Triple C Camber Bolts
When you lower a vehicle’s ride height, negative camber is increased — how much depends on the vehicle and the reduction in ride height. H&R ‘Triple C’ Camber Adjustment Bolts are a simple, yet very effective means of removing excessive camber, adjusting your vehicle’s camber settings, or even correcting small side-to-side camber variations for precise alignment.
Installation takes only minutes with readily available hand tools, and benefits include increased tire life, improved tracking and the ability to dial in more camber for weekend track events.
Quite simply, H&R ‘Triple C’ Camber Adjustment Bolts are a great value. No other single suspension modification can yield such impressive results with such a small investment in time and money.
Old 09-25-2011, 09:12 AM
ouchxx's Avatar
hey just wondering what is the lowest drop the teins coilovers can go?
Old 11-24-2011, 04:41 PM
Dj Aqua B1u3's Avatar
the price of all tein item
aallbbeerrtttttt
11-24-2011 09:25 PM
Arkaneinc
10-22-2008 01:27 PM
koshir
02-03-2008 11:50 PM
ascGD3
01-02-2008 10:51 PM
towelie
03-28-2007 12:19 PM
Quick Reply: We now offer Tein and H&R! Coilovers, Springs, Spacers, and Camber kits!
