Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Buy, Sell, Trade, Product Market Research and Group Buys > FIT-Vendor Sponsored Group Buys and Sales
FIT-Vendor Sponsored Group Buys and Sales Organize group buys to get discounts. Only Forum Sponsors may post group buys in this sub-forum. Forum Sponsors will have "FIT Vendors" in their user title and have gone through a screening process by FIT Freak staff.
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 11-25-2008, 07:29 PM
OJRKraftWerks's Avatar
Platinum Honda FIT Vendor
OJRKraftWerks relies on Rep Points to liveOJRKraftWerks relies on Rep Points to liveOJRKraftWerks relies on Rep Points to liveOJRKraftWerks relies on Rep Points to liveOJRKraftWerks relies on Rep Points to liveOJRKraftWerks relies on Rep Points to liveOJRKraftWerks relies on Rep Points to liveOJRKraftWerks relies on Rep Points to liveOJRKraftWerks relies on Rep Points to liveOJRKraftWerks relies on Rep Points to liveOJRKraftWerks relies on Rep Points to live
Send a message via AIM to OJRKraftWerks
KraftWerks Fit Supercharger Kits (Manual and Automatic!)
Fit MT Base Kit
Included Items:
• Rotrex C15-60 Supercharger at 5 PSI* with KraftWerks Supercharger Insert
• Rotrex Self-Contained Oiling System with Oil Cooler
• KraftWerks Recirculating Bypass Valve
• KraftWerks Automatic Belt Tensioning System
• KraftWerks SuperCard Engine Management Unit and MAP Stabilizer
• KraftWerks Aluminum Intake and Discharge Piping
• KraftWerks Silicone Hoses
• KraftWerks Oiled Air Filter
• KraftWerks 5-Rib Belt
• KraftWerks Brackets and Hardware
In Stock!
Fit AT Base Kit Included Items:
• Rotrex C15-16 Supercharger at 5 PSI* with KraftWerks Supercharger Insert
New Release! In Stock!
*Boost level is determined at sea level, and can change depending on modifications, weather, altitude, etc.
-CARB Pending-
About KraftWerks:
KraftWerks was started to house all of our Rotrex-powered supercharger kits by Jackson Racing. We believe the Rotrex product will be able to grow with this brand into the future.
KraftWerks is made up of us at Jackson Racing, with Oscar Jackson Sr. at the helm and the rest of our original Jackson Racing supercharger engineers. The same quality and technology that you have known of JR, will be with KraftWerks, and will be better than ever. We have improved our supercharger design techniques and have learned quite a bit on the Rotrex supercharger from recent testing.
KraftWerks will establish its own distribution by the time of the release of our new kits. No other companies will be responsible for the distribution of KraftWerks supercharger kits.
We appreciate the support of the Fit community very much! We are very excited about our new venture, and hope the Fit community is ready for some boost!!
The Fuel Electronics:
The SuperCard is a small digital electronics unit that is able to extend injector duty cycle in boost for the given condition. The SuperCard is not a "basemap" to get you to a dyno or to "get you down the road." Also, the SuperCard really isn't a "piggyback" by traditional standards.
We spend a lot of time testing to get the electronics to work perfect across a whole range of situations; much like a typical OEM manufacturer tests their cars to work across a range of situations. We take pride in our SuperCard electronics and other electronics. We have revolutionized a new way of tuning vehicles.
We use cell-phone technology to make our small SuperCard chips and boards, allowing us to have a compact unit. This makes it simple for our customers to install, and it works seamlessly with the vehicle; at all throttle positions, all altitudes, all temperatures, all conditions.
To produce a CARB-legal product, it has to work. But we take it a step further and not just pass CARB regulations, we make it so it performs on the track, at full throttle, on the street, idling in traffic.
The SuperCard sees injector duty cycle output and manifold pressure. The SuperCard contains proprietary software that is able to determine proper management for all different types of conditions.
General KraftWerks Kit Information:
-The KraftWerks kits and Rotrex supercharger have a 2 year limited warranty. This warranty is on the KraftWerks kit components and Rotrex supercharger. Rotrex determines supercharger warranty.
-The Base and High-Boost kits are made to be used on completely stock engine components.
-There will be an upgrade path from Base kit to High-Boost kit for MT Fit.
-The High-Boost kit and upgrade will utilize a Hondata Reflash and injectors.
-Any aftermarket cat-back exhaust can be used with the KraftWerks kits.
-Test pipes can be used, but in conjunction with our Injector Upgrade Pack.
-The stock MAP sensor is utilized in both the Base and High-Boost kits. No problems using the stock MAP sensor.
-The KraftWerks kits use a single belt in the system. We have extensively tested this serpentine drive, and have verified its capabilities. There is no slippage when using a KraftWerks drive system. We have had great belt life, and no issues with our belt drive's capabilities. Having a spare belt makes it easier when you decide to change your belt. You can change it instantly, and then order another spare or two from us while you drive around on your fresh new belt.
-We include an automatic tensioner with our kit (stock car uses a manual tensioner) to help increase constant belt tension and reduce belt slipping. The automatic tensioner also increases belt life.
We have had excellent wear (meaning low wear), and have had no belt related issues. But we would expect the customer to change the belt a little more often than stock, because the supercharged belt must work a bit harder.
-Fuel Electronics are always standard with our kits, and require no additional tuning.
-A/C is fully-retained
-Our kits have no check engine lights and are a full bolt-on system. Your factory OBDII system will work as normal with our kit.
-We will confirm international compatibility once our production pieces our available. We will be sending these pieces to Rotrex partners throughout the world to check Right Hand Drive Fit/Jazz. We believe that we should have no problems.Unfortunately, the kit will be available in North America only upon initial release. We will get out international testing complete, and then the kit will be available to all Fit/Jazz owners...
-In order to meet CARB specs, we have used the stock injectors with our SuperCard unit. And these stock injectors have been our big limitation, and we have reached the limit for the little Fit injectors. Remember this is the Base CARB pending kit. This kit is to be used with a stock header and cat.
We will be offering an injector upgrade package for those that want to do a header and cat-delete, and it will work directly with the Base kit. The upgrade pack is plug and play, and is a low $399.99.
We will be releasing a Hondata Reflash package as another option for header/cat-delete Fits. This reflash will add many new features for the Fit, including raised rev limit, removed speed governor, adjusted VTEC, etc. This option will also be upgradeable to the High-Boost kit!
The biggest performance gain you can do for your Base SC Fit is ultra-light wheels and high-performance tires.
The Rotrex Supercharger:
-The Rotrex is small; about the size of the turbo it competes against. It has a traction drive, but is sans the turbine of course.
-The Rotrex drive system is a planetary traction drive system. This patented drive allows the Rotrex to spin to extremely high RPMs. There is some calculated slip in the system, but it is very small. This drive has no cut gears, which allows the Rotrex to be ultra quiet.
-The traction drive system has been tested to over 500,000RPM! Compressors wheels will not live at that RPM though. The smallest Rotrex unit spins at 201,000 RPM all day long!
-It uses the same compressor wheels and housings as its turbo opponents, because the drive system can turn the proper RPMs.
-The Rotrex supercharger pumps its own Rotrex SX100 oil, so there is no need to tap the oil pan or add an oil pump. A small Rotrex reservoir is included, along with a small oil cooler for the Rotrex oil.
-The Rotrex SX100 traction oil should be replaced every 50,000 miles or 2 years. If you are doing some heavy track abuse, I recommend changing the oil more often. The bottle included with the kit will cover your first 50,000 miles or so under normal conditions.
-The ratio in the Rotrex supercharger never varies. The C15-16 and C15-60 superchargers used on the Fit kits have a 12.67:1 drive ratio.
-The supercharger pulley size changes the speed of the Rotrex, just like any other traditional supercharger.
Stock AT (Blue) vs new Fit Auto Base Kit (Red)
Stock MT (Blue) vs new Fit MT Base Kit (Red)
For general kit questions and interest, please email our KraftWerks Sales line!
Kraftwerks Home
Thanks!
-Oscar Jackson Jr.
__________________
Oscar Jackson Jr.
KraftWerks Supercharger Systems
Forced Induction Forum Sponsor
not all boost is created equal.
Sponsored Links
  #2 (permalink)
Old 11-25-2008, 10:01 PM
jeimusu86's Avatar
Frequent FitFreak Poster
jeimusu86 is a splendid one to beholdjeimusu86 is a splendid one to beholdjeimusu86 is a splendid one to beholdjeimusu86 is a splendid one to beholdjeimusu86 is a splendid one to beholdjeimusu86 is a splendid one to behold
any chance there will be a group buy for this?
  #3 (permalink)
Old 12-10-2008, 03:34 AM
LuxuryMods has a brilliant futureLuxuryMods has a brilliant futureLuxuryMods has a brilliant futureLuxuryMods has a brilliant futureLuxuryMods has a brilliant futureLuxuryMods has a brilliant futureLuxuryMods has a brilliant futureLuxuryMods has a brilliant futureLuxuryMods has a brilliant futureLuxuryMods has a brilliant futureLuxuryMods has a brilliant future
Send a message via AIM to LuxuryMods
Wow, I didn't know you guys were so close to me! I'm tempted to come see you for my AT Fit. How much is installation?
  #4 (permalink)
Old 12-10-2008, 07:02 AM
kSpec relies on Rep Points to livekSpec relies on Rep Points to livekSpec relies on Rep Points to livekSpec relies on Rep Points to livekSpec relies on Rep Points to livekSpec relies on Rep Points to livekSpec relies on Rep Points to livekSpec relies on Rep Points to livekSpec relies on Rep Points to livekSpec relies on Rep Points to livekSpec relies on Rep Points to live
No Christmas special?!
  #5 (permalink)
Old 12-29-2008, 08:14 PM
PM me about local installations!!
__________________
Oscar Jackson Jr.
  #6 (permalink)
Old 12-30-2008, 05:51 AM
kodo's Avatar
kodo relies on Rep Points to livekodo relies on Rep Points to livekodo relies on Rep Points to livekodo relies on Rep Points to livekodo relies on Rep Points to livekodo relies on Rep Points to livekodo relies on Rep Points to livekodo relies on Rep Points to livekodo relies on Rep Points to livekodo relies on Rep Points to livekodo relies on Rep Points to live
whats the price on the AT kit? and do you guys do install to if so how much?
__________________
  #7 (permalink)
Old 12-30-2008, 02:09 PM
PMed
-Oscar Jr.
__________________
Oscar Jackson Jr.
  #8 (permalink)
Old 12-30-2008, 04:42 PM
kodo's Avatar
hmmm time to start saving
__________________
  #9 (permalink)
Old 12-30-2008, 05:29 PM
trancedsailor's Avatar
trancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to live
Send a message via AIM to trancedsailor
when will the high-boost MT kit be available?
__________________
For Sale:: Progress swaybar, Weapon R trunk cage, right FX35 retrofit headlight. PM with offer if interested
1994 EG2 B16A3 acquired 9/3/09
  #10 (permalink)
Old 12-30-2008, 09:07 PM
Quote:
Oscar Senior is going to give the big, final thumbs up.... Then we are good to go!
-Oscar Jr.
__________________
Oscar Jackson Jr.
  #11 (permalink)
Old 12-30-2008, 09:27 PM
omg I'm beyond stoked for that *drool* you might make me re-enlist in the navy so I can afford it hahah
__________________
  #12 (permalink)
Old 12-30-2008, 10:14 PM
Shaggs2Dope's Avatar
Shaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to live
Looks like a super tidy kit. Just sucks even with boost an AT fit is puttin down an AMAZING 110hp. What's the price on the kit and how hard is it to install DIY and tune? CARB certs is a must
__________________
Aww, they love each other, but are jealous of who gets my attention
  #13 (permalink)
Old 12-31-2008, 12:16 AM
J_L's Avatar
J_L J_L is offline
J_L will become famous soon enough
This thing is so freakin' tempting...
__________________
'08 BOM sport AT
| mishimoto intake | blitz throttle control | T1R response header | T1R b pipe | tanabe touring medallion | progress sway | mugen visors | 30% tint | cheepo MB 7X | alpine iva-w205 |
  #14 (permalink)
Old 12-31-2008, 07:46 AM
SC whine > turbo blowoff ;D
constant power ftmfw!
__________________
  #15 (permalink)
Old 12-31-2008, 04:56 PM
redrumm's Avatar
redrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to liveredrumm relies on Rep Points to live
Quote:
install instructions are on the website.
__________________
ORDER 3 OR MORE BARS GET FREE SHIPPING!!!!
FOR YOUR GD3/GE8......http://ultraracingusa.com/
EMAIL: ultragd3@yahoo.com
mbarton@ultraracingusa.com
  #16 (permalink)
Old 01-02-2009, 12:56 PM
Quote:
Correct. Any questions about instructions, they are available on our website as a PDF.
-Oscar Jr.
__________________
Oscar Jackson Jr.
  #17 (permalink)
Old 01-04-2009, 01:46 AM
Hondady's Avatar
Hondady is a jewel in the roughHondady is a jewel in the roughHondady is a jewel in the rough
will there be a high boost kit for the auto version or are we only getting the 5psi kit? What about a hondata reflash for the auto? It would be nice with the paddle shifters!
__________________
Not Stock!!!
  #18 (permalink)
Old 01-08-2009, 01:25 PM
Quote:
We will not be releasing a High-Boost kit for the Auto Fit.
If we see enough demand for Hondata AT, we would of course look into it. Currently, we have no plans to release Hondata for Fit AT.
Thanks,
Oscar Jr.
__________________
Oscar Jackson Jr.
Last edited by OJRKraftWerks; 01-08-2009 at 07:25 PM. Reason: Adjust my statement...
  #19 (permalink)
Old 01-08-2009, 02:42 PM
eldaino's Avatar
eldaino relies on Rep Points to liveeldaino relies on Rep Points to liveeldaino relies on Rep Points to liveeldaino relies on Rep Points to liveeldaino relies on Rep Points to liveeldaino relies on Rep Points to liveeldaino relies on Rep Points to liveeldaino relies on Rep Points to liveeldaino relies on Rep Points to liveeldaino relies on Rep Points to liveeldaino relies on Rep Points to live
Quote:
We may release Hondata for Auto Fit, if we see enough interest.
Thanks,
Oscar Jr.
oscar i'm sure that EVERYONE rocking the a/t kit will show interest in a hondata version! especially if a highboost kit wont ever surface.
if said hondata version were to come out, would it at leat be boosting higher than the base kit version? maybe like at 6-7 psi?
__________________
if i could travel through time sometime....
pep pep?
Say Wha??? You mean, there's another reason to have a suspension?
Nah, foo...I want that ish slammed to the ground
I roll hard and I like my ride to represent, yo!
Hehe
  #20 (permalink)
Old 01-08-2009, 08:58 PM
Koi Koi is offline
Koi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to liveKoi relies on Rep Points to live
Still, you're getting a 20-25% increase in peak HP that you reach earlier, and around 33% increase in peak torque. All this without the trouble of turbo kits, although you can get more power increase from those. From what I understand from those who have this AT kit, it puts the Fit at just the right spot in terms of power - but whether or not the price is justified is of course your opinion. If I had the money for something like this, I'd be rocking it
Reply
Tags
09, 2009, charger, engine, fit, honda, kit, manual, parts, review, super, supercharger, superchargers, system, turbo, wear
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
KraftWerks Supercharger Kit Info v4.0 OJRKraftWerks Fit Forced Induction Forum 1024 11-08-2009 12:44 AM
Long (!) review of automatic vs. manual Fit Sport (US) Wessy General Fit Talk 235 03-13-2009 01:23 AM
KraftWerks Supercharger Kit Info v3.0 OJRKraftWerks Fit Forced Induction Forum 542 11-14-2008 08:38 PM
KraftWerks Fit Supercharger Kits OJRKraftWerks FIT-Vendor Sponsored Group Buys and Sales 19 09-13-2008 12:45 PM
KraftWerks Supercharger Kit Info v2.1 OJRKraftWerks Fit Forced Induction Forum 369 05-21-2008 02:46 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
