can a lowered fit use 15x8 wheels?
i have a fit that's lowered on springs and it's a pretty good drop (about a half-finger of wheel gap in the front). is it possible to run 15x8 wheels without having to roll my fenders?
Posts in the NUUDE
No... If the offset is higher possibly, most offsets on an 8in wide wheel is 30mm and lower.
If the offset is too high itll rub on the front strut or inside the fender wells.
To run any kind of offset and/or wide wheels on the Fit the fenders needs to be rolled.
I have 15x8 inch rims with +0 offset
I have a 3rd Gen 09 Fit with a 1.6 inch lowering springs what tires do you think I can run on 15x8 15 inch with a +0 offset?
Loopy
04-02-2012 05:52 PM
