never mind, I got it, I just took my fingernails to it, it peeled right off, then I cleaned it with a lil soap and water, good as new.
but I HATE reliance honda. those after taking off the front plate, I realized those bastards drilled a hole right through the middle of the front bumper! bah now I've gotta find some kinda plug to fill the hole...
1. Prep (clean) area using Meguiars Quick Detail spray
2. Heated up badge with the wife's hair drier. Held the dryer about six inches from the surface. Moved the dryer over the badge for about two minutes.
3. Since my badge was only recently applied, I was able to peel mine right off. The badge itself was flexible and one of the corners released nicely from the heat. I had my fishing line ready to go if I experienced any problems...
4. Re-cleaned the area with Meguiars Quick Detail spray. I could see some dirt that was trapped behind the badge.
5. Waxed the area using Meguiars Quick Wax spray.
Ok it's very easy. I work in the vinyl market, I cut them, print them, install and remove them. Pretty easy.
First of all, I'll present you your new friend !!!
If your decal isn't stick on the car since more than one year, you don't need any heatgun or hairdryer. You simply need your nails. Try to peel of one corner and the rest will follow.
**HINT** Put water (with a spray bottle) arround the sticker so it will prevent from "scratching/mark" the paint with your nails.
In most of the case you'll have little glue on the paint after removing the sticker (sorry, i'm french so my sentence are not always perfect), use the rubber cement to get rid of. Some people use paper towel but I find it hard on paint so I use kleenex cause it's softner.
So this is how you can get rid of your dealer sticker and/or any glue on the paint.
Lift an edge of the sticker with your fingernail.
Then pull off the sticker extremely slowly with your fingers - very little (if any) glue will be left on the car. By removing the sticker really slowly, you can actually see the glue lift off from the car and remain with the sticker. If some glue sticks to the car then just slow down.
Someone else mentioned leaving the car in the sun a few minutes to heat the sticker and remove the sticker promptly when you first get the car.
I purchased my Fit from David McDavid Honda in Irving, Tx. They use about a 4 1/2" by 4 1/2" plastic styleized chrome emblem shaped like the state of Texas with their dealer's name on it. It is absolutely hideous. I asked my salesman to have it removed before I took delivery. He stated that it might remove some paint. I told him if it does, I wouldn't but it. We argued about this issue for a few seconds, but it was removed without any damage to the car. I believe that no dealerships in California (at least Southern California) put their stupid names on vehicles. I understand that the majority of people probably don't care about this, but at least California cares about the customers that do.
As advice to folks waiting to take delivery of their Fits tell the dealer that you do not want them to put this on the car. If they do put something on the car do not take delivery of it until they remove it and you are satisfied with the paint in the area. I told my salesman ahead of time that I did not want any kind of dealer sticker on my car and they did not do it.
My two request when I went to make the deal on my Fit (1). No dealership logo on the back and (2). No front plate installed. They did both without any problems.
Cat :X
Ditto..
__________________
If it moves, try to race it. If not try to eat it.
Agreed, Hair Drier works wonders!! A little soap and water to remove sticker or badge resedue afterwards and your done.
For those "plaque" type logos, it can sometimes help to get a piece of dental floss behind the plaque and slowly cut between it and the paint, through the adhesive. Then you can work on the adhesive with heat guns and solvents, etc.
simple, as stated: hair dryer is your best bet, safe. Don't just plainly use your finger nails though! Get some heat a little water and go at it carefully.
__________________
Engine mods: A-spec CAI and axle back (burnt)
Inside: JDM Passenger visor, Zeta dead pedal, JDM Squash, Skunk2 ss + knob
Shoes: 16x7(+45) Polished Rota Slips Pirelli 205/45
Suspension: Tanabe GF210
Lighting: 6000K HID low, 4300K custom yellow HID fogs, DC5 sidemarkers, independent fog light switch
Misc: 20% tint, Rear red H emblem
