Fit FREAK.net
Go Back   Honda FIT Forums > Buy, Sell, Trade, Product Market Research and Group Buys > Gauge Interest in a Fit Product or Group Buy
Reply
  #1 (permalink)
Old 08-18-2008, 01:55 AM
goodspeed is an unknown quantity at this point
*Pivot Raizin+6pts Silver Grounding(EThrott)@$140*
Dear ExLancer member,
Volt Stabilizer "RAIZAIN" from Pivot, this brand is a famous volt stab in Japan.
Click on the Below link to see the Details and Benfits from "Raizain"
http://pivotjp.com/product/frame-vs-1-e.html
Confirm from Japan, if not full refund.
NOTICE OF FAKE RAIZIN
http://pivotjp.com/imitation/imitation-raizin-e.html
Grounding Services
In addition, I will be providing 6pt grounding services with SILVER coated 10AWG Grounding wire @$60.
Esp for New cars Version which have E Throttle device in their car, our 6 pts grounding will also include the throttle body to help in the responses.
Grounding and the Piovt Vs, improve the performance by producing more stable ignition. This is brought abt by the double effect of strengthened earthing system. This will increase the torque @ Low and Middle speed, Increasing engine reponse.
Anyway grounding and Piovt VS is not new product, have being in the market for a few years. read up more online or u can give me a call at 91462635 so that i can give u more infos.
Why Silver Grounding wires? How does benefits it you?
•Check your car’s existing grounding pts material, you will be surprised to see that it is the same as the material we are using. We follow strictly the sample layout from car makers so that it will not introduce any complications or side effects. We only want to maximum the existing electrical system of the car.
•Most of the grounding services only provide wires that are made of copper as it is cheaper and less conductivity. We are using silver which are better in term of conductivity.
•Silver has the highest electrical conductivity of all metals. In fact, silver defines conductivity - all other metals are compared against it. Because of this property, and because it doesn't spark easily, silver is commonly used in electrical circuits and contacts. Silver is also utilized in batteries where dependability is mandatory and weight restrictions apply. Copper wires are heavier.
Pics of wires
Promotions
Package A
Silver coated Earth Cables 6Pt Grounding only
$70
Package B
Pivot Raizin Volt stabilizer only
$85
Package C
Pivot Raizin Volt Stabilizer with silver earth cables with 6 grounding pts
$140
Addition Information
As most of us know, most car makers in order to save cost will reduced the amount of grounding pts in the car as wires are expensive. Therefore most shops or grounding services does grounding with copper wires. Many people think of copper wires as something that has great electrical conductivity. But you will be wrong. Silver and copper are very different in terms of electrical conductivity and also copper wires are heavier in weight. The different between us and the others we used “Silver” earth cable
Check the following website for details in conductivity.
http://www.lehigh.edu/~amb4/wbi/kwardlow/conductivity.htm
Don’t just listen to me. Just check your car existing ground pts and you will see that they also used silver earth cables for grounding purpose. I believe that the car makers know their work with the tons of research and investment in the car making biz. I am just following the sample layout by the car makers instead of adding in addition foreign/different wires which may introduce more complications or side effects.
Nick/Contact no.
1)
2)
3)
4)
5)
6)
7)
10)
You can contact me, Randall@ 96344979 OR Alvin@91462635 to discuss about the installation or queries. If you live near Amk or Sengkang i can even show you example of the grounding pts.
Sample pics of the installation
Below is a sample of the testing we show to the owner after we finish the grounding. we will do a amp/current test to show that the wires are all connected/Live and running. In addition, we will grease all ur connection pts esp the +/- pts of the Battery with hi-temp grease so that it will not rust.(Rusting will cause the connection pts to decrease in current, as there are impurities)
More pics on recent installations
Jazz
Points to be taken, recently was help a bro installing his used pivot I noted that there are more and more Imations in the market now. Below is the attached drawing.
Just some pointers to share, capacitors for the RAIZIN show be “K” shape, not “T” or “-X”
In addition, the pivot products I selling have Serial No. so that if you are installing with me, I will copy down your license plate and pivot Serial no. for reference.
Take note that this is the proper way manufacturer recalling back products. Do not buy products that don’t offer serial no. as they will be most likely be Imations as there will be no way the manufacturer can recall which products are defects.
Integra
FD Civic Type R
Mitsubishi Colt R 0
Lancer EX
Fiat Pundo
Sponsored Links
  #2 (permalink)
Old 08-18-2008, 11:21 PM
CuTeBoi's Avatar
CuTeBoi will become famous soon enough
isn't this the same as a good high quality copper wiring used in generators or sold in electrician shops?
and isn't the "stabilizer" portion just the same as a CAP loaded? I know I use 2 small sized caps for the starter and the other for the rest of my circuits, this way my lights never dim, and the other portions of my car never have to dip low with the current.
__________________
Got Speed?
  #3 (permalink)
Old 08-19-2008, 08:54 AM
chrisng's Avatar
chrisng will become famous soon enough
what exactly is the benefit of a product like this?
__________________
2008 Fit Sport AT - Storm Silver Metallic
2008 Civic Si Sedan - Galaxy Grey
2006 MINI COOPER S - Hyper Blue/White (totaled )
2006 Acura MDX Touring -Gray
  #4 (permalink)
Old 08-19-2008, 02:02 PM
Firstly bro. my wires are silver coated not copper.
stabilizer from pivot are super condenser not CAP.
Lastly we have a DC AMP metre to show customer the amount of AMP gain from electrical loading like air con and head light. This should be the true test and prove to customer that our wires and connection are correct and working.
of cos i am always open and learning from customer and people from the forum. so far all questions are answered. hope i have done so with ur questions.
  #5 (permalink)
Old 08-24-2008, 03:29 AM
CuTeBoi's Avatar
Free bump for ya.
What is the benefit of silver coated as opposed to pressure mounted raw copper? why the extra metal? shiny? and what is a "super condenser"? What does it claim to do? from experience in life, a condenser is what is used in Air conditioners... to catch moisture and dispose of it via catch pans...
This feels awkward.
a cap would be just as efficient, an Am-meter would also be available on some nice CAP models, to show amp usage, and how much it actually is using.
This seems like extra wiring and a box that could be in the way.
I so need to get wiring for my Fit and do the setup.. The civic EF has all the caps, and a relocated battery.
Cap == Capacitor
__________________
Got Speed?
  #6 (permalink)
Old 08-24-2008, 01:23 PM
Free bump for ya.
This feels awkward.
Cap == Capacitor
Bro...let me answer to my best knowledge
Q1:What is the benefit of silver coated as opposed to pressure mounted raw copper? why the extra metal? shiny?
A: Silver has a lower resistance than copper. So have a real silver wire is too ex...thats y coating only. Outer apperance is shiny.
Q2:what is a "super condenser"?
Ans:Electrical condensers converts signals i.e electrical noise to electrical impulse.
Q3:A cap would be just as efficient, an Am-meter would also be available on some nice CAP models, to show amp usage, and how much it actually is using.
Ans: A Cap stores charges so when you ICE demand more than rated, the Cap actually gives out power too sustain your ICE. Our Ammeter measures the current flow in the newly installed cables whereas most Cap shows the voltage level. 2 different items. Even if the Cap can show amps, it cant tell much becoz the cap is not hook up at the engine bay. CAP doesnt not have electrical noise suppression whereas VS has. Thats Y VS is a voltage stabilizer. It stabilize the voltage by using their internal components. Cap primary function is to sustain the ICE power.
Tks
  #7 (permalink)
Old 08-29-2008, 06:36 AM
The NEW Pivot Raizin Stock Have Arrived for this week fresh from Japan, Pivot have only changed New Packaging last mth, our prove to customers that all Goodspeed-jp products are direct from JAPAN and not so old stock!!!! Don’t miss out this time as I only bring in 10units.
Pls click on our website for further informations on other products…
Where the Legend Begins... - Powered by CO.CC
NEW LOOK for the Pivot Raizin Ver2.0 2008 Model
21th GP INSTALLATION for Pivot Raizin+6pts Silver Grounding@ $140 WITH One Year Warrenty for the forum members only!!!
INSTALLATION SLOT Date and Time: Sat 29/8/08 , 3pm
Location : Sengkang East RD/WAY Blk 261 Deck 5B, feel free to join us for viewing and discussion
Call/SMS me at 9146 2635 or 9795 0918 to confirm a slot for the Pivot Raizin@ a discounted price of $80 taken together as a package.
A) Package will be $140 VS Pivot with 6pts silver groundings.
B) 6pts customize Silver earth cable will be at $70
Current Status : 21th GP Installation Closed!!!
Recent Installation: Daihatsu BB
Reply
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
White or Silver Fit? Please help me decide. ProMed General Fit Talk 21 07-02-2008 11:58 PM
Rear Bumper Needed 2007 Silver Storm Sport gcisko Fit It Yourself : Discuss Do It Yourself-Repair and Maintenance 1 05-12-2008 05:23 PM
Fit Party.... Part Deux ComposiMo Fit Pictures and Videos 16 12-27-2007 08:34 AM
Storm Silver Metallic.. More silver or gray? aznguyen316 General Fit Talk 13 03-25-2007 12:16 PM
Storm Silver Sport MT availability in DFW? wannahaveafit General Fit Talk 15 06-23-2006 05:50 PM
Go
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
