undercarriage underpanel cover from GK to GD/GE
After seeing pictures of the GK's undercarriage from Jimmy's thread here: https://www.fitfreak.net/forums/3rd-...aka-fitty.html
It got me thinking about the possibility of retrofitting it to other Fits.
The part number is 74641-T5R-A00
74641-T5R-A00 | Honda COVER, FR. FLOOR (LOWER) - Bernardi Parts
#20 in diagram
Don't have the funds to spend $265.93 plus oversized shipping on it so the search to eBay and Craigslist I go for someone parting out a GK.
This combined with the CRZ front underpanel
https://www.fitfreak.net/forums/2nd-...ed-my-fit.html
should improve airflow and increase MPG nicely.
Thoughts?
#20 in diagram
Thoughts?
Start by managing the air before it becomes a problem, with a grille block and air dam. Quick, cheap and easy to make, and easy to keep from looking stupid:
Once you've cleaned up the overall shape and minimized the airflow underneath the car, you can worry about smoothing out what's left- including engine bay ventilation. I haven't had to modify mine yet to allow more airflow, but I'll probably have to pretty soon. As you can see, the stock airdam could use a little extending before underbody panels would be able to do their best.
The way you get less drag on the bottom is by reducing the amount of air that gets under there. Pop the hood and look at the big grille and how all if that air is channeled under the car. Smoothing out the flow can only help so much if you're using your front end as the intake to a big compressor. The biggest benefit is from reducing the amount of air in the first place.
A cleaner shape is higher performance whichever way your priorities lie. Is less drag a bad thing because it will also save gas?
I had a speed run yesterday. Crappy traffic in the beginning, then highway for about 35 miles. I kept it over 65 except for the tolls, mainly keeping it between 70-75. Not much hypermiling gets done under those conditions, but I got 40 and change for the trip.
Aero mods are even more effective at higher speeds.
ROTTBOY
117
11-22-2020 03:36 AM
tfc_bee
24
10-25-2019 05:04 PM
Extreme Dimensions
41
06-06-2012 04:58 PM
