Fit FREAK.net
Go Back   Honda FIT Forums > The Honda Fit and Jazz Forums > General Fit Talk
Reply
  #1 (permalink)
Old 06-17-2008, 10:21 PM
RichXKU's Avatar
Senior Member
RichXKU will become famous soon enough
Wheel bearing failure people check in!
I searched the warranty repair thread but did not see any wheel bearing issues reported.
The car had been parked for about 10 days, and I used it to run ~ 14 miles of errands today. On the way back from errand 1 I started noticing a slight hum around 40 MPH. Heading out on errand 2 it was more pronounced, as if I had a mud tire on the left front wheel. If i steered to the right it got louder (more pressure on the left front wheel). If I steered left it got quieter. All signs point to a wheel bearing.
I searched Fitfreak and found others with the same issue, which turned out to be the wheel bearing.
Members:
Chango
OCKC
TrickyPantz
Shady (rear)
Threads:
Odd Sound
http://www.fitfreak.net/forums/fit-t...=Wheel+Bearing
I will get it to the dealer as soon as I can and follow up.
__________________
'07 Fit Sport 5MT | '05 WRX STi
-CleanMPG.com, the real Eco forums.
Sponsored Links
  #2 (permalink)
Old 06-17-2008, 11:43 PM
kirko is an unknown quantity at this point
Generally speaking, you turn into the bad wheel bearing. If you steer left, and it gets louder, its the driver side, etc. This is because there is less of a load on the bad bearing, which allows it to vibrate more. So it sounds like you have a bad passenger side bearing. Wheel bearing should be covered under 3/36 warranty, get it taken care of, it will continue to get worse.
  #3 (permalink)
Old 06-18-2008, 12:00 AM
Senior Member
Darkstars is just really niceDarkstars is just really niceDarkstars is just really niceDarkstars is just really niceDarkstars is just really nice
^^ that is false, the OP has it right.
__________________
2008 Honda Fit Sport 5-Speed
Honda all season floor mats, Honda cargo cover, "Fit" emblem removed, front "H" blacked out, rear "H" shaved, Mugen window visors, window tint - 15% on the back 35% on the rest, Mishimoto CF chambered intake, 15" bronze Konig Heliums w/ stock sport tires and TPMS sensors, Muteki blue lugs, Progress Springs, Progress rear sway bar, LaminX on the fogs, Oracle 3000K HID foglights & a Tom Tom GPS.
  #4 (permalink)
Old 06-18-2008, 12:36 AM
ricohman can only hope to improve
Its a quick and easy fix. Unit bearings can fail like anything else.
No big deal.
  #5 (permalink)
Old 06-18-2008, 01:44 AM
mdm427 will become famous soon enough
Quote:
I second that^^^
When you lean on the bad bearing, it will growl louder.
  #6 (permalink)
Old 06-18-2008, 02:23 AM
Quote:
Originally Posted by mdm427 View Post
I second that^^^
Not all the time.
When I worked at a large GM dealer we had an endless train of X-cars with bad front wheel bearings.
Some were so bad the entire front of the car would moan and groan. A quick turn of the wheel to the right or left would reveal which bearing (or both) was bad.
And yes, placing load on the noisy bearing would quiet the bearing. Especially if the seals had failed and it was running dry.
  #7 (permalink)
Old 06-18-2008, 06:14 AM
Quote:
Originally Posted by ricohman View Post
Not all the time.
Okay, I'll give you that. There are always exceptions to everything. Let me re-word my statement;
Every wheel bearing I have ever changed on my personal vehicles, and those belonging to friends and family, has made more noise when you put additional weight and side load on it by turning in a direction opposite of the side that the bad bearing is on. This includes both front and rear wheel drive vehicles.
While we're on the subject of bearings, here's the tip of the day...
NEVER go for the cheapest bearing you can find! They simply don't last. You don't necessarily have to go with OEM bearings (although it's usually a safe bet), just make sure they are a quality brand such as Timken, Moser, SKF, etc.
  #8 (permalink)
Old 06-18-2008, 12:56 PM
wdb wdb is offline
Senior Member
wdb will become famous soon enough
No big deal.
It is a big deal if they're failing prematurely. I don't know about you but I don't want to be replacing them every 10,000 miles.
  #9 (permalink)
Old 06-18-2008, 01:31 PM
Quote:
Warranty will take care of that.
Just a fluke. Probably had a manufacturing flaw.
  #10 (permalink)
Old 06-18-2008, 01:40 PM
Fit_to_be_tied's Avatar
Senior Member
Fit_to_be_tied has a spectacular aura aboutFit_to_be_tied has a spectacular aura aboutFit_to_be_tied has a spectacular aura about
its an imperfect world, poop happens. i had a sledge hammer from home depot that broke the third time i hit something.stop being panic nancys
  #11 (permalink)
Old 06-19-2008, 12:03 PM
wdb wdb is offline
Senior Member
Quote:
No one is in a panic. Just some folks trying to harness the power of duh intuhnet to see if these instances are indeed flukes or if there may be some larger issue linking them together.
  #12 (permalink)
Old 06-20-2008, 08:14 PM
RichXKU's Avatar
Senior Member
It's currently at the dealer, they agree it's the wheel bearing. It went from nothing, to noticeable, to LOUD in about 50 miles, starting tues.
I should have it back tomorrow.
Rocking the loaner 08 Civic LX til then.
__________________
  #13 (permalink)
Old 06-20-2008, 08:39 PM
Looks like your the only one checking in...................
  #14 (permalink)
Old 06-21-2008, 01:15 AM
RichXKU's Avatar
Senior Member
I already searched out and posted the other 4 members in the first post. 5 issues out of the relatively small sample size on fitfreak seems to be a high percentage. Many recent Civics were recalled for wheel bearing failures, so it wouldn't be the first time Honda made some bad ones.
__________________
  #15 (permalink)
Old 06-21-2008, 12:29 PM
Well, of the past 50 wheel bearings ive done in the in the least 3 or so years at work, i would say 95% of them have been the side that I have stated above, including my own (in my old aveo). I havent had a bad one in the Fit though, yet. It seems to be a toss up though if youre worried about them going bad in the fit. Of the million wheel bearings that are made, not all of them are perfect, and they will fail, my Aveo only had 8k on it when it failed. I would say its not an issue with Fits, but there are some exceptions of course.
  #16 (permalink)
Old 06-21-2008, 05:50 PM
wdb wdb is offline
Senior Member
Quote:
Given that bearing manufacture is very automated, very measureable, and very repeatable, I expect their success rate to be in the 6 sigma range -- 3.4 bad parts per million. If they're hitting that rate they may not be bothering to QA every part, so the odd bad bearing could certainly get out of the factory. What is odd is the number of reported issues on fitfreak.net, which is a far smaller sample size. Statistically speaking, 5 reports from this forum is significant. Put those two together and I'd conclude that the issue is not a bad bearing, but some other problem such as inadequate lubrication, misalignment, or what have you.
I would disagree. However it does appear that all of the reports are from 2007 cars, so it may be something that they caught and fixed already.
  #17 (permalink)
Old 06-21-2008, 08:36 PM
Thats funny because i was about to say that but you beat me to the punch. Driving habits, where you live (e.g. bumpy roads), alignment, lowering, etc all have an effect on wheel bearings.
  #18 (permalink)
Old 06-21-2008, 10:10 PM
kenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond repute
bearings are not unusual to fail on a lot of cars. they're probably
using the same supplier(s). my stock legacywgn's bearing gave out
around 12k miles. roared like a DC10 on the expressway.
__________________
08 FitSport Storm Silver Metallic (5MT)
Suspension: EnduraTechs
Dressup: Black fog lamp surrounds, Megan axle-back.
Wheels: DragDR21 15x7 +40mm, Ziex912 195/50/15
Int & Ext: Factory a/s floor mats, Zeta deadpedal,
factory trim kit, JDM visor, JDM door handles, MOMO Champion,
Daikei hub 20mm spacer + AS01 adjust, RecaroYoung Sport
child seat VivoLite, TypeR style satin shift knob, Zeta cargo cover,
Mugen window visors, ONYX metalized 30% tint.
ICE: JVC Arsenal HU
  #19 (permalink)
Old 06-22-2008, 03:06 PM
RichXKU's Avatar
Senior Member
At any rate the bearing was replaced, everything is back together (and quiet).
As it turns out they also performed an alignment, and the car had a factory out-of-spec toe-in condition on both front wheels which they corrected.
__________________
  #20 (permalink)
Old 06-22-2008, 04:18 PM
Honda doesn't make wheel bearings.
It will be a subsidiary supplier.
I have changed thousands of bearings in my 20 years as a mechanic and for modded vehicles the most common failure was due to increased offset.
Especially on lifted trucks.
Reply
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
FIT Yahoo Autos Reviews alclssus2020 General Fit Talk 43 07-12-2007 04:07 AM
New Car Inspection Super Orange Fit General Fit Talk 4 05-09-2007 03:39 AM
Rear Civic wheel bearing update. r2000swler@hotmail.com Other Car Related Discussions 5 09-21-2005 11:31 AM
2001 Accord maintenance question / concern ... Leon Kiriliuk Other Car Related Discussions 24 05-04-2005 05:44 PM
2001 Civic EX check engine light acidic@tokyo.com Other Car Related Discussions 0 05-04-2005 12:16 PM
Go
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
