Yikes! Side panel seam is molting!
OK guys and gals - I need your opinions. I had noticed about a month ago that the side panels that meet with the front bumper was starting to peel its paint. I had a rock chip my front bumper last weekend and had to order some touch up paint from Lester Raines. I mentioned the peeling
paint and the guy said to let them take a look when I came in to pick up the touch up paint. Those guys at Raines Honda are totally awesome! They did not even charge me for the touch up paint and came right out to look over the peeling paint. This is what it looks like:
Well, Honda will replace the front bumper under my paint warranty and there will be no cost to me. They will have to keep the car for two days and this will be OK because one of my co-workers lives a few blocks over from me. Now they can not guarantee that the paint will be a perfect match but I will get a new bumper for the front which will also take care of the rock chip - so what do you guys and gals think. Should I go ahead and let Honda do a replacement and paint or should I just use some touch up paint and hope it works. The guy in service said that the part that is peeling is plastic so it would not rust but he also can not promise that it won't happen again.
Let me know your opinions - they want me to call them on Monday so they can order the parts and paint.
Thanks for your opinions and recommendations
Cat
Cat
where do you find these? i have searched time and time again and never seen this bulletin. nor have i ever the sb on the dash rattles
Let them do the replacement, of course. Without proper surface prep, paint ALWAYS comes off. That will happen to your touch-up job. It's not your problem, it's Honda's problem. Let them fix it.
Mine is doing the same thing in the same spot. My thought is this is happening because of the 2 or 3 times the front has bottomed out over steep driveways or such. Mine is not quite as bad yet so I will wait some time before I bring it in. I'd definitely let the dealer do it for sure.
I agree with the above; Let them repair and repaint it under the warranty so that if it happens again it's documented and still covered if necessary. You didn't mention why they told you they cannot guarantee the color match, so just in case they didn't inform you (or for those unfamiliar with body work), I'll just briefly mention the main reason. Essentially, the paint they we be applying is the OEM color as it would have come brand new. Given that you've had your car a while, the color will gradually fade over time. However, if you've regularly waxed your car you shouldn't see a shade matching issue and it should all blend in nicely.
Best of luck in the repairs. I'll be watching my bumper from now on to see if this problem comes up. Glad to know there's a TSB for it though. Thank you for mentioning that Fit_to_be_tied
Thanks to those of you who replied. I will give them a call on Monday and tell them I need to schedule. I have given the car at least 4 wax jobs before this happend. The car still looks as good as when I first purchased as far as the color goes it's just the swirl marks that drive me nuts.
Will post up some pictures of the replacement bumper for you guys to see how it went. I just hope I can handle two days without my MR Fit! I will have to join the Fitless crew as a temporary member.
Cat
Cat
Cat
Cat
If its a dealership and they're taking care of the issue they may give you a loaner car...
Cat
If they will do it for free get it done, and you'll be saving gas those two days getting a car pool anyways
With the new one, look into getting a clear type of Scotchguard 3M clear bra or something. These cars have low budget paint and will probably start flaking within 3 years.
Cat
YES!!! I constantly get stuck going behind an expedition or durango or some other monstrosity driving 10 under the speed limit on this 10 mile stretch of road with no passing areas these days. Makes me get so mad lol
