i had an issue with this yesterday. i went to have my alignment done after i installed my skunk2 coilovers and the first guy that "did the alignment" took the wheel off.. which never should have come off.. and idk what he did. but i ended up taking it back and having the original guy who always does my alignments re do it. easy fix. so i go home.. and oh GREAT my new wheels are in. i get the tires mounted and wheels balanced and when i get home to take my wheels off.. turns out the dumbass who did the first "alignment" stripped all 4 of my studs out. 1 broke off. 3 stripped.. completely messed up my lug nuts, which i just bought cost me over 100 for them which pissed mee off more.. so now i need a new set. this was on my front driver spindel.
anyways back to the proccess.
oreilys didnt hve them when searched on the computer, but i have a good friend who works there. he contacted the customer support and they found a match for the studs, appearently 88-00+ hondas are all the same?.. go figure. but anyways i spent maybe 9$ with his discount for 8 studs only needed 4. but original price was about 2.90 a piece.
steps :
1. Take the wheel off
2. Take off the (2) 17mm bolts on the back of the caliper. move caliper out of the way
3. Use an impact screw driver to un do the screws that hold the rotor on.
4. keep the car out of gear so you can rotate the spindel.. and use a hammer to pop the studs out of the back..
5. Get new stud and insert. itll be a bit crooked when first going in and your dust shield will probably get beat to shit (mines horrible, yet functionable. just smashed in a little on the side needed to make room to work)
6. use the hammer to beat the studs through the back as close as possible.
7. i put lock tight on the back of all the studs to help with the hold
8. i put the car in gear and used a lug nut to suck the stud up, it gets pretty difficult.. had to beat the back in a bit in the proccess of sucking it up with a lug nut.
9. after this, the stud should be flush with the spindel.
10. (repeat steps 4-8 for the rest)
11. Re assemble the rotor using lock tight on both screws, also make sure to use an impact screw driver for this step also.
12. after rotor is on re assemble the caliper with the (2) 17mm bolts
13. add wheel and lug nuts.. should be good to go.
i ruined a whole bunch of lug nuts tightening the studs up to the spindel so be sure to use spares when you guys are doing this.
Hope this helps a lot of people.
