Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > The Honda Fit and Jazz Forums > General Fit Talk
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #21 (permalink)
Old 07-29-2009, 02:14 PM
pharmpk has a reputation beyond reputepharmpk has a reputation beyond reputepharmpk has a reputation beyond reputepharmpk has a reputation beyond reputepharmpk has a reputation beyond reputepharmpk has a reputation beyond reputepharmpk has a reputation beyond reputepharmpk has a reputation beyond reputepharmpk has a reputation beyond reputepharmpk has a reputation beyond reputepharmpk has a reputation beyond repute
Something else I've noticed with the fans that seems unusual. The service manual seems to suggest that at below 199*F with a/c on only one fan should run. However, our two 09 Sport Fits both run both fans if you have a/c on when you first start the car (the coolant temp is well below 199*F). Does this happen for others? Maybe a US 'option'?
__________________
Cargo cover and tray
Carpet Floor mats
Body side moldings
Indoor/Outdoor Temperature gauge
  #22 (permalink)
Old 07-29-2009, 02:25 PM
spreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to live
Quote:
Both fans operate with the A/C. If the A/C is off only one fan will operate.
  #23 (permalink)
Old 07-29-2009, 02:29 PM
Quote:
OK, thanks. On my Fit, under 204*F with no a/c neither fan runs, then at > 204*F they both run (from memory).
__________________
Carpet Floor mats
Body side moldings
  #24 (permalink)
Old 07-29-2009, 09:03 PM
2trips is an unknown quantity at this point
I'm pretty sure the thermostat doesn't open until 170F.
I drove my fit from san diego to Utah a couple of weeks ago, and the hottest it got was about 210. that was with ambient temps at over 100, but the car was constantly getting good airflow.
The first time I climbed this one super-steep hill in first, the temp "soared" to 205 and I got so worried, lol.
  #25 (permalink)
Old 07-29-2009, 10:16 PM
secondspassed's Avatar
secondspassed relies on Rep Points to livesecondspassed relies on Rep Points to livesecondspassed relies on Rep Points to livesecondspassed relies on Rep Points to livesecondspassed relies on Rep Points to livesecondspassed relies on Rep Points to livesecondspassed relies on Rep Points to livesecondspassed relies on Rep Points to livesecondspassed relies on Rep Points to livesecondspassed relies on Rep Points to livesecondspassed relies on Rep Points to live
When the car is moving the "ram air" is usually enough to cool the engine. When the A/C is on the radiator and A/C fans operate with the compressor to cool the condenser coil, which also cools the radiator. When you are not moving (with the A/C off) this cooling air flow is eliminated and you rely on the radiator fan to cool the engine. This fan does not come on until the coolant reaches 210*F and cycles off at 200*F. So sitting still temperatures above 200*F are normal. I have never seen mine above 215*F
repped!! awesome info.
  #26 (permalink)
Old 08-03-2009, 01:35 AM
Neebs relies on Rep Points to liveNeebs relies on Rep Points to liveNeebs relies on Rep Points to liveNeebs relies on Rep Points to liveNeebs relies on Rep Points to liveNeebs relies on Rep Points to liveNeebs relies on Rep Points to liveNeebs relies on Rep Points to liveNeebs relies on Rep Points to liveNeebs relies on Rep Points to liveNeebs relies on Rep Points to live
Is it still fluctuating?
__________________
'09 Milano Red MT Ge8 w/ Navi
'98 Milano Red Ej8 Squad #226, retired. Thieves :thumbdown:
Honda, The Power of Dreams
Nikon User: D80, D700
MyFlickR
Reply
Tags
ac, damage, diego, engine, fit, heat, honda, hot, run, running, runs, san, scangauge, shutting, temperature, traffic, turns
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
INSTALL HELP: Spoon Engine Torque damper suketoborudo00 AJ-Racing.com 43 04-22-2009 04:52 PM
Engine braking bad? Gordio General Fit Talk 15 04-25-2006 10:00 PM
Re: Hood insulation / engine heat thinking gmccx Other Car Related Discussions 0 05-04-2005 12:16 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
