New Fit! Two observations:
Old May 12, 2006 | 07:05 PM
eyedryve's Avatar
1. I know I'm sitting on 10 gallons of fuel. Does anyone else hear it just sloshing around under you? Not loud, but obvious. Strange...
2. The front suspension sounds kinda clunky. I just don't remember this type of sound at all on my 95 Civic sedan. Doesn't sound loose, but not muffled either. Could just be related to the relative lack of sound deadening in this EconoHonda.
I love it though. Great car. Handles great- virtually no body roll, just turns. Awesome.
Any opinions of 1/2 above?
-eyedryve
Old May 12, 2006 | 07:22 PM
GoFit's Avatar
Someone that Posts too much
1. it's there but not enough to annoy.
2. No clunking sound from Front suspension here.
Old May 12, 2006 | 07:32 PM
Moonchild's Avatar
I did not notice the sloshing during test driving. I tested 3 at different places also. Each time gas tank was totally full..I assumed they were expecting a lot of testers. After purchasing and driving home 38 mi and then driving it the next day I did hear it sloshing. After using very little fuel, without the radio on even, I no longer hear it. Now tonite I filled up for the first time..no sounds again.
Old May 12, 2006 | 08:31 PM
bobbied's Avatar
I hear the sloshing sometimes on initial startup and movement. I could be wrong but I also heard that the tank had a vacuum system to eliminate sloshing. Maybe the vacuum takes some time after inital startup to kick-in which is why we hear it sometimes.
Old May 12, 2006 | 09:14 PM
eyedryve's Avatar
Yikes.
I hope it's not just MINE doing the sloshing. If I stomp the brakes to a stop- it knocks back and forth down there for a while.
Old May 12, 2006 | 09:44 PM
benfal2001's Avatar
The gas tank is still in a protected spot in the middle of both ends of the car in case of crash. Safer isn't it ?
Old May 12, 2006 | 11:40 PM
aziatiklover's Avatar
Master FitFreaker
I guess......
Old May 13, 2006 | 12:04 AM
Clear Lake Fit's Avatar
Fix for the sloshing fuel: Turn up the radio!
Old May 13, 2006 | 02:03 AM
Paulo107's Avatar
the sloshing!!! I heard it, but i guess i have tuned it out
Old May 13, 2006 | 10:03 PM
dougiepants's Avatar
Avid FitFreak Poster
1) Never heard it
2) Fit handles better than most modified EG's & EK's I have tuned for customers...
Old May 15, 2006 | 01:00 AM
circa86's Avatar
Originally Posted by dougiepants
1) Never heard it
you should tune them better no logical reason why a Fit would handle better than a well tuned EG or EK.
Old May 15, 2006 | 01:18 AM
timemachine's Avatar
The tank is in the center of the car.
Old May 15, 2006 | 02:16 AM
RacerDre's Avatar
didn't notice anything but I DO AGREE that the Fit handles awsome for being so tall. can't wait till some suspension upgrades.
Old May 15, 2006 | 02:31 AM
Master FitFreaker
yea for being tall I call it my mini van or jdm egg
Old May 15, 2006 | 09:28 AM
Mesaba's Avatar
That sloshing will happen until the tank is broken in which is around 600 miles according to the owner's manual. After that the tank manifold tightens around the fuel pump bearings and the noise should stop unless you haven't changed the blinker fluid which should also be taken car of around 600 miles.
Old May 15, 2006 | 12:29 PM
cheffyjay's Avatar
Don't you usually wait until the muffler bearings go before replacing the blinker fluid?
Old May 15, 2006 | 12:37 PM
Daņiel's Avatar
Do I need to change the air in the tires at 600 miles?
Old May 15, 2006 | 12:58 PM
cheffyjay's Avatar
yes, the factory air is too tippy.
Oh what have we done to this thread...
Old May 15, 2006 | 01:04 PM
Daņiel's Avatar
But then I won't have JDM air.
Old May 15, 2006 | 01:12 PM
b17gsr's Avatar
I just ordered some cross drilled brake lines and radiator by-pass kit! WOOT WOOT!
