Oil Life indicator reliable??
I like the oil life indicator, gives me another option for checking the oil. I continually check the oil to see it's color and viscosity, along with paying attention to the number of miles between oil changes.
And I usually go for the overkill frequent oil changes. It helps more than hurts . And is one of the reasons why my old 13 year old Mazda is still working well. I prefer to spend a little bit more money here and there to have my car last longer. I am the type of person that will drive a car until it dies.
Oil changes are very cheap and infrequent compared to using gasoline. People are so worried about giving more money to oil companies, you should then worry more about your driving habits to optimize your fuel economy. You will waste alot more money per year on gasoline than from frequent oil changes.
50 years of oil change history
Originally Posted by siownschu
actually. i spoke to a lot of honda mechanics (some work and some DO NOT work for honda) and basically they only extended the "oil change" schedule due to competition with toyota and other major car makers. The engines themselves have not changed much and especially the oil has not changed much at all
they recommend following the "old school" maintence schedule
reason they say this is because they've already seen some major problems and breakdowns after a few years of driving (probably after the regular warranty) on the 2002 and above models of accord and civics
but hey its up to you, extra $20 every few months vs a broken down car that will cost you a few thousand later on is up to you
Originally Posted by Andrew
1000% agreed. Love your Fit? Change that Oil. Mobil one is even better but changing every 3000 matters most.
The interval on my Jetta was 10k miles, but I noticed that around 7k the oil would start to disappear, so I always changed it 5-6k miles, mobile one 5w30. No data for the Fit yet from me... but given that the motor is newer than vw's vr6, and less power/heat, and less/smaller cylinders for exhaust to slip by, the oil should last even longer.
Originally Posted by sillypuddy
for all of them, i have follow my own schedule of 4000km oil changes with castrol syntec.. when it comes time to remove the valve cover for the valve adjustment, the honda dealer or my mechanic always comment on the lack of sludge in the pan compare to other customers who does oil changes at the recommended 8000km interval.
I'll trust the minder as to what interval to change the oil. I've been doing the same with our Odyssey, and the oil is still clean when I dump it. Honda knows how to build motors, and they know how to make them last.
i went to my mechanic yesterday to do my 4000 oil change and he actually refused to do it, not time yet he said
I spoke w/my warranty administrator today and she said as long as you followed the car's computer maintenance recommendations that the car will be fine. It's set up to adjust according to your driving and conditions. She didn't change her own oil until it was almost 10k. We did agree though that regardless of the recommendations we would change it at at the latest 5k.
Because our yearly driving conditions can vary widely from 32C to -32C I checked the Honda Canada site and found this info regarding the maint.
minder.
http://honda.ca/HondaCA2006/YourHond...TrimID=261&L=E
By the way, anyone notice the Indy 500 used all Honda engines and not one engine failure?
minder.
I am glad I changed my oil. Yes, I feel better about the oil life indicator capabilities, but will still change my oil more than most. WHY? Because I live in rural, DUSTY, minnesota. The oil life doesn't take into consideration dust. I am also planning on changing my air filter earlier too. If you lived on rural roads you would understand my concerns. In the winter I will not be as concerned about dust so please don't ostracize me for paying a little money for upkeep in the summer months. By the way, I had 38.4MPG on my first full tank after changing the oil. That's is with the sport auto.
#32
I don't understand why people who don't want to change their oil is giving the guys who do a hard time
you do your thing
i do mine
in terms of the milk ****ogy, I had bought milk that has an expiration date of one month, but after two weeks, it started to slowly go bad.. so do i keep drinking it and blindly follow the expiration date? NO.. i take into consideration other circumstances, such as the dust issue noted above.. then make an INFORMED decision
yes, honda say they won't void your warannty, etc.. but when it comes to it later down the road, outside of your warranty period, who pays? YOU do
i have 7 hondas in my family and the first 88 accord lasted almost 550 thousand miles
-joe
you do your thing
i do mine
-joe
#33
you do your thing
i do mine
in terms of the milk ****ogy, I had bought milk that has an expiration date of one month, but after two weeks, it started to slowly go bad.. so do i keep drinking it and blindly follow the expiration date? NO.. i take into consideration other circumstances, such as the dust issue noted above.. then make an INFORMED decision...
-joe
you do your thing
i do mine
-joe
#36
#38
After reading all the back and forth about when to take the Fit in for its first oil change, I called the service dept. where I bought my Fit and asked about the oil life indicator and whether I should rely on it for the very first oil change. He said yes -- with the caveat that I should not wait beyond the 10% mark. He assured me that I could trust Honda and the owner's manual and not worry about advice to the contrary. I have talked with several people who hang onto their cars for many years and I get a number between 3,500 and 7,500. My mechanic (Honda certified) says 3,500.
On another related topic -- I heard that manufacturers of some of the new vehicles are claiming that the transmissions do not require a fluid change at all. I can't remember what she bought, but a lady I talked to at a service station told me she was advised to replace the whole transmission at 30,000 miles rather than attempting to flush it out! Anyone heard of this?
#39
I love the justification people constantly come up with for wasting resources.
What are you checking an oil's color for anyhow? To see if it's doing its job?
#40
In regards to what the "lady at the service station" told you...that is absolute lunacy. Just another typical, shady ass, corrupt service station trying to make $1k+ on a job.
For MT cars, assuming you are using Honda MTF, I would suggest changing the fluid every 10k miles. Honda's MTF has been known to shear under extreme conditions and, in order to protect the tranny, I would play it safe and change it every 3 oil changes or so. I wouldn't worry so much about ATF...every 30k miles or whatever the manual calls for.
