Update on my Trailer
As I've stated before... In 2008 I went from a full size 2006 GMC Sierra truck to the Honda Fit. Not much after I added a hitch and wiring kit to the Fit for both a bicycle carrier, and a trailer.
I am using a 4'x8' folding trailer that stores upright and only takes up about 5'x2' of floor space. It works great for those occassional duties where you need some open storage like a truck bed.
I helped 2 people move this past weekend, and it gave me an opportunity to update the sides I use on the trailer. I mounted the sides outside the staked 2x4's to allow using more then 4'x8' of storage space on the trailer. I also replaced the bolts and nuts I was using to attach the sides with drilled out bolts with cotter pins, plus corner stake connectors. This allows for easier and much quicker removal/installation of the sides... which need to be removed when folding and storing the trailer.
I have under $400 in the trailer (with all new parts), and it's been a great addition to the "tool" collection.
Thanks.... yes, this one is the HF one. I like the Northern one just a little more, but it wasn't worth the extra $ at the time. The only real difference between the 2 is the way the tongue is setup.
Thanks for posting those pics. I thought they both carried the exact same trailer, but they're obviously a little different.
- Dustin
- Dustin
On page 238 of my 2010 owner's manual it states:
Towing a Trailer
Your vehicle is not designed to tow a
trailer. Attempting to do so can void
your warranties.
Note is says "can" not "will"... Who gets to make that determination?
Towing a Trailer
your warranties.
I remember reading a post from an Australian owner that the owners manuals with their cars says the Fit can tow a trailer..I don't recall what the weight limit is.... I have pulled a number of cars with a tow bar and VW pickup on a trailer with a 60HP VW pickup. I had no problem at all by doing it...In the owners manual that came with my recently purchased 1998 Cadillac Eldorado it restricts towing weight to 1,000 Lbs... I'm pretty sure that the restriction weight so low not using a trailer at all is due to the distribution of front to rear weight on FWD cars... You might have a problem if you have to hit your brakes while in a curve or rounding a corner with a heavy on it...If a Goldwing can cruise at 70+ MPH with a small camping trailer, I can't see why a Fit couldn't safely do likewise.
I think there are a couple of reasons the towing disclaimer is in the manual. One is to (try to) protect Honda from lawsuits when someone has an accident while towing, possibly because they were pushing the car beyond its limits. Another is to avoid having to do warranty work on parts that were not actually defective, but that were destroyed by being used beyond design limits. Similar situations arise from damage from overloading with too much weight or from high-speed track racing—the damage would not be covered.
There are a fair few cars that are rated to tow moderately sized trailers in Europe but are incapable of towing in the United States, despite having little or no difference in design.
