Anyone try taller tires on their Fit mt?
So what I hear, is that final drive ratio in hi gear doesn't effect mpg, but an extra pound of tire weight does.
How come people are saying the a/ Fits get better mpg on the highway than the m/t its? Do you not think it's the gear ratio? Changing tire diameter, has the same effect as changing the gear ratio.
Am I wrong here?
Am I wrong here?
I could be wrong but I think the OP is talking about a modest change to a taller tire that would reduce rpm's a little on the hwy and possibly gain a little mpg
Taller tires are a bad idea. It isn't going to help MPG and it will just throw your alignment off. As far as filling the wheel well better, it's not the way to do that either, you're better off to lower the car. A taller tire might fill the space a little more but it's also going to raise the entire vehicle and look goofy.
tire size does NOT effect alignment
Lowering my car will not fill in the wheel well. There are still the sides (front and rear of tire)
Im lowered 2 inches, a half inch taller tire equals a quarter inch all around, not much of a difference, but a minor difference can make something look better.
It wont make it look goofy, you wont even notice such a small change in height
I doubt it would have much if any effect on mileage. The aerodynamics are what determine that on the highway along with the weight. The biggest benefit I see is it might ride a little bit better with more rubber.
I agree with others--taller does not necessarily mean better MPG. Even getting lighter tires seems to only have negligiable amount of MPG gains. I've tried 185/60/15's tire (Yoko AVID), which is about the same size as stock and bit lighter. Unfortunately, saw virtually no increase in MPG. Handling definitely suffered, though. I think I will go back to 195/55/15's and at least have some of the fun back.
If I were truly going for better MPG, I think I will go to light 14" rims paired with Mich Destiny/Defenders (185/65/14).
Actually lighter tires will work wonders for MPG, given the new tires have the same or reduced rolling resistance
a pound off the tire is similar to removing 4 pounds in rim weight. (this is a rough rule of thumb)
Grab something that weighs a few pounds, get on an office chair that spins, and compare spinning with teh weight against your chest and the weight held outstretched
You will notice the closer the weight is to you the easier and longer you spin.
Same idea of simply cutting outer weight from anything spinning.
I'm rolling on 195/65/15 25" diameter (1 inch larger)
my tires feel little bit lighter than the base tires with steelies.
smother ride, but almost bouncy lol i think i went too far. go with 1/2" inc in diameter
mpg is about 35
mpg is about 35
bigger diameter or heaver tires reduce mpg and acceleration. putting larger diameter tires will reduce gearing by the ratio of old vs new tires which is the equivalent of lower gear ratio..
generally speaking, bigger tires of both diameter and weight will work fair when there is little change in elevation and little acceleration and deceleration because the drop in engine rpm reduces mpg when only constant speeds are observed.
klutzyfool
09-05-2010 11:51 AM
