Door locks and ignition
Hello,
My first time posting, I have a 2009 Fit. I've replaced the driver's side door lock once already, and it is already acting difficult again: basically I put the key in and can't get it to turn. I've also had to replace the ignition assembly. (Honda picked up the tab for the part even though it was just out of warranty; I had to pay labor).
I've owned two Civics in the past and never had this problem. Am I just having bad luck or does Honda not make them like they used to?
fpgill
fpgill
Are you pulling the door open with your key? Some people use it like a handle and it breaks things.
If it keeps happening it might be worth spending $40 or whatever to get a blank key with the remote control doorlock and stop using the key (I assume you have a Base Fit as the Sport comes with remote on the key). You would just use the remote part for the lock and use your regular key for the ignition.
Hello,
fpgill
fpgill
upallnight
07-09-2018 11:07 AM
