Is the M/T officially dead???
#41
You are correct. Accordguyintake posted the press release and the 6th is identical to the GEs 5th. Since the engine has a little more,power it should slightly lower RPMs nonetheless.
#42
RPM x gearing x tire size = speed. How does more power behind the rpm change any of that? I could see it in an auto or a CVT where slip can happen all over the place, but with real, honest-to-God gears just doing their thing?
#43
I also read that the final drive might be lower ratio. Thus 6th gk is the same as 5th ge, but overall ratio is lower
#44
final drive alone does not determine that. The gears hemselves can be changed.
A good example is Hondas old DOHC ZC gearing. it had a 3.8 final drive, yet that transmission was shorter overall then the american Civic SI trannies. Putting an SI final drive really woke it up furhter (4.25 or 4.4, depending on market of source)
#45
I'm still happy I got my GD. The only car that has me itching for an upgrade right now is the Ford Fiesta ST. 197hp! Still the GK Fit is a sweet deal for 16k.
#46
I was giving an alternate explanation.
I meant if both were the same ratios, but final drive was 3.4 vs 3.8, that would drop the rpms 10% at same speed.
#49
Go to Ireland and tell me how many A/Ts you find...
I can't do a 5-3 or 4-2 downshift with paddles
When and if they no longer offer M/T i'll just buy an older car. When and if they no longer offer gasoline engines I will do the same. No different than grandpa who still thinks a 4 barrel carb is better than EFI right
Yeah i'll be "that guy".
#50
Surely that depends upon the situation, no? It seems to me that you ought to shift (smoothly) into whatever is the best gear for the current situation, if you aren't there already; and if that's more than one gear away, so be it. Perfunctorily passing through any intermediate gears is just a waste of time IMHO, and merely makes one look and sound busy, but not necessarily professional.
#51
i go 5-3 or 4-2, even 5-2 when needed. doesn't matter if you skip gears. the most wear would be the syncro's if you force it into the gate.
obviously one would blip to rev match.
#52
who cares about looking and sounding professional?
If Im cruising in 5th and decide I need to pass some slow person, dropping it directly into 3rd and punching the gas takes care of the issue.
Rev matching is not to look or sound professional. Rev matching prevents damage to teh mounts and damage to the bearings inside the transmission. Any sudden lurch does damage!
#53
I've only owned one automatic in my life. That was my first car, and I bought it used. Every new car I've bought was a manual transmission.
Today, I consider the manual to be a theft deterrent, since so few people know how to drive one.
#54
Cannot really call a manual a theft deterrent.
#55
Of course not. That'd be silly.
Carjacker caught because he couldn't drive stick-shift
Springfield police: Would-be carjackers thwarted by manual transmission
Would-be carjackers foiled in Seattle, couldn't drive stick
Nobody'd ever believe that sort of thing.
#56
It's been known to happen.
Two would-be carjackers in St. Petersburg foiled by car's stick shift | Tampa Bay Times
Carjacker Foiled By Stick Shift; Unable To Drive Away - 7NEWS Denver TheDenverChannel.com
Judge Recommends Car Thieves Learn How To Drive Stick
The Court of Appeals for California's Third Appellate District was not impressed at all. This is what they had to say:
We strongly discourage anyone from choosing crime as a career. Nevertheless, as with any pursuit in life, one should be prepared. For instance, if you are planning to carjack someone, you should make sure you can drive a stick-shift.
#57
Needs Change
During the past 40 years, I've lived in a rural county that has many long steep inclines. I never even considered owning any car that did not have a manual transmission. Before that, I was into British sportscars -- 'nuff said.
Two years ago, I moved into town. Now I rarely drive out through the countryside---where all of the hills are. Around town, the manual transmission now seems like a whole lot of unnecessary work.
I am presently looking for a new Honda Fit LX with automatic. There's a first time for everything. I'm no engineer, but the CVT system seems like it would be far less slushy than past automatic transmissions. The fact that the CVT pulls substantially better MPG figures than the M/T seems to bear this out.
#59
The thing is, with the Auto on the Fit you get the paddle shifters, which gives you almost the best of both worlds. It's kinda fun to "help" the car drive sometimes by using the paddle shifters. It feels good doing more than just steering and accelerating lol!
I have a ton of fun finding the power band with the paddles on my way back from school.
Not to say that I don't like manuals, I love manuals, just don't got one. I'm happy with the auto.
I have never understood why anyone would pay MORE money to make their Fit slower, less fun to drive, less reliable, and more expensive to repair. With such a pathetic amount of power on tap our cars are slow as molasses with an auto.
Have fun staying neck and neck with a Prius (it does 9.8 0-60)
The exceptions to this argument are the elderly and the disabled (anyone physically unable to operate a clutch pedal).
#60
The Fit is as slow as a Prius with the auto...the Prius does 0-60 in 9.8 seconds if I recall.
My GE is a manual and with 0-60 in about 8 seconds flat is reasonably quick.
This like a totally different car...8 seconds is respectable (think NEW 4cyl Camry).
Not to mention the well documented mpg discrepancy with the M/T- it is much better than EPA estimates. I get 33mpg mixed driving if I drive it like a go-kart most the time, 36mpg mixed with normal driving style, and 40mpg highway regularly. Calculated at the pump, not based on what the car says (it is usually optimistic by 0.5mpg or so).
