2005 honda fit, keyles starting.
I have a 2005 honda fit with the climate control and cvt transmission. And the part where the key goes in is like a plastic thing that allows the key to be inserted.. but that plastic thing can also be covered up. And on the cover it says push/turn to start. Which would only mean that i can start the car without the key.. but i cant with the only key i got. It is a single button remote key, which needs to be inserted then pushed and turned to start the car.
I'm wondering how to get my cat to start without a key
You need something called a "smart card" that's slightly larger than a credit card. With that, you don't need to use a key.
I have one for mine, but it's a hit or miss thing for auto locking. The idea is you just walk away and it will lock itself. It certainly will 9 times out of 10, and if it doesn't, it will make a BEEP BEEP noise letting you know it didn't work. Rather embarrassing.
Jensen Healy
03-17-2017 02:38 PM
jelliotlevy
02-11-2009 08:12 AM
