Fit FREAK.net
Go Back   Honda FIT Forums > North America FIT Forums & Clubs > Canada Fit Forums & Clubs > Greater Calgary Community
Reply
  #81 (permalink)
Old 08-08-2008, 12:54 AM
Mr_ET's Avatar
Honda Fit Forums Moderator
Mr_ET has much to be proud ofMr_ET has much to be proud ofMr_ET has much to be proud ofMr_ET has much to be proud ofMr_ET has much to be proud ofMr_ET has much to be proud ofMr_ET has much to be proud ofMr_ET has much to be proud ofMr_ET has much to be proud of
Quote:
Originally Posted by Illusive View Post
LMAO! Best justification for oil EVER! It sounds cool hahaha! Deal, how many litres does the Fit take again?
4 quarts I think it`s around 3.7-3.8L or something like that.
__________________
2008 VBP Fit LX M/T
3m clearbra
Keyless entry
Sport Spoiler
Zeta dead pedal
JDM centre console w/ armrest
  #82 (permalink)
Old 08-08-2008, 01:05 AM
Illusive's Avatar
Administrator
Illusive is a splendid one to beholdIllusive is a splendid one to beholdIllusive is a splendid one to beholdIllusive is a splendid one to beholdIllusive is a splendid one to beholdIllusive is a splendid one to beholdIllusive is a splendid one to behold
excellent. I just joined the bobistheoilguy.com site for help. Looks like people are recommending Mobil 1, AMSoil, or Vavoline. I think I might go AMSoil
__________________
Mugen - T1R - J's Racing - Spoon
Fitfreak.net Admin! Fear the PINK WRATH! =)
Got a question? I might have an answer, drop me a PM if you need help!
- KillerFit #10 -
KRAFTWERKS Kit Owner #5
  #83 (permalink)
Old 08-08-2008, 02:17 AM
Sugarphreak's Avatar
Master FitFreaker
Sugarphreak should get some awardsSugarphreak should get some awardsSugarphreak should get some awardsSugarphreak should get some awardsSugarphreak should get some awardsSugarphreak should get some awardsSugarphreak should get some awardsSugarphreak should get some awardsSugarphreak should get some awardsSugarphreak should get some awardsSugarphreak should get some awards
It's official, I am going Royal Purple on the 16th
Props to ET and JP for hooking me up
__________________
  #84 (permalink)
Old 08-08-2008, 10:13 AM
Mr_ET's Avatar
Anytime buddy
__________________
2008 VBP Fit LX M/T
3m clearbra
Keyless entry
Sport Spoiler
Zeta dead pedal
  #85 (permalink)
Old 08-08-2008, 10:40 AM
Illusive's Avatar
Administrator
lol we will all be running different oils
__________________
- KillerFit #10 -
  #86 (permalink)
Old 08-08-2008, 11:59 AM
YeeFit's Avatar
Frequent FitFreak Poster
YeeFit has much to be proud ofYeeFit has much to be proud ofYeeFit has much to be proud ofYeeFit has much to be proud ofYeeFit has much to be proud ofYeeFit has much to be proud ofYeeFit has much to be proud ofYeeFit has much to be proud ofYeeFit has much to be proud of
Fancy and expensive oils. lol...
__________________
T1R Type-S Turbocharged Jazz
T1R Type-S Turbo Kit @ 8.5psi
HKS SSQV Ver.II Blow Off Valve
J's Racing / Showa Suspension
15" Enkei RPF-1
T1R Mid Pipe/Oil Cooler Kit/V2 Stabilizer
Greddy Ti-C Axleback
Mugen Vent Visor/Short Shift Kit
Innovative Mounts 75A Kit
Prosport Gauges
Hallman Pro RX MBC
  #87 (permalink)
Old 08-08-2008, 12:25 PM
Illusive's Avatar
Administrator
lol...I think I'm just gonna go with M1...since its $31 for 4.4L right now at Crappy Tire...and I can use it on the G as well
__________________
- KillerFit #10 -
  #88 (permalink)
Old 08-08-2008, 08:07 PM
Master FitFreaker
Pretty much like everything else! We are definitely one diverse crowd of Fits.
__________________
  #89 (permalink)
Old 08-09-2008, 05:27 AM
YeeFit's Avatar
Quote:
Agreed... We've got a KWSC fit, a NA tuned Fit, a soon to be T1R turbo'd Jazz, a bunch of bolt on peeps, and a soon to be HKS turbo'd fit!
2:21am... taking a break from the turbo install. So far so good, instruction manual can definitely use a little work... No major road blocks yet, so far so good... I started at 5:30pm.. so after almost 9hrs of straight install me and a buddy have installed the turbo, manifold, injectors, new spark plugs, tapped the oil pan, oil feed line, oil return line, oil sandwich plate, wastegate, dump pipe, down pipe, up pipe, intercooler, blow off valve, and intake.
Not bad IMO lol... gonna tackle the rest of the intercooler piping, oil cooler, emanage, gauges, and vacuum lines tomorrow....
I think if things good well tomorrow too, I should be all done and good to go by Sunday!
ET, I really hope you can stop by on Sunday to double check my work before I start to crank it over..
I'll give u a call in about 10 hours or so to confirm!
__________________
15" Enkei RPF-1
Prosport Gauges
Hallman Pro RX MBC
  #90 (permalink)
Old 08-09-2008, 10:18 AM
Mr_ET's Avatar
Ill stop by tomorrow for sure.
Looks like you guys made some good progress.
Had fun with the injectors?
When you say you tapped the oil pan did you remove it or leave it on and if you left it on how was it cleaned after?
__________________
2008 VBP Fit LX M/T
3m clearbra
Keyless entry
Sport Spoiler
Zeta dead pedal
  #91 (permalink)
Old 08-09-2008, 12:35 PM
YeeFit's Avatar
Great.. thanks ET.
We did make decent progress, but there's still a fair amount of work to do...
The injectors actually weren't too bad.. it was a bit tight, but they squeezed in nicely
For the oil pan, I removed it completely.. drilled it and installed the oil return fitting. I washed it out completely since it was off, then reinstalled it with the high temp gasket maker and new gasket. it was fairly easy to remove and reinstall..
I noticed that my kit is missing the silicone hosing that connects all my boost/vacuum lines.. does anyone know where in town I can get this stuff? I'll need a couple different sizes..
__________________
15" Enkei RPF-1
Prosport Gauges
Hallman Pro RX MBC
  #92 (permalink)
Old 08-09-2008, 04:10 PM
Mr_ET's Avatar
Quote:
Originally Posted by YeeFit View Post
Great.. thanks ET.
Hey Adam call me so we can work out tomorrow, Princess auto will have the stuff you need for your gauges and home depot can hook you up with some fittings if need be.
Jon and I just finished another front bar install today
__________________
2008 VBP Fit LX M/T
3m clearbra
Keyless entry
Sport Spoiler
Zeta dead pedal
  #93 (permalink)
Old 08-12-2008, 01:04 AM
YeeFit's Avatar
Jazz Turbo!
Big thanks to ET for coming all the way up to the NW to look over my install!
I love it.. the turbo spools up nicely and really pulls.. I haven't really pushed it too hard yet.. maybe 1/2 throttle.. I'll be cracking her open real soon tho!
The car is running ok, there's a couple of little glitches, but I will look at fixing them soon. I think I need to adjust the idle a little between 500-1000rpm.. i am finding it hard to get going from a stop without bringing the rpms to above 1000... I was told that if I just adjust the idle/fuel at 500-1000rpm all will be well.
I do have a CEL tho. Hopefully I can get Justin to check it out with his scangauge soon. I talked the Ben and AJ-R and he said there is a new map coming out at the end of the month.. it'll fix the CEL that I have which is a barometric pressure sensor issue. The new map is supposed to be pretty good as i'm told.. they are just tweaking a few little things to make it run smoother.
I hope to have this for the 30th.. if not, then I will just do the regular dyno w/o tune.. and then maybe go back for a dyno tune after I have the new map loaded!
We'll have to have a meet soon so you guys can all check it out!
__________________
15" Enkei RPF-1
Prosport Gauges
Hallman Pro RX MBC
  #94 (permalink)
Old 08-12-2008, 01:39 AM
Master FitFreaker
Very nice! Glad to hear things are working out, I am sure the tuning glitches shouldn't be too hard to resolve. Can't wait to check it out!!!!
I should be ready, I got word today my new manifold is on it's way from Cali. I have to do a swap when it gets in, should be straight forward. Then borrow Justin's scanguage and get rid of that annoying Low-EGR CEL forever!!
__________________
  #95 (permalink)
Old 08-12-2008, 09:22 AM
Mr_ET's Avatar
So Nick if it`s on it`s way, any chance of it being here Saturday? We could probably swap it out if it is
Adam anytime buddy, I guess the cel came back on as soon as I left eh? Your car is probably running a slight bit too rich at cold start idle and it`s creating the slightly sligish acceleration from a stop and the low idle for those few seconds on start up.
The generic basemap you have is not for your specific setup so a dyno tune should fix all those issues and give you a safe and taylored solution.
With that said I`m with you on waiting for the other basemap from Ben and going from there.
__________________
2008 VBP Fit LX M/T
3m clearbra
Keyless entry
Sport Spoiler
Zeta dead pedal
  #96 (permalink)
Old 08-12-2008, 11:19 AM
YeeFit's Avatar
Ya, it came on right after you left.. lol..
I think I have a boost leak now too hehe.. I was driving to work this morning and everything was good.. then all of a sudden I couldn't hear the BOV anymore and I wasn't seeing any boost on my gauge. I took a closer look and the hose clamp on the turbo outlet isn't tight.. atleast from what I could tell.. when I wiggled the pipe a bit and the hose clamp on the turbo outlet moved with it.. i think if it was really tight it shouldn't move at all should it..?
I'm gonna go check it out in a little while here.. just gotta get the right tools together and have my morning coffee!
__________________
15" Enkei RPF-1
Prosport Gauges
Hallman Pro RX MBC
  #97 (permalink)
Old 08-12-2008, 11:48 AM
Master FitFreaker
That would be pretty kick ass
Last time it wasn't too bad for the WR manifold shipping but you never know with the shipping from the US. The UR pulley kit was a bit of a nightmare
__________________
  #98 (permalink)
Old 08-12-2008, 12:36 PM
Mr_ET's Avatar
all clamps should be tight and any hose should flex but not be able to rotate on the pipe it is connected to.
__________________
2008 VBP Fit LX M/T
3m clearbra
Keyless entry
Sport Spoiler
Zeta dead pedal
  #99 (permalink)
Old 08-12-2008, 12:37 PM
Mr_ET's Avatar
