08-25-2008, 11:59 AM
Administrator
Illusive's Part Out
Just a reminder to all you Calgarians, I'll be taking her apart (EVERYTHING) this coming Saturday. If you wanna give us a hand, feel free to drop by. If you want anything, likewise drop by. Everything is up for grabs, the more out the door that day, the better
__________________
Mugen - T1R - J's Racing - Spoon
Fitfreak.net Admin! Fear the PINK WRATH! =)
Got a question? I might have an answer, drop me a PM if you need help!
- KillerFit #10 -
KRAFTWERKS Kit Owner #5
08-25-2008, 12:31 PM
Honda Fit Forums Moderator
Quote:
epic part out
__________________
2008 VBP Fit LX M/T
3m clearbra
Keyless entry
Sport Spoiler
Zeta dead pedal
JDM centre console w/ armrest
08-25-2008, 12:38 PM
Master FitFreaker
Very Epic, wish I had a VBP Fit right now
I will see if I have time, if so I can stop by to help. I have mad flashlight skillz yo!
__________________
08-25-2008, 01:15 PM
Administrator
It'll be UBER EPIC!
__________________
- KillerFit #10 -
08-25-2008, 04:01 PM
Senior Member
It'll be UBER EPIC!
WHY?????????????? Supercharger too?
__________________
All go and no show
Skunk2 Pro-C coilovers 8k/6k
DC2-R front brakes w/ SS lines
Progress Rear Sway Bar
Kraftwerks 5psi S/C kit
J's Racing LSD (For Sale)
Exedy Stage 1 Clutch
Fidanza 7lbs Flywheel
私は粘土をもっと憎む
08-25-2008, 05:35 PM
Master FitFreaker
Quote:
He is going to a better place now...
see post "Should I!?!?" under calgary section
__________________
08-25-2008, 11:48 PM
I am stuck way up north for another two weeks. Otherwise I'd drop by and say "hello" to you guys. If I didn't have to pay my daughter's tuition at U of C, I'd probably take a few items off your hands. Oh well, guess I have to wait until she graduates before I get any high ticket items. Next is wheels and tires and I'll be sure to get your advice first  ...maybe in the spring when my bonus gets paid out... <sigh>
__________________
2007 Fit DX | 5MT : ScanGaugeII
: WeatherTech Vent Visors : SilverStar ULTRA's : Zeta Dead Pedal : Broadway Convex Mirror : Mangowalk Stubby Antenna : Polk Audio db651s : Stainless Muffler Finisher
08-26-2008, 09:26 AM
Quote:
If you ever need an install pm me or JDMish and we'll look after you man.
__________________
2008 VBP Fit LX M/T
3m clearbra
Keyless entry
Sport Spoiler
Zeta dead pedal
08-26-2008, 11:20 AM
Master FitFreaker
Hey ET, the manifold arrived at Justins house. He is busy this week with something so I will probably pick it up when I come by for the part out (maybe while Justin is parting out, I can part-in in the driveway...  )
Justin, I will bring by my stock manifold cover as well so you can put it in ASAP and then whenever you flip your fancy mugen-style one you can just give me a stock cover back later on.
__________________
08-26-2008, 12:28 PM
Frequent FitFreak Poster
Is there a list of stuff going??
__________________
OEM > *
Need OEM parts? PM me
08-26-2008, 12:38 PM
Quote:
he has another thread started for the parts list on the local buy/sell..
I'll come help one of the days for sure.. and I might wanna get my grubby little hands on some things.. maybe...
__________________
T1R Type-S Turbocharged Jazz
T1R Type-S Turbo Kit @ 8.5psi
HKS SSQV Ver.II Blow Off Valve
J's Racing / Showa Suspension
15" Enkei RPF-1
T1R Mid Pipe/Oil Cooler Kit/V2 Stabilizer
Greddy Ti-C Axleback
Mugen Vent Visor/Short Shift Kit
Innovative Mounts 75A Kit
Prosport Gauges
Hallman Pro RX MBC
08-26-2008, 01:33 PM
Master FitFreaker
You should get the Test pipe with the extra bung so you can hook the wideband AF to your E-Manage and let it tune itself  Apparently it can "Auto-Tune" if you have a wideband hooked up.
__________________
08-26-2008, 01:38 PM
Quote:
really? it will do that? I wonder how reliable the "auto tune" feature would be..
__________________
15" Enkei RPF-1
Prosport Gauges
Hallman Pro RX MBC
08-26-2008, 02:39 PM
It should keep the AFR's in check and allow you to monitor it as well.
__________________
OEM > *
08-26-2008, 03:00 PM
Master FitFreaker
Not sure if the E-manage Blue does that, but I was reading about it in the manual for the Ultimate.
No idea how to use it or how good it is, but would sure save you some cash on tuning it everytime you change something!
Here is a blurb I found about it on MX5, lots of good information on how to use it. Section 13 of the post is specific to autotune.
Everything You Need To Know... - MX5Nutz
Quote:
The autotune feature will ONLY work:
1) If wideband is properly set up in the EMU. To test if it is running properly, look at the a/f ratio in the datalog, it should read close to 14.7 during idle.
2) If the water temperature tab is enabled in the parameters menu. If it is not, nothing will happen. Also, the water temperature must fall within the temperatures specified in the A/F target menu, otherwise the Autotune will not activate, you can select "water temperature" in the datalog menu, thus enabling you to see the actual temperature the EMU is reading.
3) When the throttle activation voltage has been reached. In the case of the throttle voltage input parameters shown above (minimum = 0.43V, maximum = 5.0V). The autotune activation voltage corresponding to 20% throttle is approx. 1.34 V. This is why any low voltage input can be used, so long as it is sent to the TPS input when you want to use Autotune. The 20% activation setting is arbitrary, use whatever value suits.
4) If the a/f target map is activated (selected) in the "map select" menu, and the map filled in with the appropriate a/f values.
5) If laptop is connected and communicating with EMU.
__________________
08-28-2008, 01:43 PM
Master FitFreaker
SO... any chance I can come hang out in Illusives driveway and mooch off of ET & Jon to swap out my manifold & alt pulley on the side
...Will bing coffee and stay late helping Justin part out
__________________
08-28-2008, 07:10 PM
Administrator
I don't mind. But we will be at ET's house, so you'll be alone on my driveway LOL!
__________________
- KillerFit #10 -
08-28-2008, 07:30 PM
Yeah and no Jon this weekend so it's all me. You can drop by for sure and depending how things are going I might be able to swap the pulley and we'll have to see about the manifold.
It's all fairly simple but I am not sure how long that SC will take to come out and that is the main goal for the day so Justin can drive her back home that night.
__________________
2008 VBP Fit LX M/T
3m clearbra
Keyless entry
Sport Spoiler
Zeta dead pedal
08-28-2008, 07:41 PM
Administrator
I wasn't expecting to go home that night haha, my dad was going to come pick me up. Can we take out the suspension too? Adam wants that  I'll pay you extra for it Etienne
__________________
- KillerFit #10 -
08-28-2008, 09:37 PM
we'll spend the whole day on it and see where we stand that night but I'll take as much off as you need buddy, suspension should not be an issue but we will need the stock parts and I have a spring compressor to throw it all back together.
__________________
2008 VBP Fit LX M/T
3m clearbra
Keyless entry
Sport Spoiler
Zeta dead pedal
