Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Honda Dealer and Honda USA Discussions > Honda Fit Dealer Representatives
Honda Fit Dealer Representatives Interact with local Honda dealer representatives for news, availability and purchase information.
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 12-03-2007, 11:02 PM
senador is an unknown quantity at this point
2008 Wiring recall?
Can any dealer representatives provide any information regarding a possible recall of 2008 Honda Fits. I just bought an '08 and I want to make sure to get anything fixed if there is a recall. It's been mentioned here:
New Topic Area - Honda Bulletins
and here:
http://www.fitfreak.net/forums/fit-t...tml#post201751
Sponsored Links
  #2 (permalink)
Old 12-08-2007, 06:23 PM
Bahumut's Avatar
Bahumut is an unknown quantity at this point
and here:
I don't think this is a recall issue.. Just a service bulletin as in, if it breaks, they'll fix it, but you're not required to bring in the car.
  #3 (permalink)
Old 12-08-2007, 06:35 PM
spreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to livespreadhead relies on Rep Points to live
It is a recall, according to the bulletin, customers will start being notified the week of Dec. 17. It includes all 07s and some 08s (up to serial #019313). Here is the bulletin in pdf form http://www.boringspot.com/files/A07-088.pdf (thanks dbcmaster).
  #4 (permalink)
Old 02-28-2008, 11:13 PM
8AV8OR2's Avatar
8AV8OR2 has a spectacular aura about8AV8OR2 has a spectacular aura about
Send a message via MSN to 8AV8OR2
Its a quick repair. Basically the wire harness that runs down the inside of the rocker on the drivers side has four harness splices, 2 splices on DX model, beside the drivers seat. The splices are wrapped in a tape type sort of vinyl deal and in some instances they have been corroding from water and or salt buildup. I work for the local Honda dealer in Moncton, New Brunswick and i have never seen one corroded, i have done probably 30 inspections and repairs. If any corrosion is found, the complete cabin harness is replaced, if no corrosion is found, the repair procedure is used. All the tape is taken off the splices, a new sort of eurethane wrap is put on the splices to waterproof and then you reseal the harness. Myself, i put the wrap on, tape up the wrap, put the loom back on and tape the loom up after, just for added protection.
Other than that, i haven't really seen many issues on the Fit, i have replaced a few Air Fuel sensors, but there is a reason for that. Honda came up with some better software for the ecm/pcm for controlling the heater times and duration on the af sensors. In our canadian climate, in the extreme cold, the AF heater comes on right away to warm the sensor up for faster readings, but it is cracking the element inside from the temp difference. Honda let the exhaust warm the sensor first to prevent premature damage of the sensor, thats what the new software does. So if your Fit has never had an ECM rewrite, there is one available.
Reply
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2008 Honda Fit review torres General Fit Talk 6 10-28-2007 07:11 PM
2008 fit has tire pressure monitor? Gordio General Fit Talk 16 09-06-2007 12:47 AM
Headlight Wiring Diagram Stevengeorge Fit Interior & Exterior Illumination 1 10-28-2006 11:55 PM
Japanese Fit Recall PhillyJoe Front Page News 10 08-08-2006 12:26 AM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
