Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Off Topic Forums > Off Topic Discussion
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 11-18-2008, 10:43 PM
Shaggs2Dope's Avatar
Frequent FitFreak Poster
Shaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to live
My HID v2.0 for my 05 CBR600RR
Just finished up rewiring my HID headlamps with a cutoff switch.
What a must have, should have done it years ago. Got tired of turning the bike on/off when ballast misfires after start. Now the High and Low beams operate fully independently of each other. I can run no lights, Low Only, High Only, or Both.
I turn the bike on, let it warm up, then flip on the HIDs. Fires perfectly every time.
lil video if it in action
Login | Facebook
rip off the whole front end quick-style instead of as per repair manuals, takes 1/5th the time.
Front end off testing switch
Bike running, headlights killed for engine warmup
Headlight toggle switch, hidden bracket for no drill install (switch turned off)
Switch turned on, HIDs are back on
The HIDs are better than ever, and the battery feels stronger for starts. It's definitely one of the must-have low dollar mods if you have HID. Getting the front fairing on straight with everything attached is the biggest bitch other than making the hidden bracket.
I got a two position toggle switch. Wired the red HID wire to the LOAD prong, the black HID wire went to EARTH, and I split that one so it works as ground for both the HID and the LED for the toggle through the h7 negative terminal from OEM bulb connector, and then made a jumper for POWER source to go to the Positive side of the OEM h7 bulb connector. I can upload a diagram if you would like one to make it super easy if anyone else wants to do this mod.
And for the bracket, I didn't wanna drill my plastics so I cut an L-bracket for like a fence in half, drilled the pilot hole bigger to fit the switch, and its a super thick bracket, nearly killed the drill bit and saw blade. Then I affixed it underneath the left ram air cover and adhered it with high bond 3M double sided tape, which is the same material holding the ballast.
__________________
Aww, they love each other, but are jealous of who gets my attention
Sponsored Links
  #2 (permalink)
Old 11-19-2008, 08:51 PM
avocado123's Avatar
FALCON PUNCH!!
avocado123 relies on Rep Points to liveavocado123 relies on Rep Points to liveavocado123 relies on Rep Points to liveavocado123 relies on Rep Points to liveavocado123 relies on Rep Points to liveavocado123 relies on Rep Points to liveavocado123 relies on Rep Points to liveavocado123 relies on Rep Points to liveavocado123 relies on Rep Points to liveavocado123 relies on Rep Points to liveavocado123 relies on Rep Points to live
+rep for a job well done. I'm too lazy to do that on my gixxer so as soon as I put the key in the ignition I start the bike I see you got a set of Pilot Powers, what else you got done to her?
__________________
"Useless Fourdoor"
  #3 (permalink)
Old 11-19-2008, 10:35 PM
Thanks for the good words. Its just a good mod to do. I have had to bump start the bike a few times after the HIDs zapped the battery, which running down the street pushing your bike in full gear and jumping on it and shifting to second makes you tired, sweaty, and you can loop the bike.
as for mods
-Carbon Fiber Cone Cap Yoshimura RS5 slip-on exhaust(best mod ever)
-Lockhart Phillips smoked LED flush mount front signals
-Competition Werkes Fender Eliminator kit with spring loaded flip up mount
-Flush mount rear indicators
-6000k HID w/cutoff switch (obviously)
-6000k LED third Light
-6000k LED plate light
-Those pilot powers you saw, wayyyyy better than the dunlop D208's by far
what year/color scheme gixxer do you have. I am an all honda guy but I used to work for Yamaha/Kawasaki. My only non-honda is my 74 datsun truck. BTW-lovin the SSR's on your ride
__________________
  #4 (permalink)
Old 11-20-2008, 08:39 AM
avocado123's Avatar
FALCON PUNCH!!
The 06 blk/red 600. It came with Battlax's which SUCKED! Once I put on the Pilot Powers it made all the difference in the world
__________________
"Useless Fourdoor"
Reply
Tags
05, cbr600rr, diagram, flip, hid, light, mod, plates, turn
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
I need your feedback on RiceBoyTV V2.0 Hissy Fit Off Topic Discussion 2 08-29-2008 09:16 PM
Yet Another Exotic Car Meet V2.0 (Seriously, this one will choke a T1, No Joke) Sid 6.7 Other Car Related Discussions 0 08-29-2008 08:27 PM
Music Link V2.0 FrogDaddy Fit I.C.E. 0 07-14-2008 01:13 AM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
