Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > The Honda Fit and Jazz Forums > Other Car Related Discussions
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 05-04-2005, 12:16 PM
Jafir Elkurd
Guest
Posts: n/a
Re: '93 Accord T-belt Service - Balance Shaft Gear Set????
I've never seen it replaced.
"Carl Gerhold" <gerholds@comcast.net> wrote in message
news:kJ6dnXBa1dWBeZ_fRVn-1A@comcast.com...
> Good question....I have one, has anyone ever had to replace this part?
Sponsored Links
  #2 (permalink)
SoCalMike
Guest
Posts: n/a
TeGGer® wrote:
> Check out that pricing...
hm... why are 2 gears $4/ea, and ones $150?
  #3 (permalink)
Carl Gerhold
Guest
Posts: n/a
"SoCalMike" <mikein562athotmail@hotmail.com> wrote in message
news:c9idnfdBTfcCQJ_fRVn-pQ@comcast.com...
  #4 (permalink)
Carl Gerhold
Guest
Posts: n/a
Yep, it was a rather expensive job. With this much invested, I'm thinking
of keeping it around for awhile. Update on the PS hose. After cleaning all
of the parts in the area per your suggestion, I noticed some spots on the
lower hose which are right in line with the inside of the pulley. Looks
more like a front seal problem than a hose leak.
CG
"TeGGer®" <tegger@istop.c0m> wrote in message
news:Xns95F2C166EDB8Bteggeratistop@207.14.113.17.. .
> mike-r@earthlink.net (Mike) wrote in
> news:mike-r-0302051149360001@dialup-4.249.171.54.dial1.washington2.level3
> .net:
> > In article <mZGdnZ-XBME6rZ_fRVn-iw@comcast.com>, "Carl Gerhold"
> > <gerholds@comcast.net> wrote:
> >> Hi All,
> >> Thanks for the excellent responses on the power steering hose
> >> problem. I brought this question up with Tegger off-list and he
> >> never heard of it. Before getting the service done, the shop mgr.
> >> started talking about the Balance Shaft Gear Case probably needing
> >> replacing. Has anyone heard of this? He said that it's common for
> >> high mile Honda's to need this by the time for 2nd t-belt. Now I've
> >> done a lot of background searches and have yet to read of this. I
> >> went along to the tune of $208.00 and labor in addition to the t-belt
> >> job, was this something that was truly needed? '93 Accord SE 224K
> >> miles. Thanks.
> >> Carl
> > The seal in the balance shaft gear case could leak, requiring gear
> > housing replacement. There's also an o-ring on the back side. Verify
> > with the service writer if seal (not o-ring) leakage is the primary
> > reason for replacement...HTH
> Now that I've seen the drawings, I think I understand better (what a nice
> site!)
> http://tinyurl.com/46gtu
> It's part #36 on that illustration.
> There are TWO balance shafts, not one. Both are driven off the same belt.
> It's the cogged wheel ("gear") that engages the balancer shaft belt that
> Carl apparently had replaced.
> TeGGeR®
> The Unofficial Honda/Acura FAQ
> www.tegger.com/hondafaq/
  #5 (permalink)
TeGGer®
Guest
Posts: n/a
..net:
>> Hi All,
>> miles. Thanks.
>> Carl
site!)
TeGGeR®
  #6 (permalink)
Mike
Guest
Posts: n/a
> Hi All,
> Thanks for the excellent responses on the power steering hose problem. I
> brought this question up with Tegger off-list and he never heard of it.
> Before getting the service done, the shop mgr. started talking about the
> Balance Shaft Gear Case probably needing replacing. Has anyone heard of
> this? He said that it's common for high mile Honda's to need this by the
> time for 2nd t-belt. Now I've done a lot of background searches and have
> yet to read of this. I went along to the tune of $208.00 and labor in
> addition to the t-belt job, was this something that was truly needed? '93
> Accord SE 224K miles. Thanks.
> Carl
The seal in the balance shaft gear case could leak, requiring gear housing
replacement. There's also an o-ring on the back side. Verify with the
service writer if seal (not o-ring) leakage is the primary reason for
replacement...HTH
Mike
  #7 (permalink)
Carl Gerhold
Guest
Posts: n/a
Well, I found the part in question on cheapesthondaparts.com, it's the
driven gear, rear shaft. Still, is this something that typically needs
replacing on high mileage Accords? Just wondering....
Carl
"E. Meyer" <e54.meyer@ieee.org> wrote in message
news:K4-dnfQhUNxmoJ_fRVn-ig@comcast.com...
> Isn't the balance shaft just that - a shaft. I don't think there are any
> gears associated with it. It is usual to replace the balance shaft belt
> when you do the timing belt.
> news:mZGdnZ-XBME6rZ_fRVn-iw@comcast.com...
> > Hi All,
I
the
have
'93
> > Carl
  #8 (permalink)
Carl Gerhold
Guest
Posts: n/a
Hi All,
Carl
  #9 (permalink)
E. Meyer
Guest
Posts: n/a
> Hi All,
> Carl
Reply
« - | Carfax $1.50 »
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
