Civic makes a loud ticking noise when cold
Old 05-04-2005, 11:16 AM
Mike
Guest
Posts: n/a
Hi All,
I have a 1995 Honda Civic GLi (D15) and when I start it in the morning
the engine is quite noisy. It produces a ticking noise and goes away
after 5 minuets then the car is fine. It only happens when the car is
cold, once it has been driven it will not do it again during the course
of the day. I have adjusted the tappets and it has made no difference.
I also notice the car lacks in power between 3k rpm and 4k rpm then it
comes back at 4.5k rpm. Any suggestions on this problem?
Regards,
Michael.
ravelation
Guest
Posts: n/a
Re: Civic makes a loud ticking noise when cold
>and when I start it in the morning the
>ticking noise and goes away after 5
>happens when the car is cold, once it
>during the course of the day. I have
>difference.
I had a Lexus RX300 that developed what's referred to as Piston Slap. It
only occurs during the first start up of the day, when the engine has
been sitting overnight. Do a search on Piston Slap and you'll probably
be saying, "That's my car!"
>suggestions on this problem? Regards,
That could be a function of the Vtec kicking in. Is your engine a Vtec?
My son had a '99 Civic EX and you could feel the Vtec kick in and I
think it was around 4500 rpm. I'm not sure about your model, though.
Mike
Guest
Posts: n/a
> >difference.
Hi ravelation,
Thanks for the suggestion. I have been also told that it may be a
broken exhaust manifold stud or bad exhaust manifold gasket. I will
look into all the suggestions and see how I go.
Regards,
Mike.
capt455
05-31-2014 11:54 AM
benedictARNOLD
02-20-2014 03:13 PM
Santiad
10-28-2013 12:27 PM
fujisawa
08-07-2012 05:52 PM
DesignGuy
07-20-2005 01:35 PM
Quick Reply: Civic makes a loud ticking noise when cold
