Fit FREAK.net
Go Back   Honda FIT Forums > The Honda Fit and Jazz Forums > Other Car Related Discussions
Reply
  #1 (permalink)
Old 05-04-2005, 12:16 PM
SoCalMike
Guest
Posts: n/a
Re: Prelude stalling problem (picture and movie included !) - needhelp locating some engine components
Chris wrote:
> because I also had an intermittent restart problem (once in a while
> after stopping the engine to pop into a shop it wouldn't restart for
> about a minute).
sounds like the main relay, yes?
Sponsored Links
  #2 (permalink)
Chris
Guest
Posts: n/a
Re: Prelude stalling problem (picture and movie included !) - need help locating some engine components
Great news! I got the exhaust centre section replaced (coroded) and
while I was there I asked the garage to replace the main fuel relay
about a minute).
Now my rough idle, intermittent stall and intermittent restart problems
are all gone ! Dont know if it was the exhaust or main relay that fixed
it. Hope this helps someone else out !
Chris wrote:
> I've had a stalling problem for the past year on my '93 Prelude Si
> VTEC.
> It idles rough and sometimes stalls when warm and the revs drop
> (typically when stopping for traffic lights).
> The distributor recently failed and I was gutted that a replacement
> didn't help me with the stalling problem.
> So, from searching the web I reckon it might be the Idle Air Control
> (IAC) valve (aka EACV Electronic Air Control Valve).
> Can someone please tell me from this photo where this component is
> located?
> http://63.218.54.74/prelude/airvalves.jpg (200KB)
> I've placed a red X where I think it is located.
> Also, where is the fast idle control valve ?
> While we're at it, is the EGR valve where I've marked EGR??? ?
> And, finally what is the black think where I've written "What is this
> In case anyone is interested in helping me further, this link points
> to a
> movie of the rough idle.
> http://63.218.54.74/prelude/roughidle.mpg (2MB)
> I increase the revs 3 times
> 1. Initially the fan is on so it's quite noisy (ignore this one).
> 2. Fan stops and noise level drops. I pull throttle chord again,
> engine runs ok.
> 3. I pull throttle chord the third time, idle drops very low and
> engine almost stalls, then revs pick up to normal again. When on the
> road it sometimes actually stalls (a few times a week). There is also
> a rattle, this is coming from a vibrating heat sheild.
> Notes:
> There is one ECU code (code 12 - EGR lift valve). Local dealer has
> checked vacuum and thinks it might be a bad ECU or bad wiring but
> hasn't been able to find out for sure.
> Local dealer hasn't been able to successfully diagnose the stalling
> problem and after 2 visits has sent me home with a new battery and
> distributor (which had failed).
Reply
« - | Carfax $1.50 »
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Go
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
