Re: Civic Axle Shaft Replacement Nightmare
WaterWatcher wrote:
> This has been the most frustrating of the many car repairs that I've done
> over the years. I've replaced the passenger side drive axle on my '90 Civic
> four times and apparently I'm not done yet. The first three were ARI brand
> reman shafts which either were noisy or vibrated. Finally, I had the parts
> store order me an A-1 Cardone axle and I thought my problems were solved.
> But, now I've found that the seal is leaking. When I installed the axle I
> noticed it was considerably harder to insert into the transmission than the
> others but I was thinking the circlip in the end that retains it in the
> trans was hanging up. Now, I'm thinking they gave me the wrong shaft (yes I
> know how that sounds) that did not fit the seal correctly. Does anyone know
> if there are differences in the shafts for Civics, such as having a larger
> diameter where the seal fits?
there's different overall diameters - not sure if there's any
differences specific to the seal. chances are, as stated by the others,
it's a damaged seal. just replace it & you'll be fine.
> I noticed the Cardone axle was different from
> the others where the big nut is staked. It had a flat spot to flatten the
> nut against rather than a keyway.
don't worry about it - still works the same.
> I thought this was strange but I know
> that Honda frequently makes production run changes. Does anyone out there
> have a clue to what the problem might be? Wrong shaft? Bad mechanic?
> Phase of the moon wrong?
> BTW, this is an indie parts store that has an excellent local rep, but I'm
> frustrated beyond belief with them now.
> Thanks for any help,
> WW
