Changing timing belt -- CIVIC 98
Old May 4, 2005 | 11:16 AM
Blackhill
Guest
Posts: n/a
Hi!
I'm changing the timing belt on my Civic (130 000K) over
the weekend and I was wondering if someone had
a tip on how to maintained the timing on the "CAMS"
Thanks!
Blackhill.
disallow
Guest
Posts: n/a
Re: Changing timing belt -- CIVIC 98
there is a marking on the engine block for where
the crank pulley needs to be, and the camshaft
should have a marking on it that should be at 90
degrees to the top of the engine.
t
John Ings
Guest
Posts: n/a
On Tue, 29 Mar 2005 20:17:21 -0800, "Blackhill"
Get yourself some nail polish in a bright color. Before removing the
old belt, mark the belt, and a crankshaft and cam sprocket tooth with
the nail polish. Lay the old belt on the new one and transfer the
marks, then line the new belt's marks up with those on the sprockets.
Abeness
Guest
Posts: n/a
TeGGer® wrote:
> If you don't have a female to cadge nail polish from and don't feel
> comfortable buying it yourself, you can always use Wite-Out, available at
> any office supply store.
Heh heh. Some males use nail polish, too, ya know... <g>
Subhabrata Bhattacharyya
Oct 12, 2005 08:30 PM
pch
Aug 26, 2005 12:55 AM
PKeys2003@aol.com
May 4, 2005 11:16 AM
sorensong@gmail.com
jim beam
