gregfocker@earthlink.net wrote:
> disallow wrote:
> > is there a switch under the dash somewhere to
> > switch from valet mode?
> Yes. I can switch to and from valet mode OK now. But I still can't
> lock the doors in either mode. The alarm doesn't lock them anymore,
> and I can't lock them manually with the keys nor from the inside by
> pressing the lever/latch in. It won't give.
When you say you can't even lock the doors manually, do you mean that
locking the driver's door (with key or knob) does not cause the other
doors to lock, or do you mean that you can not even lock the driver's
door using the key in the driver's door or using the knob on the
driver's door? Does the lock on the passenger side work if you use the
key in the passenger side or the knob on the passenger side?
When you try to lock the doors, do you hear any unusual sounds (like the
lock actuators trying to lock and then immediately reversing to unlock)?
A very modest collection of Honda tech info can be found at:
http://www.geocities.com/ng_randolph
