Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > The Honda Fit and Jazz Forums > Other Car Related Discussions
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 05-10-2005, 12:42 PM
dtrejo
Guest
Posts: n/a
1994 Honda Civic- Ignition lock
Someone tried to steal my sons Honda and destroyed the ignition key hole.
The steering wheel is in the LOCKED position. We have plugged in a new
ignition and the car does start, its that the steering wheel is still
locked. How do I unlock it? Please help. THANKS
Sponsored Links
  #2 (permalink)
Old 05-15-2005, 08:30 PM
Tim Zimmer
Guest
Posts: n/a
Re: 1994 Honda Civic- Ignition lock
Try to unlock the steering wheel with the cylinder removed. Use a Phillips or
flathead screw driver. If it won't unlock then the mechanism is either broken
or a shattered material has jammed the ignition column assembly.
  #3 (permalink)
jim beam
Guest
Posts: n/a
if that's the case, the o.p. needs to be very careful when they free up
the mechanism. if the shaft has been scored & damaged, it can in time
fatigue. potentially fatal. that's how ayrton senna died. best policy
if damage is evident is to go to a junk yard & get a replacement
steering shaft assembly. fairly quick & simple to replace. hardest
thing is removing the steering wheel! check the helm manual for proceedure.
Reply
Tags
1994, civic, honca, hondas, ignition, steal, tool, unlock
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
