Fit FREAK.net
Go Back   Honda FIT Forums > The Honda Fit and Jazz Forums > Other Car Related Discussions
Reply
  #1 (permalink)
Old 06-03-2005, 02:06 AM
Brooklin
Guest
Posts: n/a
Can't get the %$#@! license plate off
Not quite a strictly Honda question, but since I've gotten lots of
good info here in the past, I'd thought I post here.
I have a '97 Civic that I was putting a new front license plate cover
on. The bolts were pretty tight, but I loosened them up with WD40.
The last bolt seemed to turn, but the nut on the inside of the bumper
was turning and not the screw.
Now I can't get the last bolt off to change the cover (or remove the
plate).
Any suggestions.
Thanks in advance.
Sponsored Links
  #2 (permalink)
TeGGeR®
Guest
Posts: n/a
Re: Can't get the %$#@! license plate off
Brooklin <Brooklin@primus.ca> wrote in
news:t0ls919j71rvius433ejtr776jdgaljpun@4ax.com:
> plate).
> Any suggestions.
Drill it out.
TeGGeR®
www.tegger.com/hondafaq/
  #3 (permalink)
Randolph
Guest
Posts: n/a
> plate).
I can't help you with the existing screws (short of taking the bumper
off to get access from the back, it isn't all that hard to do). Make
sure to use M6 metric machine screws to install the new frame, the ones
you have in there are probably #12-24 screws, they are fairly easy to
force into the M6 threads, but can be a royal pain to get back ut.
A very modest collection of Honda tech info can be found at:
http://www.geocities.com/ng_randolph
  #4 (permalink)
Dan Beaton
Guest
Posts: n/a
Brooklin (Brooklin@primus.ca) writes:
> plate).
> Any suggestions.
> Thanks in advance.
Can you get vice grips on the nut? If you can get it to start to run,
likely you can get it off. Or use a hack saw (ughh) or dremel
tool to cut the head off. A cold chisel could work but it might be
worse than the hack saw in terms of doing collateral damage.
Dan
(This account is not used for email.)
Reply
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Go
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
